ASUS BE24DQLB is a 23.8-inch Full HD monitor that features an integrated Full HD (2MP) webcam, microphone array and stereo speakers for video conferencing and live-streaming. With Full HD resolution and an IPS panel for wide-angle viewing, it delivers incredibly sharp imagery and stunning video playback. Its ergonomic design with tilt, swivel, pivot and height adjustments provides a comfortable viewing experience, and compatibility with a standard 100 x 100mm VESA mount allows flexible wall mounting or installation on a display arm.
Lifelike imagery and 178° viewing angles
BE24DQLB offers Full HD resolution to deliver stunning clarity. The IPS panel provides 178° viewing angles, both horizontally and vertically, so you can enjoy its beautiful visuals from almost any direction. -
Easy video streaming with integrated Full HD webcam
With a built-in 2MP Full HD webcam BE24DQLB is ready-made for web video-conferencing and live-streaming. The webcam's adjustable eye is easily rotated through 315°, and also offers 10° tilt in either direction - so it can capture the view you need. Built-in stereo speakers provide loud and clear audio through the monitor, and the webcam even has a sliding shutter to ensure total privacy when not in use. -
Array mic that's perfect for Cortana and conferencing
BE24DQLB's beam-forming microphone array separates speech from background noise, so it's perfect for use with Cortana, the Windows 10 smart assistant. Intelligent echo-cancellation technology further enhances speech clarity, ensuring Cortana won't miss your commands. Physical buttons on the bezel for volume and mute make it easy to control these key features during video conferences. -
Loaded with the latest connectivity
BE24DQLB features a host of connectivity options that include HDMI, DisplayPort, DVI-D, D-sub and two USB 3.0 ports, so hooks up easily to a wide variety of PCs, laptops, consoles, media boxes, keyboard and mice. It also has pass-through ports for the line-in and headphone jack inputs, putting the audio connections conveniently right in front of you. -
Versatile, ergonomic stand for custom comfort
Because its ergonomic stand offers tilt, swivel, pivot, and height adjustments, BE24DQLB provides a superb range of viewing options for increased productivity and comfort. The screen can also be rotated vertically through 90° for use in Portrait mode, which is a great benefit when working with long documents, writing code or browsing lengthy websites. -
Space-saving design for a clutter-free desktop
BE24DQLB is VESA-mountable, so it's easy to hang it on a wall or post. It also includes the ASUS-designed MKT01 mounting kit which allows you to attach a mini PC to the rear of the display to reduce unnecessary clutter in your workspace. -
ASUS blue light filter
Exclusive ASUS blue light filter protects you from harmful blue light. It offers four blue-light filter settings that are easily accessed through the onscreen display menu via the hotkey. -
ASUS flicker-free technology
It's time to say goodbye to those tired, strained eyes. Flicker-Free technology helps reduce onscreen flicker, giving you a more comfortable, movie-marathon-ready environment. It is designed to minimize eyestrain, headaches and eye fatigue when you spend long, countless hours in front of the display. -
Splendid Video Intelligence technology
BE24DQLB features ASUS Splendid technology that optimizes videos and images by enhancing color brightness, contrast and sharpness. It features a wide variety of modes - including Reading, Darkroom, Scenery, Standard, Theater, sRGB, Game and Night View. -
ASUS MultiFrame management software
ASUS MultiFrame keeps your desktop neat and organized, helping you manage multiple windows simultaneously.
- ASUS BE24DQLB - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/405435
- Energy Class
- Class F
- Energy Consumption per Year
- 28 kWh
- Power Consumption (On mode)
- 21.7 W
- Microphone, 2.0 megapixel camera, USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 100000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 56.861 cm x 22.635 cm x 39.908 cm
- 6.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, ISO 9241-307, KCC, WEEE, PSE Mark, MEPS, J-MOSS, ErP Ready, E-Standby, UkrSEPRO, KC, RCM, TUV Rheinland Low Blue Light Certification, CU, TUV Rheinland Flicker Free Certification
- Display Type
- Energy Class
- Class F
- 28 kWh
- Diagonal Size
- 23.8"
- Built-in Devices
- 2.0 megapixel camera, USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- Vertical Refresh Rate
- 49 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, Low Blue Light Mode, Flicker Free technology, ASUS EyeCare Technology, Colour Temperature Selection, Quick Release Stand Design, 72% NTSC colour gamut
- Black
- 56.861 cm x 22.635 cm x 39.908 cm - with stand
- 6.7 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
Input
- Microphone
- Audio line-in , Headphones , DisplayPort , VGA , DVI-D , HDMI , USB 3.0 upstream , 2 x USB 3.0 downstream
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 180
- Rotation Angle
- 180
- Height Adjustment
- 145 mm
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- MiniPC kit
- Cables Included
- 1 x VGA cable , 1 x audio cable , 1 x DisplayPort cable , 1 x USB cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 21.7 W
- Power Consumption SDR (On mode)
- 21.7 kWh/1000h
- Power Consumption (Typical)
- 19 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0 Watt
- Dimensions & Weight Details
- With stand - width: 56.861 cm - depth: 22.635 cm - height: 39.908 cm - weight: 6.7 kg , Without stand - width: 56.861 cm - depth: 5.62 cm - height: 38.649 cm - weight: 3.91 kg
- Shipping Width
- 67.6 cm
- Shipping Depth
- 20.2 cm
- Shipping Height
- 45.8 cm
- Shipping Weight
- 9.1 kg
Sustainability Information
- ENERGY STAR Certified
