The ASUS VN series features compact dimensions- this 27" display has a super narrow bezel of just 0.8 cm, bringing a broader and better vision without compromising on style and comfort. Its pedestal boasts a sleek concentric circle design and the rear bezel comes with a textured finish that is scratch-proof. VN279Q leads you to enter a big and spectacular world of colors with Full HD 1080p (1920 x 1080) support and rich connectivity including DisplayPort, HDMI/MHL and D-sub inputs.
Experience a multi-screen solution with a super narrow frame
The ASUS VN series features compact dimensions - this 27" display has a super narrow bezel of just 0.8 cm, bringing a broader and better vision without compromising on style and comfort. Its pedestal boasts a sleek concentric circle design and the rear bezel comes with a textured finish that is scratch-proof. -
Full HD with DisplayPort and HDMI/MHL
VN279Q leads you to enter a big and spectacular world of colors with Full HD 1080p (1920 x 1080) support and rich connectivity including DisplayPort, HDMI/MHL and D-sub inputs. -
178-degree ultra wide viewing angle
VN279Q adopts 178-degree/178-degree ultra wide viewing angle AMVA+ panel that eliminates color shift on your screen no matter where and how you look at it. -
Splendid Video Intelligence technology
The exclusive Splendid Video Intelligence technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. -
VividPixel technology for best picture quality
ASUS VividPixel technology helps enhance image outlines and reduce noise bars for crystal-clear and detail-oriented viewing. -
MHL (Mobile High-Definition Link) for enhanced viewing from mobile to monitor
Mobile High-Definition Link (MHL) technology allows users to experience any MHL supported mobile devices on the big screen while simultaneously charging the devices. -
Smart contrast ratio for lifelike visuals
With 100,000,000:1 ASUS Smart Contrast Ratio (ASCR) and 300 cd/m2 brightness, the VN279Q enhances display contrast and sharpness by adjusting backlight luminance to achieve the deepest black tones and brightest whites, resulting in extra-clear visuals that truly come to life. -
ASUS exclusive QuickFit virtual scale
ASUS includes its exclusive QuickFit virtual scale feature with the VN279Q, allowing you to preview photos and documents on-screen in their actual size prior to printing. It can be activated via a monitor hotkey, and serves as a highly useful guide to accurately view and edit photos in their native size. -
Extensive connectivity and built-in stereo speakers for multimedia enjoyment
VN279Q comes with rich connectivity including DispalyPort. HDMI and D-sub so that users could easily connect it to Full HD Blu-ray Disc players and myriad HD playback devices like DVD players and set-top boxes for limitless entertainment and multimedia enjoyment with the built-in stereo speakers.
- ASUS VN279Q - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A
- Energy Consumption per Year
- 35.2 kWh
- Power Consumption (On mode)
- 24.1 W
- Panel Type
- A-MVA+
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 300 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours (8-bit)
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, VGA, DisplayPort
- Speakers
- Integrated
- Tilt
- Black
- 61.92 cm x 20.98 cm x 44.04 cm
- 4.8 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, TUV GS, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, ISO 9241-307, WEEE, PSE Mark, J-MOSS, UkrSEPRO, ERP, EAC, CEL level 1
- Display Type
- Energy Class
- Class A
- 35.2 kWh
- Diagonal Size
- 27"
- Panel Type
- A-MVA+
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 31.5 - 67.5 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, contrast, input select, colour temperature
- HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, Mobile High-Definition Link (MHL), ASUS GamePlus, ASUS VividPixel Technology, super narrow frame, 72% NTSC colour gamut
- Black
- 61.92 cm x 20.98 cm x 44.04 cm - with stand
- 4.8 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- Audio line-in , Headphones , HDMI , VGA , DisplayPort
Mechanical
- Tilt
- Tilt Angle
- -5/+22
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x audio cable
- Security Slot Type
- Kensington security slot
- 24.1 W
- Power Consumption (Typical)
- 35 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 61.92 cm - depth: 20.98 cm - height: 44.04 cm - weight: 4.8 kg , Without stand - width: 61.92 cm - depth: 4.83 cm - height: 36.24 cm
- Shipping Width
- 70.6 cm
- Shipping Depth
- 18.8 cm
- Shipping Height
- 53.6 cm
- Shipping Weight
- 7.5 kg
Sustainability Information
- ENERGY STAR Certified
