Be the best on the battlefield with B150M Pro Gaming's truly immersive SupremeFX audio and experience sound so alive with realism that it hands you the vital competitive edge needed to win. SupremeFX sounds stupendous - and puts both your ears and frags in front of everyone else! ASUS SupremeFX technology delivers high-fidelity, near-lossless audio no matter how frantic your game becomes. The purity and stability of the remarkable 115 dB signal-to-noise ratio (SNR) is assured, with a shielded design, electromagnetic-interference (EMI) cover and voltage-protected 5V power supply.
B150M Pro Gaming banishes lag - letting you annihilate your foes as fast as your trigger finger! The engineers pack in only the ultimate networking technology, including tournament-level Intel Gigabit Ethernet and ASUS LANGuard to keep your connection fast, so fire first and watch your enemies fall. Protect your back in the game and let B150M Pro Gaming protect all sides in the real world! Motherboard self-protection with loads of brilliant defenses, including the unique smart DIY features ensures long-term gaming is in your future. B150M Pro Gaming is built for play - strong enough storm through the industry's extremely punishing labs workouts. With B150M Pro Gaming you do more than just play - you'll experience gaming on the edge of reality.
Flawless audio that makes you part of the game
Be the best on the battlefield with B150M Pro Gaming's truly immersive SupremeFX audio and experience sound so alive with realism that it hands you the vital competitive edge needed to win. SupremeFX sounds stupendous - and puts both your ears and frags in front of everyone else! -
Shielded audio, superior sound with SupremeFX
ASUS SupremeFX technology delivers high-fidelity, near-lossless audio no matter how frantic your game becomes. The purity and stability of the remarkable 115 dB signal-to-noise ratio (SNR) is assured, with a shielded design, electromagnetic-interference (EMI) cover and voltage-protected 5V power supply. -
Illuminated shielding
Banish analog interference and enjoy eye-catching, customizable lighting effects. -
EMI cover
Effective shielding against electromagnetic interference preserves the integrity of audio signals for the ultimate quality. -
Top-speed protected networking
B150M Pro Gaming banishes lag - letting you annihilate your foes as fast as your trigger finger! The engineers pack in only the ultimate networking technology, including tournament-level Intel Gigabit Ethernet and ASUS LANGuard to keep your connection fast, so fire first and watch your enemies fall. -
Featuring Intel Ethernet for faster, smoother gaming. Intel's LAN has the serious double advantage of reducing CPU overhead and offering exceptionally high TCP and UDP throughput. This significantly reduces the processor's workload, so there's more power for your game and your gameplay. -
LANGuard for pumped-up throughput and surge protection
ASUS LANGuard is hardware-level networking protection that employs signal-coupling technology and premium anti-EMI surface-mounted capacitors for rock-solid gaming connections and better throughout for online play, plus electrostatically-guarded and surge-protected components for greater tolerance to static electricity and improved protection against surges. -
Performance level up
With x4 PCI Express 3.0/2.0 bandwidth, M.2 supports amazing data-transfer speeds. It is the perfect choice for an operating system or application drive, making your whole PC or professional apps work as fast as possible. -
FAN Xpert
Via two 4/3 pin (PWM/DC) combo fan connectors and two onboard thermal sensors, Fan Xpert makes sure every fan achieves the optimum balance of cooling performance and low noise. -
GPU Boost
ASUS GPU Boost technology lets you accelerate B150M Pro Gaming integrated GPU (iGPU) for extreme graphics performance safely and easily via a user-friendly interface - it's a free iGPU level-up! -
USB 3.0 Boost
This great technology accelerates the already-fast speed of USB 3.0, enabling transfer speeds. -
Gamer's guardian for real-world protection
Protect your back in the game and let B150M Pro Gaming protect all sides in the real world! Motherboard self-protection with loads of brilliant defenses, including the unique smart DIY features ensures long-term gaming is in your future. -
DRAM overcurrent protection
All connection ports and DRAM are protected against overcurrent and short-circuit damage by onboard resettable fuses, extending your motherboard's life. -
Stainless steel back I/O
Crafted from chromium-plated, corrosion-resistant stainless steel, the input/output (I/O) panel is three times longer than ordinary panels! -
ESD protection for extended component lifespan
Electrostatic discharge (ESD) could mean game over for your rig, so B150M Pro Gaming is protected by ESD Guards to actively prevent ESD - ensuring longer component lifespan and providing greater system resilience. Game on! -
Audio connector
Capacitor protection on both front and back audio-output circuits. -
LAN connector
ESD TVS diode protection and an anti-surge LAN connector protects against extreme events, such as lightning strikes. -
USB 3.0/2.0 connectors
On-circuit transient-voltage-suppression (TVS) diodes and capacitor protection for surface-mount and dual-inline packages. -
Built for gaming
- ASUS B150M PRO GAMING - motherboard - micro ATX - LGA1151 Socket - B150
- Product Type
- Motherboard - micro ATX
- Chipset Type
- Intel B150
- Processor Socket
- 1 x LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7
- Max RAM Size
- 64 GB
- RAM Supported
- 4 DIMM slots - DDR4, non-ECC, unbuffered
- Storage Ports
- 6 x SATA-600, 1 x M.2
- USB / FireWire Ports
- 4 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 2 x USB 2.0 via headers)
- Max Allocated RAM Size
- 1024 MB
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Chipset Type
- Intel B150
- Processor Socket
- LGA1151 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR4
- Bus Clock
- 2133 MHz
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
Graphics
- 1024 MB
Audio
- Audio Codec
- SupremeFX
- High Definition Audio
LAN
- Network Controller
- Intel I219V
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 2 x PCIe 3.0 x1
- Storage Interfaces
- SATA-600 / PCIe 3.0 -connectors: 6 x 7pin Serial ATA, 1 x M.2
- 1 x PS/2 keyboard / mouse , 1 x LAN (Gigabit Ethernet) , 4 x USB 3.0 , 4 x USB 2.0 , 1 x HDMI , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack
- Internal Interfaces
- 2 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header , 1 x serial - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, UEFI BIOS, ACPI 5.0 support, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support
- Sleep / Wake Up
- Wake on LAN (WOL), wake on PME
- Hardware Features
- Jack retasking, ASUS Q-Design, ESD Guards, Q-DIMM, ASUS EZ DIY, Q-Slot, CrashFree BIOS 3, audio jack detect technology, ASUS Q-Shield, ASUS Fan Xpert, ASUS DIGI+ VRM, Intel Clear Video HD Technology, Fanless Design Heatsink, USB 3.0 Boost, SupremeFX Shielding technology, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, Disk Unlocker, ASUS Enhanced DRAM Overcurrent Protection, Preboot eXecution Environment (PXE), ASUS Stainless Steel Back I/O, LANGuard, ASUS Gamer's Guardian
- Included Accessories
- Cable ties, I/O back plate, cable labels, 1 x M.2 screw
- Cables Included
- 2 x Serial ATA cable
- Software Included
- Drivers & Utilities, ASUS AI Charger, ASUS AI Suite III, ASUS EZ Update, Antivirus (OEM version), Media Streamer, ASUS EZ Flash 3
- Plug and Play
- 23.4 cm
- 21.8 cm
