Asus BE209QLB 19.5" 1440 x 900 5ms DVI-D VGA Monitor
Quicklinx: CW2SWS00 Mfr#: BE209QLB
Diagonal Size: 19.45in
Max Resolution: 1440 x 900
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, VGA (HD-15)
£112.87 ex VAT
£135.44 inc VAT
BE209QLB LCD monitor features a 1440 x 900 resolution with LED-backlit IPS panel and a 178° wide-view angle that minimizes color shift on both horizontal and vertical planes to ensure quality visuals from almost any direction.
BE209QLB LCD monitor features a host of connectivity options that include DisplayPort, DVI-D, D-sub, audio in, earphone jack, and two USB 2.0 ports.
  • Vivid, lifelike visuals with 178° wide-view angles
  • Extensive connectivity
  • Great viewing comfort with eye care technology and ergonomic design for everyday computing
    Say goodbye to tired, strained eyes. ASUS BE209QLB features ASUS Flicker-free and Low Blue Light technologies to reduce instances of eyestrain and other damaging effects when spending long, countless hours in front of a display.
  • ASUS Flicker Free Technology
    ASUS Flicker-Free Technology by using smart dynamic backlight adjustment avoids low brightness level and high speed LED backlight flashing, clears out the distractive flicker, and brings comfort viewing experience to avoid computer vision syndrome.
  • ASUS low blue light technology - blue light filter
    The ASUS low blue light monitors allow users to access four different blue light filter settings on screen, which you can choose from level 1 to level 4, depending on different tasks, to effectively reduce harmful blue light from the screen for the best viewing comfort.
  • Versatile comfort with ergonomic stand design
    With an ergonomically-designed stand with tilt, swivel, pivot, and height adjustments, the BE209QLB provides a comfortable viewing and usage experience. The ability to pivot the screen clockwise or counterclockwise 90 degrees for use in portrait mode comes in handy when working with long documents, coding or website browsing.
ASUS BE209QLB - LED monitor - 19.45"
LED-backlit LCD monitor - 19.45"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
1440 x 900
Pixel Pitch
0.2907 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
45.7 cm x 21.1 cm x 34.6 cm
4.8 kg
Environmental Standards
ENERGY STAR Qualified
UL, TUV, TUV GS, VCCI, BSMI, cUL, WHQL, CB, TUV Ergo, FCC, RoHS, WEEE, PSE Mark, MEPS, ErP Ready, UkrSEPRO, TCO Displays 6.0, RCM, ISO9241-307, Ukraine EMC DoC, TUV Rheinland Low Blue Light Certification
3-year warranty
Display Type
Diagonal Size
19.45"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
1440 x 900
Pixel Pitch
0.2907 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, WideView, ASUS QuickFit Virtual Scale, ASUS VividPixel Technology, Low Blue Light Mode, Flicker Free technology, ASUS EyeCare Technology
45.7 cm x 21.1 cm x 34.6 cm - with stand
4.8 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
Audio line-in , Headphones , DisplayPort , VGA , DVI-D , 2 x USB 2.0
Mechanical
Tilt Angle
-5/+33
Swivel Angle
180
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), quick release mechanism
MiniPC kit
1 x VGA cable , 1 x audio cable , 1 x DisplayPort cable , 1 x USB cable
15.74 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Dimensions & Weight Details
With stand - width: 45.7 cm - depth: 21.1 cm - height: 34.6 cm - weight: 4.8 kg , Without stand - width: 45.7 cm - depth: 5 cm - height: 30.6 cm
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
Asus BE209QLB 19.5 Bundle deal on Asus BE209QLB 19.5" 1440 x 900 5ms DVI-D VGA Monitor
£205.90
Response Time: 5ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Asus
Price Range Ex VAT: 100 - 150
