Asus HD7970-DC2T-3GD5 The Coolest and Quietest Radeon HD7970 "HD7970-DC2T-3GD5" 28NM with fantastic ASUS design Features
The newly arrived ASUS HD7970-DC2T-3GD5 ships with 1000MHz overclocked GPU and 3GB GDDR5. To fully harness the power of 28nm GPUs, HD7970-DC2T-3GD5 comes with ASUS exclusive DirectCU II fansink and six flatten copper heat-pipes directly contacted the GPU. The 20% larger dissipation area, not only makes this card 20% cooler but also leads 14dB quieter operation than reference card. ASUS HD7970-DC2T-3GD5 is also built with DIGI+ VRM and 12-phase Super Alloy Power technology for precise digital delivery and enhanced durability.
In addition, proprietary VGA Hotwire allows users to alter voltages directly on a hardware level, resulting in more precise modification. GPU Tweak utility helps users modify and tune clock speeds, voltages, and fan performance via an intuitive interface. For the ultimate immersive gaming experience, HD7970-DC2T-3GD5 supports dual DVI and four DisplayPort connectors to drive up to six screens with AMD Eyefinity™ 6 - achieving HD/ 4K resolution with no additional adapters. HD7970-DC2T-3GD5, the coolest and quietest HD 7970 graphics card, provides perfect gaming experience!
ASUS Exclusive Innovations
? 1000MHz factory overclocked
? 20% cooler and 14dB quieter performance with ASUS exclusive Direct-CU II thermal solution
? ASUS DIGI+ VRM technology with 12-phase Super Alloy Power for precise digital delivery and enhanced durability
? VGA Hotwire hardware overvolting and GPU Tweak software tuning.
? One card drives up to six screens with AMD Eyefinity™ 6: four DisplayPorts and dual DVIs provided!
Key Selling Points
- 28nm GPU: Less power consumption & more efficient transistor
- PCIE 3.0: Delivers double the bandwidthper lane of PCIe Gen 2 for faster GPU -CPU communication
- Microsoft® DirectX® 11 Support: Bring newlevels of visualrealism to gaming on the PC and gettop-notch performance.
- AMD Eyefinity Technology: Extend the View across 6Displaysto immerse yourself in gameplay and entertainment
- CrossFire: Multi-GPU technology for extreme performance
- AMDD3D™ Technology: Optimize stereoscopic 3D gaming and movie-watching entertainment
- Microsoft® Windows® 7Support: Enable PC users to enjoy an advanced computing experience and to do mor
Key specification
- Graphics Engine AMD Radeon™ HD 7970
- Bus Standard PCI Express® 3.0
- OpenGL OpenGL® 4.2
- Video Memory 3072MB GDDR5
- Engine Clock 1010 MHz overclocked Edition
- Stream Processors 2048
- Memory Clock 5600MHz (1400MHz GDDR5)
- Memory Interface 384 bit
- RAMDAC 400MHz
- DVI Max. Resolution 2560 * 1600
- D-Sub Max. Resolution 2048 * 1536
- DVI Output
- 1x Native single-link DVI-I
- 1x Native Dual-link DVI-D
- HDMI Output 1x Via DVI to HDMI Adapter
- HDCP compliant YES
- DisplayPort 4x Native DisplayPort
- Adapter/Cable Bundled: 1x CrossFire Bridge / 1X Power Cable / 1x DVI to HDMI Adapter
- Software Bundled: ASUS Utilities & Driver / GPU Tweak
- Dimension The card size is 11 x 5.1 x 2.1 inches
28nm GPU
Less power consumption & more efficient transistor. -
PCIe 3.0
Delivers double the bandwidth per lane of PCIe Gen 2 for faster GPU - CPU communication. -
AMD Eyefinity technology
Extends your visual horizon across six displays for engaging gameplay and entertainment. -
AMD HD3D technology
Optimize stereoscopic 3D gaming and movie-watching entertainment. -
DirectX 11 support
Bring new levels of visual realism to gaming on the PC and get top-notch performance. -
AMD CrossFireX technology
Multi-GPU technology for extreme performance. -
Microsoft Windows 7 support
Enable PC users to enjoy an advanced computing experience and to do more with their PC.
- ASUS HD7970-DC2T-3GD5 - graphics card - Radeon HD 7970 - 3 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- AMD Radeon HD 7970
- Memory
- 3 GB GDDR5
- Core Clock
- 1000 MHz
- Effective Memory Clock
- 5.6 GHz
- RAMDAC
- 400 MHz
- Memory Interface
- 384-bit
- Max Resolution
- 2560 x 1600
- Max Resolution Details
- DVI: 2560 x 1600 / VGA: 2048 x 1536
- Max Monitors Supported
- 6
- Interfaces Details
- 4 x DisplayPort , HDMI - with adapter , DVI-I (dual link) , DVI-D (dual link)
- API Supported
- OpenGL 4.2, DirectX 11.1
- 13 cm x 27.9 cm x 5.3 cm
- Microsoft Certification
- Compatible with Windows 7
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1000 MHz
- RAMDAC
- 400 MHz
- Max Resolution
- 2560 x 1600
- 6
- API Supported
- AMD Eyefinity Technology, AMD CrossFireX Technology, Super Alloy Power technology, ASUS DirectCU II Technology, VGA HotWire
- Size
- 3 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 5.6 GHz
- Bus Width
- 384-bit
- Cables Included
- 1 x CrossFire cable , 1 x HDMI-DVI adapter
- Software Included
- Drivers & Utilities, ASUS GPU Tweak
- 13 cm
- 27.9 cm
- 5.3 cm
