Asus A55BM-K AMD A55 FM2+ mATX
Quicklinx: 9C0TWS00 Mfr#: A55BM-K
Media-renowned UEFI BIOS from ASUS provides the smoothest mouse-controlled graphical BIOS, and features more intuitive functions to quickly take you to favorite BIOS pages and frequently-accessed settings through custom shortcuts. You can even write quick notes in-BIOS for future reference, view an activity log of setting changes and modifications, and rename SATA ports.
AMD Radeon Dual Graphics is an exclusive technology available to AMD platforms. It allows AMD APUs and selected AMD Radeon HD 6000 series graphics cards to work together, delivering an unrivaled 3D gaming graphics quality and performance. By combining both the discrete and integrated graphics processors, gamers can now enjoy faster and smoother frame rates on any latest gaming titles.
  • Exclusive EZ mode adds useful info to become even easier
  • Real-time network bandwidth management
    One click to prioritize network traffic for applications you're currently using or set up favorite profiles to run at specific times. Avoid network congestion, speed up downloading, and make sure online gaming runs optimized, all through an intuitive user interface.
  • Effortless PCI Express component removal
    Press the Q-Slot clip lightly, and graphics cards just pop out. The large winged clip is easy to reach so you don't have to struggle with installing or removing even the biggest graphics cards.
  • Precise power control and long-lasting stability
    Voltage regulator modules (VRMs) are among the most essential motherboard components. A good VRM intelligently delivers APU power based on actual needs at any given time. ASUS was first with digital power design featuring faster sensing and response to deliver precise APU power on demand. This great accuracy reduces energy waste and of course improves system stability thanks to more consistent delivery.
  • AMD Dual Graphics technology
ASUS A55BM-K - motherboard - micro ATX - Socket FM2+ - AMD A55
Motherboard - micro ATX
Chipset Type
AMD A55
Processor Socket
1 x Socket FM2+
Compatible Processors
Athlon, A series (supports CPUs with up to 4 cores)
Max RAM Size
32 GB
RAM Supported
2 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
4 x SATA-300 (RAID)
USB / FireWire Ports
4 x USB 2.0 + (4 x USB 2.0 via headers)
Max Allocated RAM Size
2 GB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Chipset Type
AMD A55
Processor Socket
Socket FM2+
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1866 MHz, 2133 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, AMD Memory Profile (AMP)
Graphics
2 GB
Audio
Audio Codec
Realtek ALC887-VD
High Definition Audio
LAN
Network Controller
Realtek RTL8111G
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x PCIe 2.0 x1 , 1 x PCI , 1 x PCIe 3.0 x16 (FM2+ processor must be installed) , 1 x CPU , 2 x DIMM 240-pin
Storage Interfaces
SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / JBOD
4 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x DVI , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
4 x USB 2.0 - header , 1 x audio - header , 1 x serial - header , 1 x SPDIF out - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS MyLogo2, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, UEFI BIOS, SMBIOS 2.7 support, ACPI 4.0a support
Hardware Features
Jack retasking, ASUS Anti-Surge Protection, ASUS Q-Design, 3+1 Phase Power Design, ASUS EZ DIY, Q-Slot, CrashFree BIOS 3, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Fan Xpert, ASUS DIGI+ VRM, Fanless Design Heatsink, AMD Radeon Dual Graphics, ASUS Network iControl, Disk Unlocker, ASUS Boot Setting
I/O back plate
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS MyLogo2, ASUS EZ Flash 2, ASUS AI Charger, ASUS Update, ASUS AI Suite III
Plug and Play, ErP Ready, ACPI 4.0a
22.6 cm
18.3 cm
