The ASUS B1MR Ultra-bright Wireless LED Projector delivers incredibly bright, sharp visuals with native WXGA 1280 x 800 resolution, 900 lumens light output, and a 100% NTSC color scale to project precise, detailed color images. The B1MR features a mercury-free Eco-LED light source with a 30,000-hour lifespan to cut down on maintenance and bulb-replacement costs.
Bright, crisp projections
The ASUS B1MR Ultra-bright Wireless LED Projector delivers incredibly bright, sharp visuals with native WXGA 1280 x 800 resolution, 900 lumens light output, and a 100% NTSC color scale to project precise, detailed color images. The B1MR features a mercury-free Eco-LED light source with a 30,000-hour lifespan to cut down on maintenance and bulb-replacement costs. -
Compact portable Wi-Fi projector cuts the need for cables
The ASUS B1MR features a small Wi-Fi adapter for a direct wireless connection to a notebook PC, or Android and iOS devices. This removes the need to carry a video cable solely for presentation use, and allows presentations, documents and multimedia files to be streamed to the B1MR wirelessly from elsewhere in a room. The B1MR with ASUS Wi-Fi Projection APP helps bring iOS and Adroid content from input device to the big screen, and also provides advanced "Split Screen Control", to allow user to choose two or four split screens. -
Instant on and off
The ASUS B1MR turns on in five seconds without having to warm up, and powers off without the need for a cooling-down period. -
Auto Keystone Correction
Whatever angle the B1MR is positioned, the Auto Keystone Correction detects and corrects to ensure a straight, rectangular shape. -
Big screen at a short distance
The B1MR has the best short throw ratio for you to project a 51-inch image from a distance of only 1 meter from the screen.
- ASUS B1MR - DLP projector - short-throw - portable - 3D - black
- DLP projector
- 3D Capable
- Black
- Brightness
- 900 lumens
- Contrast Ratio
- 10000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Lens
- Short-throw fixed lens
- Bulb type
- RGB LED
- Bulb life cycle
- Up to 30000 hour(s)
- Video Input
- RGB, composite video - MPEG-4, AVI, WMV, MOV, MPG, MKV
- Supported Memory Cards
- SD Memory Card
- Speakers
- Speaker(s) - integrated
- 85 Watt
- 17.5 cm x 13.9 cm x 4.45 cm
- 900 g
- DLP projector
- 3D Capable
- Enclosure Colour
- Black
Projector
- Brightness
- 900 lumens
- Contrast Ratio
- 10000:1
- Image Size
- 79.2 cm - 389 cm
- Projection Distance
- 0.6 m - 3 m
- Throw Ratio
- 0.9:1
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 85 Hz x 91.1 kHz
- Bulb type
- RGB LED
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- JPEG photo playback, MP3 playback, USB host function, DLP 3D Ready, 16:9 aspect ratio support, Wireless Ready, BMP photo playback, 16:10 aspect ratio support, PPT files support, XLS files support, PDF files support, 4:3 aspect ratio support, Mercury-free illumination technology, built-in foldable stand, WAV playback, WMA playback, AAC playback, ASUS SonicMaster, MP2 playback
Lens
- Keystone Correction Type
- Digital
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video
- SD Memory Card
- Digital Video Format
Speakers
- Integrated
- Output Power / Channel
- 2 Watt
- 1 x HDMI input - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type A , 1 x composite video input - mini-phone 3.5 mm , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x headphones - mini-phone stereo 3.5 mm
- Included Accessories
- Carrying case, remote control
- Cables Included
- 1 x VGA cable
- Security Features
- UL, VCCI, C-Tick, CB, CCC, FCC, PSE Mark, GOST-R
- Power Source
- AC
- 85 Watt
- Power Consumption Stand by
- 0.5 Watt
- 17.5 cm
- 13.9 cm
- 4.45 cm
- 900 g
- 0 °C
- 40 °C
- 20 - 90%
- Sound Emission
- 32 dBA
- Sound Emission (Economic Mode)
- 28 dBA
