BE229QLB LCD monitor features a Full HD(1920x1080) resolution with LED-backlit IPS panel and a 178° wide-view angle that minimizes color shift on both horizontal and vertical planes to ensure quality visuals from almost any direction.
BE229QLB LCD monitor features a host of connectivity options that include DisplayPort, DVI-D, D-sub, Audio in, Earphone jack, and two USB 2.0 ports.
Say goodbye to tired, strained eyes. ASUS BE229QLB features ASUS Flicker-free and Low Blue Light technologies to reduce instances of eyestrain and other damaging effects when spending long, countless hours in front of a display.
ASUS Flicker-Free technology by using Smart Dynamic Backlight Adjustment avoids low brightness level and high speed LED backlight flashing, clears out the distractive flicker, and brings comfort viewing experience to avoid Computer Vision Syndrome.
Vivid, lifelike visuals with 178° wide-view angles
BE229QLB LCD monitor features a Full HD(1920x1080) resolution with LED-backlit IPS panel and a 178° wide-view angle that minimizes color shift on both horizontal and vertical planes to ensure quality visuals from almost any direction. -
Extensive connectivity
BE229QLB LCD monitor features a host of connectivity options that include DisplayPort, DVI-D, D-sub, Audio in, Earphone jack, and two USB 2.0 ports. -
Great viewing comfort with Eye Care technology and ergonomic design for everyday computing
Say goodbye to tired, strained eyes. ASUS BE229QLB features ASUS Flicker-free and Low Blue Light technologies to reduce instances of eyestrain and other damaging effects when spending long, countless hours in front of a display. -
ASUS Flicker Free technology
ASUS Flicker-Free technology by using Smart Dynamic Backlight Adjustment avoids low brightness level and high speed LED backlight flashing, clears out the distractive flicker, and brings comfort viewing experience to avoid Computer Vision Syndrome. -
ASUS Low Blue Light technology - Blue Light Filter
The ASUS Low Blue Light monitors allow users to access four different Blue Light Filter settings onscreen, which you can choose from level 1 to level 4, depending on different tasks, to effectively reduce harmful blue light from the screen for the best viewing comfort. -
Versatile comfort with ergonomic stand design
With an ergonomically-designed stand with tilt, swivel, pivot, and height adjustments, the BE229QLB provides a comfortable viewing and usage experience. The ability to pivot the screen clockwise or counterclockwise 90 degrees for use in portrait mode comes in handy when working with long documents, coding or website browsing. Furthermore, the BE229QLB features a quick release stand to provide an easier way for frequent VESA wall mount scenario setup. Screw-free and it's done in seconds. -
Bundled with the MiniPC kit
ASUS BE229QLB monitor is bundled with the MiniPC kit for those who need to mount mini PCs on the monitor, to make the desktop clutter-free and space saving .
- ASUS BE229QLB - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 100000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Black
- 51.4 cm x 21.1 cm x 34.7 cm
- 5.7 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- TCO Certified Displays 7, ENERGY STAR Qualified
- UL, TUV GS, VCCI, BSMI, cUL, WHQL, CB, TUV Ergo, FCC, RoHS, WEEE, MEPS, ErP Ready, UkrSEPRO, RCM, ISO9241-307, TUV Rheinland Low Blue Light Certification
- 3-year warranty
- Display Type
- Diagonal Size
- 21.5"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 49 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Colour temperature
- HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, WideView, ASUS QuickFit Virtual Scale, ASUS VividPixel Technology, Low Blue Light Mode, Flicker Free technology
- Black
- 51.4 cm x 21.1 cm x 34.7 cm - with stand
- 5.7 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- Audio line-in , Headphones , DisplayPort , VGA , DVI-D , 2 x USB 2.0
Mechanical
- Tilt Angle
- -5/+33
- Swivel Angle
- 180
- Rotation Angle
- 180
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- MiniPC kit
- Cables Included
- 1 x VGA cable , 1 x audio cable , 1 x DisplayPort cable , 1 x USB cable
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 22 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0 Watt
- Dimensions & Weight Details
- Without stand - width: 51.4 cm - depth: 5 cm - height: 31.2 cm , With stand - width: 51.4 cm - depth: 21.1 cm - height: 34.7 cm - weight: 5.7 kg
- ENERGY STAR Certified
- TCO Certified
- Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £109.46 |
StarTech.com Articulating Monitor Arm | In Stock | £101.86 |
StarTech.com Dual Monitor Stand | In Stock | £69.36 |
StarTech.com Cubicle Monitor Hanger | In Stock | £45.29 |
StarTech.com TV/Monitor Arm - Wallmount | In Stock | £50.91 |
