Asus BR1100C Intel Celeron N4500 4GB 128GB EMMC 11.6" Windows 11 Professional Academic
Quicklinx: HC7BWS00 Mfr#: BR1100C-C1XA-3Y#SP
  • Celeron
  • IEEE 802.11n
ASUS BR1100C is designed with one thing in mind: to keep on going however tough the environment gets. Built to military-grade standards, it's packed with clever protective features, including an all-round rubber bumper, spill-resistant keyboard and ultratough I/O ports. BR1100C also supports fast connectivity and has AI-powered noise-canceling technology for high-quality remote learning and conferencing. There's battery life to handle more than a full day's learning, and a modular design makes it easy to service, BR1100C is ready for anything!
  • Ultimate rugged design
    ASUS BR1100C is built to withstand everyday knocks, bumps, drops and spills without damage. So, whether it's dropped from a classroom desk or the dining table, BR1100C is built to keep on going.
  • Rubber bumper
    All four exterior edges and corners are protected by a tough rubber bumper, which reduces the impact of physical shocks to ensure critical components are always safe and sound.
  • Ready for action
    Classrooms can be tough, but ASUS BR1100C is tougher! Built to surpass demanding US military-grade MIL-STD-810H durability standards, it's also torture-tested to pass stringent ASUS quality tests. It can withstand occasional drops of up to 120cm - more than standard desk height - and the hinge and I/O ports are fully tested to endure the stresses and strains of everyday use.
  • Easy maintenance for uninterrupted learning
    For easy on-site servicing and reduced downtime, ASUS BR1100C has a modular design that allows key components - such as the keyboard, battery, thermal module and I/O ports - to be replaced in minutes using simple tools. As well, the underside is secured attached using captive screws, eliminating worries about losing these little parts during repairs.
  • Noise cancellation
    To provide exceptional remote learning and video-conferencing experiences, ASUS BR1100C features innovative ASUS AI noise-canceling technology that employs machine learning in order to isolate unwanted noise from human speech. Try the demo to experience the amazing difference that ASUS AI noise-canceling technology can make.
  • Noise-reducing camera
    Innovative 3D noise-reduction (3DNR) technology on the ASUS BR1100C webcam eliminates random noise that naturally affects any camera, especially in low-light conditions - significantly improving image quality without compromising exposure or detail levels.
  • Webcam shield
    Slide over the physical cover to disable the webcam for instant privacy. This simple features helps keep users safe - it's especially ideal for younger users.
  • Microphone mute key
    It takes just a single tap to mute the microphone, providing quick reassurance that all your conversations are private.
  • At-a-glance student support
    ASUS BR1100C has a bright good-to-go LED indicator integrated into its top cover. This enables educators to see at a glance if a particular student's laptop is facing Internet connectivity or power problems - giving teachers a heads up when a student might need help.
  • All-day learning
    With many hours of battery life on a single charge, ASUS BR1100C will last for a full day of classes and more - empowering students to enjoy both uninterrupted learning and relaxation.
  • Connectivity for productivity
    Full connectivity is vital when you want to get things done efficiently.
ASUS BR1100C C1XA-3Y - 11.6" - Intel Celeron - N4500 - 4 GB RAM - 128 GB eMMC
Notebook - 180-degree hinge design
Operating System
Win 11 Pro Education
Intel Celeron N4500 / 1.1 GHz, up to 2.8 GHz / 4 MB Cache
4 GB DDR4 (provided memory is soldered)
Storage
128 GB eMMC
Display
11.6" touchscreen 1366 x 768 / HD
Graphics
Intel UHD Graphics
Integrated Webcam
Bluetooth 5.1, 802.11a/b/g/n/ac/ax, Gigabit Ethernet
3-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip
Dark grey
29.46 cm x 20.49 cm x 2 cm
1.26 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Operating System
Windows 11 Pro Education
Processor / Chipset
CPU
Max Turbo Speed
2.8 GHz
Number of Cores
Dual-Core
Cache
L3 - 4 MB
RAM
4 GB (provided memory is soldered)
DDR4 SDRAM
Storage
Main Storage
128 GB eMMC
Display
11.6"
Touchscreen
Yes (multi-touch)
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
220 cd/m²
Colour Gamut
45% NTSC
Anti-glare
Audio & Video
Graphics Processor
Intel UHD Graphics
Camera
Yes - 720p
Camera Features
Privacy shutter, World Facing Camera
Sound
Speaker, array microphone
Audio Features
Output: ASUS SonicMaster; Input: AI noise cancelling
Input
Keyboard, touchpad
Chiclet keyboard, 1.35mm travel distance, spill-resistant
Communications
Wireless
Network Interface
Gigabit Ethernet
Dual stream (2x2)
3-cell Lithium Ion
42 Wh
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
45 Watt, 19 V, 2.37 A
Connections & Expansion
Interfaces Details
Headphone/microphone combo jack , LAN , USB 2.0 , HDMI , USB 3.2 Gen 1 , USB-C 3.2 Gen 2 (Power Delivery)
Dark grey
Security
MIL-STD-810H tested, system password, Computrace ready from BIOS, LED indicator, rubber bumper, ASUS Antibacterial Guard, tamper-resistant
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter, dust cover
TUV Rheinland Flicker Free Certification, TUV Rheinland Low Blue Light (Software Solution)
1.26 kg
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
