Compact gaming punch with awesome RGB lighting
LGA1151 socket for 6th-genereation Intel® Core™ i7 / Core i5 / Core i3, Pentium® and Celeron processors
Dual-channel DDR4 2133 support
SupremeFX: Flawless audio that makes you part of the game
Sonic Radar ll: Scan and detect your enemies to dominate
Intel Gigabit Ethernet and LANGuard: Top-speed protected networking
RAMCache: Speed up your game loads
Gamer's Guardian: Highly-durable components and smart DIY features
2x2 Wi-Fi with MU-MIMO and M.2: Ultra-speedy transfers for faster gaming
Be the best on the battlefield with B150I Pro Gaming/Wi-Fi/Aura's truly immersive SupremeFX audio and experience sound so alive with realism that it hands you the vital competitive edge needed to win. With near-lossless delivery and exclusive Sonic Radar II technology to pinpoint battlefield enemies before they spot you, SupremeFX sounds stupendous - and puts both your ears and frags in front of everyone else! -
Shielded audio, superior sound
ASUS-exclusive SupremeFX technology delivers high-fidelity, near-lossless audio no matter how frantic your game becomes. The purity and stability of the remarkable signal-to-noise ratio (SNR) is assured, with a shielded design, electromagnetic-interference (EMI) cover and voltage-protected power supply. Supreme FX's superior components, including the trusted Realtek codec, maximize acoustic performance and eliminate interference - so you hear only the very best from your gaming headset or speakers! -
Scan and detect to dominate
Sonic Radar II displays a stealthy overlay that shows what your opponents and teammates are up to on the battlefield, all managed via a simple control panel and customizable game list. See the direction and origin of key in-game sounds, and practice your enemy-pinpointing skill, plus Audio Enhancement technology clarifies every last sound - so you hear the distant sound of enemy footsteps and become the hunter, not the hunted! -
Only the quickest shot survive, so B150I Pro Gaming/Wi-Fi/Aura banishes lag - letting you annihilate your foes as fast as your trigger finger! The engineers pack in only the best networking technology, including tournament-level Intel Gigabit Ethernet and ASUS-exclusive LANGuard and GameFirst technologies to keep your connection fast, so always fire first and watch your enemies fall. -
Featuring the very latest Intel Ethernet for faster, smoother gaming - always. Intel's LAN has the serious double advantage of reducing CPU overhead and offering exceptionally high TCP and UDP throughput. This significantly reduces the processor's workload, so there's more power for your game and your gameplay. -
Best surge protection
LANGuard means safer, more reliable connections for your battles! Advanced signal-coupling technology and premium surface-mounting processes join forces to protect your B150I Pro Gaming/Wi-Fi/Aura's connection and deliver pumped-up throughput, plus electrostatically-guarded and surge-protected components for greater tolerance to static electricity and greater protection against surges!
- ASUS B150I PRO GAMING/WIFI/AURA - motherboard - mini ITX - LGA1151 Socket - B150
- Product Type
- Motherboard - mini ITX
- Chipset Type
- Intel B150
- Processor Socket
- 1 x LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7
- Max RAM Size
- 32 GB
- RAM Supported
- 4 DIMM slots - DDR4, non-ECC, unbuffered
- Storage Ports
- 4 x SATA-600, 1 x M.2
- USB / FireWire Ports
- 1 x USB-C + 2 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 2 x USB 2.0 via headers)
- Max Allocated RAM Size
- 1024 MB
- Audio
- HD Audio (8-channel)
- LAN
- Bluetooth, Gigabit Ethernet, 802.11a/b/g/n/ac
- Product Type
- Chipset Type
- Intel B150
- Processor Socket
- LGA1151 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR4
- Bus Clock
- 2133 MHz
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
- 1024 MB
Audio
- Audio Codec
- SupremeFX
- High Definition Audio
LAN
- Network Controller
- Intel I219V
- Network Interfaces
- Expansion Slots
- 1 x CPU , 2 x DIMM 288-pin , 1 x PCIe 3.0 x16
- Storage Interfaces
- SATA-600 / PCIe 3.0 -connectors: 4 x 7pin SATA, 1 x M.2
- 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.0 , 1 x USB-C , 1 x PS/2 keyboard / mouse , 1 x DVI , 1 x HDMI , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x TOSLINK
- Internal Interfaces
- 2 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, UEFI BIOS, ACPI 5.0 support, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support
- Sleep / Wake Up
- Wake on LAN (WOL), wake on PME
- Hardware Features
- Jack retasking, ASUS Q-Design, GameFirst, ESD Guards, Q-DIMM, Q-LED, CrashFree BIOS 3, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, Intel Extreme Memory Profile (XMP) support, Intel Turbo Boost Technology 2.0, ASUS DIGI+ VRM, Intel Clear Video HD Technology, Fanless Design Heatsink, USB 3.0 Boost, SupremeFX Shielding technology, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, Disk Unlocker, ASUS Enhanced DRAM Overcurrent Protection, Preboot eXecution Environment (PXE), ASUS Stainless Steel Back I/O, ASUS Fan Xpert 2+, LANGuard, Sonic Radar II, ASUS Gamer's Guardian, AURA RGB Lighting Control
- Included Accessories
- Cable ties, I/O back plate, cable labels, 1 x M.2 screw
- Cables Included
- 2 x Serial ATA cable
- Software Included
- Drivers & Utilities, ASUS AI Charger, ASUS AI Suite III, ASUS EZ Update, Antivirus (OEM version), Media Streamer, HyStream, ASUS RAMCache, ASUS EZ Flash 3
- Plug and Play, ACPI 5.0
- 17 cm
- 17 cm
