Asus AMD Radeon Fury X Graphics 4GB HBM PCIe3.0 Graphics Card
Quicklinx: BFS1WS00 Mfr#: R9FURYX-4G
  • AMD Radeon R9 Fury X
Like nothing you’ve seen before
The AMD Radeon™ R9 Fury X graphics card is the world’s first total solution GPU with AMD-pioneered High-Bandwidth Memory (HBM) on-chip delivering extreme 4K performance and unbelievably "real" VR experiences.
Don’t just upgrade. Revolutionize with the AMD Radeon™ R9 Fury X graphics card.
AMD High Bandwidth Memory
- High-Bandwidth Memory with more than 3x the bandwidth per watt over GDDR5 along with a 4096-bit memory interface - the highest AMD GPU memory bandwidth ever.
- Sleek industrial styling including GPU Tach activity indicator and LED illumination all in a compact 7.5-inch card that’s all about raw graphics power.
- Powerful performance, bleeding-edge technology, liquid-cooled, whisper-quiet and future-ready for extreme 4K and VR gaming.
Redefine reality with AMD LiquidVR™ technology.
- Liquid-smooth images with high frame rates for a definitive VR experience.
- Get comfortable with low-latency head tracking.
- Designed for plug-and-play headset compatibility.
Enjoy the View in 4K.
- Command the competition at 4K resolution and beyond, fueled by a 4096-bit high-bandwidth memory interface for extreme performance and power efficiency.
- Take advantage of full support for DirectX® 12, Vulkan™, OpenGL® 4.5 and Mantle.
- Experience the smoothest gameplay without frame-tearing or stuttering with an AMD Eyefinity 3x1, using 1440p FreeSync™-enabled monitors for a massive 6K gameplay "surround view" panorama.
Specs
Graphics Engine - AMD Radeon™ R9 FURY X
Bus Standard - PCI Express 3.0
OpenGL 4.4
Video Memory - 4GB HBM
Engine Clock - 1050MHz
Stream Processors - 4096
Memory Clock - 500 MHz
Memory Interface - 4096bit
Digital Max. Resolution - 4096 x 2160
DVI Output - No
HDMI Output - 1 x Native HDMI
HDCP Compliant - Yes
Display Port - 3 x Native Display Port
  • Game faster, quieter, cooler
    ASUS R9 FURY X graphics card is powered by the Radeon R9 Fury X graphics-processing unit (GPU) and bundled with a free 1-year premium license of customized ASUS GPU Tweak II and XSplit Gamecaster for intuitive performance tweaking and online streaming. With 4GB of 4069-bit high-bandwidth memory and Microsoft DirectX 12 technology, the ASUS R9 FURY X is a revolutionized graphics card for pumped gaming performance and extreme reliability.
  • Tweak till your heart's content
    With an intuitive UI, GPU Tweak II makes overclocking easier than ever, and features Game Booster to maximize graphics performance and XSplit Gamecaster to stream or record your gameplay.
  • XSplitGamecaster
    Now, you can also launch XSplitGamecaster to bring up the in-game overlay and start streaming or recording your gameplay with the click of a button. You can also try the in-game annotations and video editor features to enhance your game stream experience.an improved back-assembled design with 1.6mm of key travel and minimal key float for a solid feel and a more comfortable typing experience.
ASUS R9FURYX-4G - graphics card - Radeon R9 Fury X - 4 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
4 GB HBM
Core Clock
1050 MHz
Effective Memory Clock
500 MHz
Memory Interface
4096-bit
Max Resolution
4096 x 2160
Interfaces Details
HDMI , 3 x DisplayPort
API Supported
OpenGL 4.4, DirectX 12
3.9 cm x 19.5 cm x 11.5 cm
Microsoft Certification
Compatible with Windows 7
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1050 MHz
Max Resolution
4096 x 2160
Interfaces Details
API Supported
Native HDMI, AMD Eyefinity Technology, AMD HD3D Technology, AMD CrossFireX Technology, Super Alloy Power technology, ASUS DIGI+ VRM, HDCP
Size
4 GB
HBM
Effective Clock Speed
500 MHz
Bus Width
4096-bit
Software Included
Display drivers, XSplit Gamecaster (1 year Premium licence), ASUS GPU Tweak II
3.9 cm
19.5 cm
11.5 cm
