Asus AMD Radeon 7770 HD 2GB PCI-Express 3.0 HDMI
Quicklinx: 8670WS00 Mfr#: HD7770-2GD5
Form Factor: 3.5 x 1/3H
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 1TB, 1TB
Spin Speed (rpm): 5400rpm
  • High-Definition Multimedia Interface (HDMI)
AMD Radeon HD 7700 series GPU is built to destroy with the industry's 28 nm GPU design. It packed with incredible features, such as PCI Express 3.0, AMD Eyefinity technology. Gaming at resolutions beyond 5760 x 1080 with AMD Eyefinity technology, it is a great graphic for everyone.
  • DirectCU
    DirectCU embeds two flatten copper heat-pipes contact GPU directly for cool operation.
  • AMD HD3D technology
    AMD HD3D technology optimizes stereoscopic 3D gaming and movie-watching entertainment.
  • AMD Eyefinity technology
    AMD Eyefinity technology extends your visual horizon across six displays for engaging gameplay and entertainment.
  • DirectX 11 support
    DirectX 11 support brings new levels of visual realism to gaming on the PC and get top-notch performance.
ASUS HD7770-2GD5 - graphics card - Radeon HD 7770 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon HD 7770
2 GB GDDR5
Core Clock
1020 MHz
Stream Processors
640
Effective Memory Clock
4.6 GHz
RAMDAC
400 MHz
Memory Interface
128-bit
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 2560 x 1600 / VGA: 2048 x 1536
Max Monitors Supported
3
2 x DVI-I (dual link) , DisplayPort , HDMI , VGA - with adapter
API Supported
DirectX 11, OpenGL 4.2
3.6 cm x 21.1 cm x 11.2 cm
Microsoft Certification
Compatible with Windows 7
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon HD 7770
Core Clock
1020 MHz
Stream Processors
640
RAMDAC
400 MHz
Process Technology
28 nm
Max Resolution
2560 x 1600
3
API Supported
AMD Eyefinity Technology, AMD HD3D Technology, Dual Fan Design, AMD CrossFireX Technology, Super Alloy Power technology, HDCP
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
4.6 GHz
Bus Width
128-bit
CrossFire bridge
1 x DVI-VGA adapter
Software Included
Drivers & Utilities, ASUS GPU Tweak
3.6 cm
21.1 cm
11.2 cm
Type: Hard drive
Capacity: 1TB
Capacity: 1TB
Brand: WD
