Asus AMD Radeon R7 360 OC 2GB DDR5 PCI-E Graphics Card
Quicklinx: BF1NWS00 Mfr#: R7360-OC-2GD5
AMD Radeon™ R7 360
PCI Express 3.0
2GB GDDR5
Stunningly powerful AMD RadeonTM R9 300 Series graphics help keep you in the game with unparalleled gaming experiences.
Life continues thanks to smoother gameplay at higher resolutions with AMD RadeonTM R9 300 graphics. Enjoy 4K gaming like never before. With LiquidVR™ technology, immerse yourself in lifelike experiences that seem every bit as real as the physical world. Play without latency, stuttering, or tearing.1 RadeonTM R9 300 Series graphics are designed for your survival.
  • Dual fan cooling
    Twin optimized fans carefully selected by engineers drive 2X greater airflow while maintaining 3X quieter performance, combining enhanced cooling with a more pleasant gaming and computing environment.
  • AUTO-EXTREME Technology with Super Alloy Power II
    ASUS graphics cards are produced using AUTO-EXTREME technology, an industry-first 100% automated production process, and feature aerospace-grade Super Alloy Power II components that enhance efficiency, reduce power loss, decrease comoponent buzzing under load, and lower thermal tempertures for unsurpassed quality and reliability.
  • Tweak till your heart's content
    Redesigned with an intuitive UI, GPU Tweak II makes overclocking easier and more visual than ever, while still retaining advanced options for seasoned overclockers. With one click, the Gaming Booster function maximizes graphics performance by removing redundant processes and allocating all available resources automatically. XSplit Gamecaster lets you easily stream or record your gameplay right from a convenient, in-game overlay.
  • XSplit Gamecaster: stream and record your gameplay instantly
    Now, you can also launch XSplitGamecaster to bring up the in-game overlay and start streaming or recording your gameplay with the click of a button. You can also try the in-game annotations and video editor features to enhance your game stream experience.
ASUS R7360-OC-2GD5 - graphics card - Radeon R7 360 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon R7 360
2 GB GDDR5
Core Clock
1070 MHz
Stream Processors
768
Effective Memory Clock
6.5 GHz
Memory Interface
128-bit
Interfaces Details
DVI-I (dual link) , DVI-D (dual link) , DisplayPort , HDMI
API Supported
OpenGL 4.4, DirectX 12
3.8 cm x 22 cm x 11.1 cm
Microsoft Certification
Compatible with Windows 7
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon R7 360
Core Clock
1070 MHz
Stream Processors
768
Interfaces Details
API Supported
Dual Slot Fan Cooler, Native HDMI, AMD Eyefinity Technology, Dual Fan Design, AMD CrossFireX Technology, Dust-proof fan, FreeSync Technology, Super Alloy Power II technology, AUTO-EXTREME technology, HDCP
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
6.5 GHz
Bus Width
128-bit
Additional Requirements
6 pin PCI Express power connector
150 Watt
Software Included
Display drivers, ASUS GPU Tweak II, World of Warships invite code
3.8 cm
22 cm
11.1 cm
