ASRock Z270 Taichi LGA1151 Intel Z270 DDR4 ATX
Quicklinx: CLLSWS00 Mfr#: Z270 Taichi
  • Bluetooth 4.0
  • IEEE 802.11n
Armor Your VR Machine
Prepare yourself well to enjoy the impressive world of Virtual Reality. Before that, you have to make sure everything is qualified, including hardware, software and drivers. Motherboard is the key to connect every critical components and ASRock’s VR Ready motherboards are definitely the one you’re looking for. The premium qualify is assured by rigorous testing during development. The sturdy components and rock-slid performance makes you completely immersive in the VR scenario. Users can be assured to experience VR enjoyments without any compatibility problems.
AURA RGB LED
Build your own colorful lighting system! AURA RGB LED and header allows users to connect LED strip and create their unique PC style easily.
Dual Band 802.11ac WiFi
No one has time for weak WiFi signals and sluggish internet! That's why this motherboard comes with a 802.11ac WiFi (2.4G / 5G WiFi) module which supports wireless networks and Bluetooth v4.0.
Triple Ultra M.2
Triple of the world’s fastest PCIe Gen3 x4 Ultra M.2 slots that deliver up to 32Gb/s transfer speed, it also supports SATA3 6Gb/s M.2 modules.
Purity Sound 4
It's time to enjoy the most purified audio performance with ultra high definition. Purity Sound4 is a combination of several hardware, software audio solutions. 7.1 CH HD audio with the latest Realtek ALC1220 audio codec, individual PCB layers for R/L audio channel, 120dB SNR DAC and other technologies to deliver the crispest sound effects.
3 PCI-E Steel Slots
Adopts three PCIe Steel Slots, which are built with more solder points on the PCB for better performance and preventing any signal interference with graphics cards. Allows your graphics cards with enhanced signals and to be well-installed in the PCIe slots.
Dual USB 3.1 (Type-A + Type-C)
This motherboard has a pair of onboard Type-A and Type-C USB 3.1 ports built on the rear i/o for supporting next generation USB 3.1 devices and to deliver up to 10 Gbps data transfer rates.
  • Advanced memory ready
    Supports Intel Optane memory technology and Intel Optane storage technology, that redefines a standard of high performance and responsiveness.
  • User-friendly UEFI and EZ mode
    Advanced mode provides a more comprehensive environment, that is designed for overclockers and power users, who want maximum control over their PC's hardware. EZ mode is a dashboard, which contains multiple readings of the system's current status. You can check the crucial information of your system, such as CPU speed, DRAM frequency, SATA information, fan speed, etc.
  • Water pump header
    This is not only a standard CPU fan header, but also supports water pumps! This header provides a maximum power for supporting the popular water pumps. User also can adjust the voltage of water pump to get higher cooling performance with lower noise.
  • Dual USB 3.1 (Type A + Type C)
    This motherboard has a pair of onboard Type A and Type C USB 3.1 ports built on the rear I/O for supporting USB 3.1 devices and to deliver high data transfer rates.
  • Dual LAN
    Users are able to connect two LAN cables to this motherboard's rear I/O. Dual LAN with teaming function enabled on this motherboard allows two single connections to act as one single connection for twice the transmission bandwidth, making data transmission more effective.
ASRock Z270 Taichi - motherboard - ATX - LGA1151 Socket - Z270
Motherboard - ATX
Chipset Type
Intel Z270
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th and 7th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, non-ECC, ECC (operate in non-ECC mode), unbuffered
Storage Ports
6 x SATA-600 (RAID), 4 x SATA-600, 2 x SATA Express port, 3 x Ultra M.2
USB / FireWire Ports
1 x USB-C + 1 x USB 3.1 + 4 x USB 3.0 + (4 x USB 3.0 + 6 x USB 2.0 via headers)
Max Allocated RAM Size
1024 MB
Audio
HD Audio (8-channel)
LAN
Bluetooth, 2 x Gigabit Ethernet, 802.11a/b/g/n/ac
Motherboard - ATX
Chipset Type
Intel Z270
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2400 MHz, 2133 MHz, 2800 MHz (O.C.), 2933 MHz (O.C.), 3200 MHz (O.C.), 3733 MHz (O.C.), 3600 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC, ECC (operate in non-ECC mode)
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP) 2.0, supported ECC modules operate in non-ECC mode
Graphics
1024 MB
Audio
Audio Codec
Realtek ALC1220
DTS Connect, High Definition Audio, Premium Blu-ray audio support, Purity Sound 4
LAN
Network Controller
Intel I219V / I211-AT
Network Interfaces
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 4 x PCIe 3.0 x16 , 1 x PCIe 3.0 x1 , 1 x M.2 socket (Key E)
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices
RAID Features
Intel Rapid Storage Technology
1 x PS/2 keyboard / mouse , 1 x SPDIF out , 1 x HDMI , 1 x DisplayPort , 2 x LAN (Gigabit Ethernet) , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x USB 3.1 , 1 x USB-C , 4 x USB 3.0 , 1 x audio line-in - mini-jack , 1 x audio line-out (front surround) - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
2 x USB 3.0 - header , 3 x USB 2.0 - header , 1 x audio - header , 1 x USB 3.0 , 1 x Thunderbolt
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
UEFI BIOS, SMBIOS 2.7 support, ACPI 6.0 support
Manual Settings
Processor core voltage, memory voltage
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage, power supply fan tachometer
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
NVIDIA SLI Technology Support, 12 Phase Power Design, ASRock Instant Flash, HDCP compliant, NVIDIA Quad SLI Technology Support, 15µ Gold Contact, ASRock APP Charger, Intel Turbo Boost Technology 2.0, Intel Clear Video HD Technology, Intel Smart Response Technology, ASRock XFast LAN, Dual LAN Teaming, ASRock Crashless BIOS, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, AMD 3-way CrossFireX technology support, ASRock Internet Flash, Digi Power Design, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, ESD Protection, Dual-Stack MOSFET (DSM), ASRock UEFI System Browser, Energy Efficient Ethernet 802.3az, Preboot eXecution Environment (PXE), ASRock UEFI Tech Service, 4K resolution support, Supports Intel K-Series unlocked CPU, ASRock BCLK, Direct Drive Technology, ASRock A-Tuning, ASRock Full Spike Protection, ASRock APP Shop, ASRock Super Alloy, High Density Glass Fabric PCB, ASRock Full HD UEFI, ASRock My Favorites in UEFI, ASRock Easy RAID Installer, XXL Aluminum Alloy Heatsink, Nichicon Fine Gold Series Audio Capacitors, I/O Armor, ASRock Live Update, ASRock EZ Mode, AURA RGB Lighting Control, ASRock Ultra M.2, ASRock Hyper BCLK Engine II, Premium Memory Alloy Choke, Nichicon 12K Black Caps, Matte Black PCB, ASRock Steel Slots, TI NE5532 Premium Headset Amplifier, Premium 60A Power Choke, 120dB SNR DAC with Differential Amplifier, Pure Power-In, PCB Isolate Shielding, ASRock USB 3.1, Combo Caps
I/O back plate, ASRock SLI_Bridge_2S Card, 2 x ASRock WiFi 2.4/5GHz Antennas, 3 x M.2 screws, ASRock SLI_HB_Bridge_2S Card
4 x Serial ATA cable
Software Included
Drivers & Utilities, ASRock A-Tuning, Antivirus (Trial version), Google Chrome Browser, Google ChromeToolbar
WHQL, FCC, EuP Ready, ErP Ready
30.5 cm
24.4 cm
