Asus AMD Performance Bundle (Includes M4A78LT-M Motherboard, AMD Phenom II X2 560 BE & 2GB DDR3 Memory)
Quicklinx: 73GYWS00 Mfr#: ASUSAMD-MID2
  • ATI Radeon 3000
Exclusive Self-Build Special Bundle
Perfect Performance PC!
Take the fear out of Self-Build with this tested AMD Performance Bundle! We test it so you don't have to! Motherboard, CPU and Memory - Boxed & Ready To Rock!
Asus M4A78LT-M AMD Motherboard
This motherboard supports AMD AM3 multi-core processors with unique L3 cache and delivers better overclocking capabilities with less power consumption. It features dual-channel DDR3 memory support and accelerates data transfer rate up to 5200MT/s via HyperTransport 3.0 based system bus. This motherboard also supports AMD CPUs in the 45nm manufacturing process.
The motherboard supports DDR3 memory that features data transfer rates of 1800+(O.C.)/1600(O.C.)/1333/1066 MHz to meet the higher bandwidth requirements of the latest operation system, 3D graphics, multimedia, and Internet applications. The dual-channel DDR3 architecture doubles the bandwidth of your system memory to boost system performance, eliminating bottlenecks with peak bandwidths of up to 25.6Gbps. Furthermore, the supply voltage for the memory is reduced from 1.8 V for DDR2 to just 1.5 V for DDR3. This voltage reduction limits the power consumption and heat generation of DDR3 which makes it an ideal memory solution
AMD Phenom II X2 560 3.3GHz Black Edition Processor (HDZ560WFGMBOX)
AMD Phenom II X2 Black Edition processor combines value and unlocked potential for gamers and tuners on a budget. Users can now experience the power of AMD platform technology, codenamed "Dragon" with dual-core configurations. AMD Black Edition processors help users to take control and unleash the maximum potential of Dragon platform technology's unprecedented performance tuning capabilities. With dual-core processors, AMD provides platform level solutions at multiple price points, each of which exceeds expectations for virtually any user.
Patriot Signature 2GB DDR3 CL9 PC3-10600 1333MHz Memory (PSD32G13332H)
Designed with reliability, performance and value in mind, Patriot Signature DDR3 PC3-10600 (1333MHz) is the perfect memory upgrade solution for desktop and workstation systems. Patriot ensures that every memory module meets and exceeds industry standards.
  • HyperTransport 3.0
    HyperTransport 3.0 technology provides 2.6 times more bandwidth than HyperTransport 1.0, radically improving system efficiency to create a smoother, faster computing environment.
  • Dual-channel DDR3 1800 (O.C.)
  • Hybrid CrossfireX
    ATI Hybrid CrossFireX technology is a unique hybrid multi-GPU technology. It takes your gaming experience to the next level boosting PC performance by enabling the chipset's integrated graphics processor and a discrete GPU to operate simultaneously with combined output for blisteringly-fast frame rates unleashing the graphics performance.
  • HDMI support
    High-Definition Multimedia Interface (HDMI) is a set of digital video standards that delivers multi-channel audio and uncompressed digital video for full HD 1080p visuals through a single cable. Supporting HDCP copy protection such as HD DVD and Blu-ray Discs, HDMI provides you with the highest-quality home theater experience.
  • S/PDIF-out on back I/O port
    This motherboard provides convenient connectivity to external home theater audio systems via coaxial and optical S/PDIF-out jacks. It allows transferring digital audio without converting to analog format and keeps the best signal quality.
  • PCI express architecture
    PCI Express is the latest I/O interconnects technology that will replace the existing PCI. With a bus bandwidth 4 times higher than that of AGP 8X interface, PCI Express x16 bus performs much better in applications such as 3D gaming.
  • Serial ATA 3Gbps
    This motherboard supports next-generation SATA hard drives based on the SATA 3Gbps storage specification. It also supports RAID0, RAID1, RAID 0+1 and JBOD Configurations for SATA hard drives.
  • USB 2.0
    USB 2.0 is the latest connectivity standard for next generation components and peripherals. Backwards compatible with current USB 1.1 peripherals, USB 2.0 delivers transfer speeds up to 40 times faster at 480Mbps, for easy connectivity and ultra-fast data transfers.
  • Gigabit LAN
    This capability ensures rapid transfer of data from WAN to LAN without any added arbitration or latency.
  • AMD Cool 'n' Quiet! technology
    M4A78LT-M supports AMD Cool 'n' Quiet! technology, which monitors system operation and automatically adjusts CPU voltage and frequency for a cool and quiet environment.
  • ASUS Q-Fan
    ASUS Q-Fan technology intelligently adjusts CPU fan speeds according to system loading to ensure quiet, cool and efficient operation.
  • EPU-4 engine
    The ASUS EPU - the world's first power saving engine, has been upgraded to a 4-engine version, which provides total system power savings by detecting current PC loadings and intelligently moderating power in real-time. The EPU automatically provides the most appropriate power usage for the CPU, VGA card, hard drives and CPU cooler fan - helping save power and money.
  • Turbo key
    ASUS turbo key allows the user to turn the PC power button into a physical overclocking button. After the easy setup, turbo key can boost performances without interrupting ongoing work or games - with just one touch!
  • Express Gate
    Express Gate is an ASUS exclusive OS that provides you with quick access to the Internet and key applications before entering Windows.
  • Anti-surge protection
    This special design prevents expensive devices and the motherboard from damage caused by power surges.
  • ASUS Q-Fan
  • CrashFree BIOS 3
    The ASUS CrashFree BIOS 3 allows users to restore corrupted BIOS data from a USB flash disk containing the BIOS file. This utility saves users the cost and hassle of buying a replacement BIOS chip.
  • GreenASUS
    The motherboard and its packaging comply with the European Union's Restriction on the use of Hazardous Substances (RoHS). This is in line with the ASUS vision of creating environment-friendly and recyclable products and packaging to safeguard consumers' health while minimizing the impact on the environment.
ASUS M4A78LT-M - motherboard - micro ATX - Socket AM3 - AMD 760G
Motherboard - micro ATX
Chipset Type
AMD 760G / AMD SB710
Processor Socket
1 x Socket AM3
Compatible Processors
Sempron, Phenom II X3, Athlon II X2, Phenom II X2, Athlon II X4, Athlon II X3, Phenom II X4
Max RAM Size
16 GB
RAM Supported
4 DIMM slots - DDR3, non-ECC, ECC, unbuffered
Storage Ports
1 x ATA, 6 x SATA
USB Ports Configuration
12 x USB
Graphics
ATI Radeon 3000
Max Allocated RAM Size
1 GB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Chipset Type
Max Bus Speed
2600 MHz
Processor Socket
Socket AM3
Max Processors Qty
1
Supported RAM
Max Size
16 GB
DDR3
Bus Clock
1333 MHz, 1066 MHz
Speed
PC3-10600, PC3-8500
Supported RAM Integrity Check
Non-ECC, ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Graphics
Graphics Controller
ATI Radeon 3000
Memory Allocation Technology
Shared Video Memory (UMA)
1 GB
Audio
Audio Codec
VIA VT1708S
High Definition Audio
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin (1.5 V) , 1 x PCIe 2.0 x16 , 1 x PCIe x1 , 2 x PCI
Storage Interfaces
AMD SB710: SATA-300 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / JBOD , AMD SB710: ATA-133 -connectors: 1 x 40pin IDC - 1 devices
1 x DVI-D , 1 x VGA , 1 x PS/2 keyboard , 1 x LAN (Gigabit Ethernet) , 6 x USB 2.0 , 1 x audio line-out - mini-jack , 1 x audio line-out (rear)/line-in - mini-jack , 1 x audio line-out (centre/subwoofer)/microphone - mini-jack , 1 x HDMI , 1 x TOSLINK
Additional Connectors (Optional)
6 x USB 2.0
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, WfM 2.0 support, ASUS MyLogo2, ASUS EZ Flash 2, ACPI 2.0a support, SMBIOS 2.5 support
Manual Settings
CPU frequency, memory voltage
Hardware Features
ASUS Q-Fan, C.P.R. (CPU Parameter Recall), AMD Cool 'n' Quiet Technology, jack retasking, ASUS Anti-Surge Protection, ASUS Turbo Key, CrashFree BIOS 3, ASUS AI NET2, ASUS Stepless Frequency Selection (SFS), audio jack detect technology, HDCP compliant, ASUS Express Gate, ASUS EPU-4 Engine, AMD Hybrid CrossFireX technology support
2 x Serial ATA cable , 1 x IDE cable
Software Included
Drivers & Utilities, ASUS Live Update, ASUS PC Probe 2, ASUS AI Suite
Plug and Play, RoHS, ACPI 2.0a
24.4 cm
24.4 cm
