Be the best on the battlefield with B150 Pro Gaming/Aura's truly immersive SupremeFX audio and experience sound so alive with realism that it hands you the vital competitive edge needed to win. With near-lossless delivery and exclusive Sonic Radar II technology to pinpoint battlefield enemies before they spot you, SupremeFX sounds stupendous - and puts both your ears and frags in front of everyone else!
Only the quickest shot survive, so B150 Pro Gaming/Aura banishes lag - letting you annihilate your foes as fast as your trigger finger! The engineers pack in only the best networking technology, including tournament-level Intel Gigabit Ethernet and ASUS-exclusive LANGuard and GameFirst technologies to keep your connection fast, so always fire first and watch your enemies fall.
Maxed-out performance means maximum gaming thrills, and with exclusive AI Suite 3's dashboard-style control panel you'll fine-tune almost every aspect of your B150 Pro Gaming/Aura-based system. Get the best balance between performance, cooling, stability, efficiency and aesthetics - all via a simple and intuitive interface.
Flawless audio that makes you part of the game
Be the best on the battlefield with B150 Pro Gaming/Aura's truly immersive SupremeFX audio and experience sound so alive with realism that it hands you the vital competitive edge needed to win. With near-lossless delivery and exclusive Sonic Radar II technology to pinpoint battlefield enemies before they spot you, SupremeFX sounds stupendous - and puts both your ears and frags in front of everyone else! -
Top-speed protected networking
Only the quickest shot survive, so B150 Pro Gaming/Aura banishes lag - letting you annihilate your foes as fast as your trigger finger! The engineers pack in only the best networking technology, including tournament-level Intel Gigabit Ethernet and ASUS-exclusive LANGuard and GameFirst technologies to keep your connection fast, so always fire first and watch your enemies fall. -
Performance level up
Maxed-out performance means maximum gaming thrills, and with exclusive AI Suite 3's dashboard-style control panel you'll fine-tune almost every aspect of your B150 Pro Gaming/Aura-based system. Get the best balance between performance, cooling, stability, efficiency and aesthetics - all via a simple and intuitive interface. -
Gamer's guardian for real-world protection
Protect your back in the game and let B150 Pro Gaming/Aura protect all sides in the real world! Motherboard self-protection with loads of brilliant defenses, including our unique smart DIY features ensures long-term gaming is in your future. -
Built for gaming
B150 Pro Gaming/Aura is built for play, shaped by professional gamers and tested for gaming perfection - strong enough storm through the industry's most punishing labs workouts. The engineer and test for the finest quality, longevity, performance, stability and compatibility. Our world-class engineers are themselves avid gamers, and combine their own passion with the skills and demands of some of the planet's best players to create innovative gaming features everyone will crave. With B150 Pro Gaming/Aura you do more than just play - you'll experience gaming on the edge of reality.
- ASUS B150 PRO GAMING/AURA - motherboard - ATX - LGA1151 Socket - B150
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel B150
- Processor Socket
- 1 x LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7
- Max RAM Size
- 64 GB
- RAM Supported
- 4 DIMM slots - DDR4, non-ECC, unbuffered
- Storage Ports
- 6 x SATA-600, 1 x M.2
- USB / FireWire Ports
- 1 x USB-C + 1 x USB 3.1 + 4 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
- Max Allocated RAM Size
- 1024 MB
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel B150
- Processor Socket
- LGA1151 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR4
- Bus Clock
- 2133 MHz
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
- 1024 MB
Audio
- Audio Codec
- SupremeFX
- High Definition Audio
LAN
- Network Controller
- Intel I219V
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 2 x PCIe 3.0 x1 (auto turn-off if all PCI Express 3.0 x4 slots are occupied) , 1 x PCIe 3.0 x16 (x4 mode) , 2 x PCI
- Storage Interfaces
- SATA-600 / PCIe 3.0 -connectors: 6 x 7pin Serial ATA, 1 x M.2
- 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 4 x USB 3.0 , 1 x USB-C , 1 x PS/2 keyboard / mouse , 1 x VGA , 1 x USB 3.1 , 1 x HDMI , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x PS/2 mouse , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x TOSLINK
- Internal Interfaces
- 4 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header , 1 x serial - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, UEFI BIOS, ACPI 5.0 support, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support
- Sleep / Wake Up
- Wake on LAN (WOL), wake on PME
- Hardware Features
- Jack retasking, ASUS Q-Design, GameFirst, ESD Guards, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, CrashFree BIOS 3, Onboard LED, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, Intel Extreme Memory Profile (XMP) support, Intel Turbo Boost Technology 2.0, ASUS DIGI+ VRM, Intel Clear Video HD Technology, Fanless Design Heatsink, SupremeFX Shielding technology, AMD Quad CrossFireX technology support, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, Disk Unlocker, ASUS Enhanced DRAM Overcurrent Protection, Preboot eXecution Environment (PXE), Clear CMOS Button, ASUS Stainless Steel Back I/O, ASUS Fan Xpert 3, LANGuard, Sonic Radar II, USB 3.1 Boost
- Included Accessories
- Cable ties, I/O back plate, cable labels, 1 x M.2 screw
- Cables Included
- 4 x Serial ATA cable
- Software Included
- ASUS AI Charger+, ASUS AI Suite III, Media Streamer, ASUS RAMCache, ASUS EZ Flash 3
- Plug and Play
- 30.5 cm
- 24.4 cm
Asus B150 PRO GAMING/AURA Intel S1151 B150 DDR4 PCIe M.2 USB3.1
