The ASUS Chromebook C213 is the ideal education computer for every school IT manager, student, and teacher. With its classroom ruggedness, the ASUS Chromebook C213 is developed to meet the daily rigors and intense usage by students both inside and outside of the classroom. Beyond its rugged construction, the ASUS Chromebook C213 is also designed for easy maintenance to minimize downtime. The result is a Chromebook, which is designed for maximum usage, creating more learning opportunities for students.
Military grade reliability & durability to withstand every situation in school
Every C213 is put through a rigorous chain of reliability tests to ensure it functions without disruption. These tests affirm that the C213’s solid and sturdy construction can withstand the punishing demands of modern day education.
No disruption from accidental drops
Dropping the notebook in school is a major problem as components can be damaged and affecting its function. Well, not anymore as the C213’s best-in-class drop test from 120cm height ensures the critical components are protected.
Reduces the impact from any knocks and drops
All 4 exterior edges and corners of the C213 are protected by rubber wrapped protective guard, using reinforced nano-molding technology, offering maximum security for critical components.
Clever features making typing a bliss every day
A spill-resistant keyboard is a must for the classroom where accidental spilling of liquid is not uncommon. A 2mm key travel also allows for more accurate typing.
Convenient every time and every day
The versatility of 4 viewing modes, from a laptop, tablet, stand to tent mode, provides the best studying angle for students in a classroom or outdoors. The 360-degree flip mechanism also allows the C213 to be opened to any desired angle to fit the required situation.
More interaction & more responsive learning
Touch learning mirrors the lifestyle habit of students as they live in a world of touch gadgets. This familiarity not only allows for easy usage of the C213 but also encourages a higher level of intuitive interaction.
Learning becomes more fun with video conference & photography
The ingenious dual camera function allows for video conference and photography, taking the learning experience to a whole new level of creativity and collaboration. Not forgetting the hours of fun the dual camera will bring, especially during field trips.
Robust, reinforced rubber, wrapped protective guard
All exterior edges and corners of the C213 Chromebook are protected, using reinforced nano-molding technology, which ensures critical components are secured. -
Spill-proof keyboard a must for the classroom
A classroom of students presents many possible scenarios for accidents. Very common is the accidental spilling of liquid on the notebook and keyboard. That's why the C213 Chromebook keyboard is spill-proof and can repel liquid, giving you the additional peace of mind. -
Easy-grip design for better holding traction
Imagine a typical school day and it will be easy to understand the potential hazards in the accidental dropping of the notebook. From the loose of grip, when carrying the notebook, from passing the notebook from one student to another or even an accidental push off from the table are very real scenarios. That's why the C213 Chromebook is designed with 2 special grips, which are strategically located to minimize these hazards. -
180-degree hinge allows a fully open Chromebook
Ideal for easy viewing, especially for group study or collaboration. -
Larger character-printed keys
Provides superior legibility for easier typing. -
Anti-glare display
Easy to view even in sunlight and less strenuous on the eyes. -
Long hours of battery life
A notebook's battery life, which can last the full school day and without having to sacrifice on the brightness of the display, are crucial for students. Not forgetting the field trips or projects outside of the classroom environment, where there is no available power source, makes the battery life even more critical. There is no worries with the C213 Chromebook, as it has a long battery life with normal brightness to last the full school day.
- ASUS Chromebook Flip C213NA BU0033 - 11.6" - Celeron N3350 - 4 GB RAM - 32 GB eMMC
- Product Type
- Chromebook - flip design
- Operating System
- Chrome OS
- Processor
- Intel Celeron N3350 / 1.1 GHz (2.4 GHz) / 2 MB Cache
- Memory
- 4 GB LPDDR3 (provided memory is soldered)
- Storage
- 32 GB - eMMC
- Display
- 11.6" LED backlight touchscreen 1600 x 900 / HD+
- Graphics
- Intel HD Graphics 500
- Integrated Webcam
- Networking
- 802.11ac, Bluetooth 4.1
- Battery
- 4-cell
- Grey, dark grey
- 30.7 cm x 19.9 cm x 2.06 cm
- 1.25 kg
- Limited warranty - 3 years - on-site
- Product Type
- Operating System
- Google Chrome OS
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.4 GHz
- Number of Cores
- Dual-Core
- Cache
- 2 MB
- 64-bit Computing
- RAM
- 4 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
Storage
- Main Storage
- 32 GB SSD - (eMMC)
Display
- 11.6"
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Resolution
- 1600 x 900 (HD+)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 200 cd/m²
- Anti-glare, WideView, 50% NTSC colour gamut
Audio & Video
- Graphics Processor
- Camera
- Yes - HD
- Sound
- Stereo speakers, microphone
Input
- Keyboard, touchpad
Communications
- Wireless
- Technology
- 4-cell Lithium Ion
- Capacity
- 46 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 20 V, 2.25 A
Connections & Expansion
- 2 x USB 3.0 , 2 x USB-C , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD)
- Grey, dark grey
- ASUS USB Charger+
- Included Accessories
- Power adapter
- 1.25 kg
