Asus AMD Radeon R7 240 730MHz 2GB DDR3 PCI-E 3.0 HDMI Low Profile
Quicklinx: 91VFWS00 Mfr#: R7240-2GD3-L
  • AMD Radeon R7 240
  • High-Definition Multimedia Interface (HDMI)
Great value graphics with superior stability and 3D gaming
  • Premium alloys in power delivery components defeat heat for cards that run 15% faster and last 2.5 times longer than reference.
  • Dust-proof Fan design increases particle resistance and extends card lifespan by up to 25% longer than reference.
  • GPU Tweak helps you modify clock speeds, voltages, fan performance and more, all via an intuitive interface.
  • Low profile graphics cards for HTPC and multimedia PCs support smooth 1280 x 1024 gaming and Blu-ray 3D. Brackets bundled for fast setup!
  • Enhanced durability and cooling
    Exclusively-formulated alloy components boost performance by reducing power loss, enhancing durability, and achieving cooler operation. Choke concrete cores eliminate buzzing sound under full load while capacitors assure a 50,000-hour lifespan: equivalent to 2.5 times longer than traditional capacitors.
  • 25% longer graphics card lifespan
    Unique fan design dissipates heat efficiently while extending a graphic card's lifespan by 25% through increased dust and particle resistance.
  • Perfect for mini-ITX PCs
    ASUS gets graphics card design done right for HTPC and multimedia PC use. Products are powered to easily run current game titles at 1280 x 1024 resolution and play smooth Blu-ray 3D content. Low profile brackets bundled for quick setup!
  • Microsoft DirectX 11.2 API
    Brings new levels of visual realism to gaming on the PC and get top-notch performance.
  • AMD ZeroCore Power technology
    It allows your AMD Radeon graphic to consume virtually no power when in idle state. It even shuts down additional GPUs in AMD CrossFire technology mode to consume less when they're not in use.
ASUS R7240-2GD3-L - graphics card - Radeon R7 240 - 2 GB
Graphics card - low profile
Bus Type
PCI Express 3.0
Graphics Engine
AMD Radeon R7 240
2 GB DDR3
Core Clock
730 MHz
Boost Clock
780 MHz
Effective Memory Clock
1.8 GHz
Memory Interface
128-bit
Max Resolution
1920 x 1200
Interfaces Details
DVI-D , HDMI , VGA
API Supported
DirectX 11.2
2 cm x 15.9 cm x 11.1 cm
Microsoft Certification
Compatible with Windows 7
Bus Type
PCI Express 3.0
Graphics Engine
AMD Radeon R7 240
Core Clock
730 MHz
Boost Clock
780 MHz
Max Resolution
1920 x 1200
Interfaces Details
DVI-D , HDMI , VGA
API Supported
DirectX 11.2
Native HDMI, ASUS Super Hybrid Engine, AMD PowerTune technology, Super Alloy Power technology, Dust-proof fan, AMD App Acceleration, AMD ZeroCore Power technology, HDCP
Size
2 GB
DDR3 SDRAM
Effective Clock Speed
1.8 GHz
Bus Width
128-bit
75 Watt
Software Included
Drivers & Utilities, ASUS GPU Tweak
2 cm
15.9 cm
11.1 cm
