Armor Your VR Machine
Prepare yourself well to enjoy the impressive world of Virtual Reality. Before that, you have to make sure everything is qualified, including hardware, software and drivers. Motherboard is the key to connect every critical components and ASRock’s VR Ready motherboards are definitely the one you’re looking for. The premium qualify is assured by rigorous testing during development. The sturdy components and rock-slid performance makes you completely immersive in the VR scenario. Users can be assured to experience VR enjoyments without any compatibility problems.
Ultra M.2 32 Gb/s (PCIe Gen3 x4 & SATA3)
The PCIe Gen3 x4 Ultra M.2 interface pushes data transfer speeds up to 32Gb/s. In addition, it also supports SATA3 6Gb/s M.2 modules, and is compatible with ASRock’s U.2 Kit for installing some of the world’s fastest U.2 PCIe Gen3 x4 SSDs.
Dual Intel® LAN
Users are able to connect two LAN cables to this motherboard's rear I/O. Dual LAN with Teaming function enabled on this motherboard allows two single connections to act as one single connection for twice the transmission bandwidth, making data transmission more effective. (Teaming is not supported with Windows® 10.)
Intel® Optane™ Memory Ready
Supports Intel® Optane™ memory technology and Intel® Optane™ storage technology that redeflnes a new standard of high performance and responsiveness.
Dual Band 802.11ac WiFi
No one has time for weak WiFi signals and sluggish internet! That's why this motherboard comes with a 802.11ac WiFi (2.4G / 5G WiFi) module which supports wireless networks and Bluetooth v4.0.
Premium Power Choke
Compared to traditional chokes, ASRock’s premium power chokes effectively make the saturation current up to three times better, thus providing enhanced and improved Vcore voltage to the motherboard.
Dual-Stack MOSFET (DSM)
Dual-Stack MOSFET (DSM) is another innovative MOSFETs design by ASRock. The silicon die area is increased by stacking two dies into one MOSFET. The larger the die area, the lower Rds(on). Compared to traditional discrete MOSFET, DSM with larger die area provides extreme lower Rds(on) 1.2 mO, so the power supply for the CPU Vcore is more efficient.
Armor your VR machine
Prepare yourself well to enjoy the impressive world of Virtual Reality. Before that, you have to make sure everything is qualified, including hardware, software and drivers. Motherboard is the key to connect every critical components and ASRock's VR Ready motherboards are definitely the one you're looking for. The premium qualify is assured by rigorous testing during development. The sturdy components and rock-slid performance makes you completely immersive in the VR scenario. Users can be assured to experience VR enjoyments without any compatibility problems. -
Dual Band 802.11ac Wi-Fi
No one has time for weak Wi-Fi signals and sluggish Internet! That's why this motherboard comes with a 802.11ac Wi-Fi module which supports wireless networks and Bluetooth v4.0. -
Premium power choke
Compared to traditional chokes, ASRock's premium power chokes effectively make the saturation current up to three times better, thus providing enhanced and improved Vcore voltage to the motherboard. -
Dual-Stack MOSFET (DSM) is another innovative MOSFETs design by ASRock. The silicon die area is increased by stacking two dies into one MOSFET. The larger the die area, the lower Rds (on). Compared to traditional discrete MOSFET, DSM with larger die area provides extreme lower Rds(on) 1.2 mO, so the power supply for the CPU Vcore is more efficient. -
Nichicon 12K black caps
A combination of 820uF and 100uF capacitors. Together these capacitors provide clearer, efficient and more responsive CPU Vcore power, and overclockers may achieve higher scores. -
Sapphire Black PCB
Pure black PCB appearance. The Sapphire Black PCB represents rock-solid quality and gives the motherboard a more mysterious touch. -
High density glass Fabric PCB
High density glass Fabric PCB design that reduces the gaps between the PCB layers to protect the motherboard against electrical shorts caused by humidity. -
Triple monitor
Graphics, graphics and even more graphics! You've demanded for more eye candy, so this motherboard supports Triple Monitor. You may choose up to three display interfaces from the rear i/o to connect monitors and use them simultaneously without installing another graphics card.
- ASRock Z270M-ITX/AC - motherboard - mini ITX - LGA1151 Socket - Z270
- Product Type
- Motherboard - mini ITX
- Chipset Type
- Intel Z270
- Processor Socket
- 1 x LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th and 7th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
- Max RAM Size
- 32 GB
- RAM Supported
- 2 DIMM slots - DDR4, non-ECC, ECC (operate in non-ECC mode), unbuffered
- Storage Ports
- 6 x SATA-600 (RAID), 1 x Ultra M.2
- USB / FireWire Ports
- 6 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 2 x USB 2.0 via headers)
- Max Allocated RAM Size
- 1024 MB
- Audio
- HD Audio (8-channel)
- LAN
- Bluetooth, 2 x Gigabit Ethernet, 802.11a/b/g/n/ac
- Product Type
- Chipset Type
- Intel Z270
- Processor Socket
- LGA1151 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR4
- Bus Clock
- 2400 MHz, 2133 MHz, 2800 MHz (O.C.), 2933 MHz (O.C.), 3200 MHz (O.C.), 3733 MHz (O.C.), 3600 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC, ECC (operate in non-ECC mode)
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP) 2.0, supported ECC modules operate in non-ECC mode
Graphics
- 1024 MB
Audio
- Audio Codec
- Realtek ALC892
- High Definition Audio, Premium Blu-ray audio support
LAN
- Network Controller
- Intel I219V / I211V
- Network Interfaces
- Expansion Slots
- 1 x CPU , 2 x DIMM 288-pin , 1 x PCIe 3.0 x16 (x16 mode) , 1 x M.2 socket
- Storage Interfaces
- SATA-600 -connectors: 6 x 7pin Serial ATA, 1 x Ultra M.2 - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
- RAID Features
- Intel Rapid Storage Technology
- 1 x PS/2 keyboard / mouse , 6 x USB 3.0 , 1 x DVI-D , 1 x HDMI , 2 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x DisplayPort , 2 x USB 2.0
- Internal Interfaces
- 1 x USB 3.0 - header , 1 x USB 2.0 - header , 1 x audio - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- Multilingual BIOS, UEFI BIOS, SMBIOS 2.7 support, ACPI 6.0 support
- Manual Settings
- Processor core voltage, memory voltage
- Hardware Monitoring
- CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage
- Sleep / Wake Up
- Wake on LAN (WOL)
- Hardware Features
- ASRock Instant Flash, Intel Extreme Memory Profile (XMP) support, 15µ Gold Contact, ASRock APP Charger, 6 Phase Power Design, Intel Turbo Boost Technology 2.0, Intel Clear Video HD Technology, ASRock XFast LAN, ASRock XFast RAM, ASRock Crashless BIOS, ASRock Internet Flash, Digi Power Design, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, Dual-Stack MOSFET (DSM), ASRock Fast Boot, ASRock Restart to UEFI, ASRock UEFI System Browser, Energy Efficient Ethernet 802.3az, Preboot eXecution Environment (PXE), ASRock UEFI Tech Service, ASRock Easy Driver Installer, ASRock USB Key, Triple Monitor, Supports Intel K-Series unlocked CPU, ASRock BCLK, ASRock A-Tuning, ASRock Full Spike Protection, ASRock APP Shop, ASRock Super Alloy, High Density Glass Fabric PCB, ASRock Full HD UEFI, ASRock My Favorites in UEFI, ASRock Easy RAID Installer, Sapphire Black PCB, Nichicon Fine Gold Series Audio Capacitors, ASRock Live Update, ASRock EZ Mode
- Included Accessories
- I/O back plate, 1 x M.2 screw, 2 x ASRock WiFi 2.4/5GHz Antennas
- Software Included
- Drivers & Utilities, Antivirus (Trial version), Google Chrome Browser, Google ChromeToolbar
- BSMI, WHQL, FCC, EuP Ready, ErP Ready, RCM
- 17 cm
- 17 cm
ASRock Z270M-ITX/ac LGA1151 Intel Z270 DDR4 mITX
