EAH6870 DC/2DI2S/1GD5
ASUS HD6870 DirectCU boosts performance with superior metal components and all-copper cooling
- 915MHz Factory Overclocked edition
- Super Alloy Power technology delivers 15% performance increase, 2.5 times longer lifespan and 35°C cooler operation
- 20%* Cooler with exclusive DirectCU thermal solution
- Up to 50%* faster clock speed with exclusive Voltage Tweak
Overclocked!
Factory overclocked to perform at 915MHz, higher than stock performance, resulting in higher frame rates in games.
DirectCU
Precision mounted DirectCU copper heatpipes in direct contact with the GPU for rapid heat dissipation - creating 20%* cooler and quiet performamce in idle.
Super Alloy Power
Super Alloy Power technology for 15% performance increase, 2.5 times longer lifespan and 35°C cooler operation.
Voltage Tweak
Full throttle overclocking with exclusive ASUS Voltage Tweak via Smart Doctor - boosting 50%* more speed, performance and satisfaction!
GPU Guard
Increases the card's strain threshold by 80%-100%, doubling its ability to withstand stress and pressures. GPU Guard prevents cracking and fracturing, even increasing drop and shock damage resistance.
Fuse Protection
Equipped with multiple sets of input fuses on the circuit board to eliminate any chance of excessive or dangerous temperature rises - leading to trouble-free and long-lasting hardware.
Dust-proof Fan
Unique fan design dissipates heat efficiently while extending a graphic card's lifespan by 25%* through increased dust and particle resistance.
EMI Shield
Reduces 66%* of electromagnetic interference both given off and received by the card - resulting in a stable signal, clearer screen display and a safer, healthier computing environment.
- Graphics Engine AMD Radeon HD 6870
- Bus Standard PCI Express 2.1
- Video Memory GDDR5 1GB
- Engine Clock 915 MHz
- Memory Clock 4200 MHz ( 1050 MHz GDDR5 )
- RAMDAC 400 MHz
- Memory Interface 256-bit
- Resolution D-Sub Max Resolution : 2048x1536
- DVI Max Resolution : 2560x1600
- Interface D-Sub Output : Yes x 1 (via DVI to D-Sub adaptor x 1)
- DVI Output : Yes x 1 (DVI-I),Yes x 1 (DVI-D)
- HDMI Output : Yes x 1 (via DVI to HDMI adaptor x 1 )
- Display Port : Yes x 2 (Regular DP)
- HDCP Support : Yes
- Accessories 1 x CrossFire cable, 1 x Power cable, 1 x DVI to D-Sub adaptor, 1 x DVI to HDMI adaptor
- Software ASUS Utilities & Driver
- ASUS Features DirectCU Series
- Dimensions 11 " x 5 " Inch
Super Alloy Power
Super Alloy Power technology for 15% performance increase, 2.5 times longer lifespan and 35°C cooler operation. -
DirectCU
Precision mounted DirectCU copper heatpipes in direct contact with the GPU for rapid heat dissipation - creating 20% cooler and quiet performance in idle. -
Voltage Tweak
Full throttle overclocking with exclusive ASUS Voltage Tweak via Smart Doctor - boosting 50% more speed, performance and satisfaction! -
Dust-proof fan
Unique fan design dissipates heat efficiently while extending a graphic card's lifespan by 25% through increased dust and particle resistance. -
GPU guard
Increase the card's strain threshold by 80%-100%, doubling its ability to withstand stress and pressures. GPU guard prevents cracking and fracturing, even increasing drop and shock damage resistance. -
EMI shield
Reduce 66% of electromagnetic interference both given off and received by the card - resulting in a stable signal, clearer screen display and a safer, healthier computing environment. -
Fuse protection
Equipped with multiple sets of input fuses on the circuit board to eliminate any chance of excessive or dangerous temperature rises - leading to trouble-free and long-lasting hardware. -
ASUS Smart Doctor
Intelligent system monitoring for efficient overclocking with an intuitive slide bar. -
ASUS gamer OSD
Real-time overclocking, benchmarking and video capturing in any PC game! -
Splendid Video Intelligence technology
Optimize colors in various entertainment scenarios with five special modes - standard, game, scenery, night view and theater. -
AMD Eyefinity technology
Unlock the power of GPU's processor cores to accelerate the most demanding system tasks. -
AMD HD3D technology
Optimize stereoscopic 3D gaming and movie-watching entertainment. -
Microsoft DirectX 11 support
Bring new levels of visual realism to gaming on the PC and get top-notch performance -
AMD CrossFireX technology
Get up to 1.8x of a graphics performance boost in dual mode.
- ASUS EAH6870 DC/2DI2S/1GD5 - graphics card - Radeon HD 6870 - 1 GB
- Graphics card
- Bus Type
- PCI Express 2.1 x16
- Graphics Engine
- AMD Radeon HD 6870
- Memory
- 1 GB GDDR5
- Core Clock
- 915 MHz
- Effective Memory Clock
- 4.2 GHz
- RAMDAC
- 400 MHz
- Memory Interface
- 256-bit
- Max Resolution
- 2560 x 1600
- Max Resolution Details
- DVI: 2560 x 1600 / VGA: 2048 x 1536
- Interfaces Details
- DVI-I (dual link) , DVI-D (Single-Link) , 2 x DisplayPort , HDMI - with adapter , VGA - with adapter
- API Supported
- DirectX 11, OpenGL 4.1
- 27.9 cm x 12.7 cm
- Microsoft Certification
- Compatible with Windows 7
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 915 MHz
- RAMDAC
- 400 MHz
- Max Resolution
- 2560 x 1600
- API Supported
- Voltage Tweak Technology, ASUS SmartDoctor, ASUS Splendid Video Intelligence Technology, Dust-proof fansink, ASUS Fuse Protection, ASUS GPU Guard, ASUS GamerOSD, ASUS DirectCU Technology, Asus EMI Shield, AMD Eyefinity Technology, AMD HD3D Technology, AMD CrossFireX Technology, Super Alloy Power technology, HDCP
- Size
- 1 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 4.2 GHz
- Bus Width
- 256-bit
- Cables Included
- 1 x CrossFire cable
- Supported Windows 7 Features
- Windows Media Center
- 27.9 cm
- 12.7 cm
