Taken from the ancient Roman and Greek word for owl, Strix means the keenest hearing and sharpest eyesight. Strix means feeling your environment so that you detect and react to the slightest movement. Strix means survival on the very edge of instinct. Strix is in your blood, as it is in yours.
ASUS STRIX R9 Fury gaming graphics card packed with exclusive ASUS technologies, including DirectCU III with Patented Triple Wing-Blade 0dB Fan Design for maximum air flow with 30% cooler and 3X quieter performance. This card features exclusive ASUS AUTO-EXTREME Technology with Super Alloy Power II for premium quality and best reliability. It also has GPU Tweak II with Xsplit Gamecaster, provides intuitive performance tweaking and lets you stream your gameplay instantly.
DirectCU III with dual 10mm heatpipe
Exclusive DirectCU III cooling technology features two exclusive 10 mm direct-GPU contact heat-pipes that transports 40% more heat away from the GPU and outperform reference designs, achieving up to 30% cooler gaming performance. -
Patented triple wing-blade 0dB fans
DirectCU III features triple 0dB fans engineered with a patented, the wing-blade design that delivers maximum air flow and 105% improvement in static pressure over the heat sink, while operating at 3X quieter volumes than reference cards. The 0dB fans also let you enjoy games like League of Legends and StarCraft in complete silence - because the fan stops completely when the GPU temperature remains below a set level. This makes DirectCU III the coolest and quietest graphics card in the market. -
AUTO-EXTREME technology
All ASUS graphics cards are now produced using AUTO-EXTREME Technology, an industry-first, 100% automated production process that incorporates premium materials to set an another standard of quality. AUTO-EXTREME Technology ensures consistent graphics card quality as well as improved performance and longevity. This manufacturing process is also environmentally friendly, eliminating harsh chemicals and reducing power consumption by 50%. -
12-phase super alloy power II
ASUS engineers have integrated premium alloy components into their graphics card designs to reinforce overall reliability. Super Alloy Power II components greatly enhance efficiency, reduce power loss and achieve thermal levels that are approximately 50% cooler than previous designs. -
GPU tweak II with XSplit gamecaster
Redesigned with an intuitive UI, GPU Tweak II makes overclocking easier and more visual than ever, while still retaining advanced options for seasoned overclockers. With one click, the Gaming Booster function maximizes system performance by removing redundant processes and allocating all available resources automatically. XSplit Gamecaster lets you easily stream or record your gameplay right from a convenient, in-game overlay. -
Gamer style
STRIX graphics cards exceed your performance expectations while looking amazing. Pulsating light effects add cool style to your system. -
Armor protection
An advanced backplate prevents PCB bending over time, and now includes STRIX GPU-Fortifier, which relieves physical stress around the GPU in order to protect it.
- ASUS STRIX-R9FURY-DC3-4G-GAMING - graphics card - Radeon R9 Fury - 4 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- AMD Radeon R9 Fury
- Memory
- 4 GB HBM
- Core Clock
- 1000 MHz
- Boost Clock
- 1020 MHz
- Effective Memory Clock
- 500 MHz
- Memory Interface
- 4096-bit
- Max Resolution
- 4096 x 2160
- Interfaces Details
- DVI-D , HDMI , 3 x DisplayPort
- API Supported
- OpenGL 4.4
- 4 cm x 30 cm x 13.7 cm
- Microsoft Certification
- Compatible with Windows 7
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1000 MHz
- Boost Clock
- 1020 MHz
- Max Resolution
- 4096 x 2160
- API Supported
- OpenGL 4.4
- LED indicator, Triple Fan, Super Alloy Power II technology, AUTO-EXTREME technology, DirectCU III with Triple Wing-Blade 0dB Fan Design, HDCP
- Size
- 4 GB
- Technology
- HBM
- Effective Clock Speed
- 500 MHz
- Bus Width
- 4096-bit
- Additional Requirements
- 2 x 8 pin PCI Express power connector
- 375 Watt
- Included Accessories
- STRIX Laser Sticker
- Software Included
- Display drivers, ASUS GPU Tweak II
- 4 cm
- 30 cm
- 13.7 cm
