The extra large aluminum alloy heatsinks take away heat dramatically. As the MOSFETs and chipsets areas are well covered by these heatsinks to protect them from overheating, MOSFET and chipsets can perform with lower temperature, and your motherboard and system will be more stable and reliable. Specially designed for memory power delivery, the alloy chokes feature a highly magnetic and heat resistant design, thus delivering more stable and reliable power to the motherboard.
ASRock does not overlook any details, even those tiny ones. With PCB appearance, the Sapphire PCB represents rock-solid quality and gives the motherboard a more mysterious touch.
XXL aluminum alloy heatsink design
The extra large aluminum alloy heatsinks take away heat dramatically. As the MOSFETs and chipsets areas are well covered by these heatsinks to protect them from overheating, MOSFET and chipsets can perform with lower temperature, and your motherboard and system will be more stable and reliable. -
Premium memory alloy choke
Specially designed for memory power delivery, the alloy chokes feature a highly magnetic and heat resistant design, thus delivering more stable and reliable power to the motherboard. -
Sapphire PCB
ASRock does not overlook any details, even those tiny ones. With PCB appearance, the Sapphire PCB represents rock-solid quality and gives the motherboard a more mysterious touch. -
Power phase design
Designed with a power phase design, this motherboard features sturdy components and completely smooth power delivery to the CPU. Plus, it offers unmatched overclocking capabilities and enhanced performance with the lowest temperature for advanced gamers as well. -
More precise, more efficient
Unlike traditional motherboards that use analog power, this motherboard uses a next generation digital PWM (Pulse-Width Modulation) design, which provides CPU Vcore voltage more efficiently and smoothly, so that the stability and lifespan of the motherboard is greatly enhanced. -
HDD Saver Technology
There's a dedicated HDD Saver Connector placed near the SATA ports. By connecting it to the HDDs, you can shut down or turn on the HDDs via software when needed. HDD Saver Technology secures more privacy, saves more energy, and extends HDD life. -
Personal Cloud for everyone
Cloud service should be simple and personal. Don't take time to upload the files to the public cloud again. Stop spending money on setting up another NAS device you don't know. Orbweb ME's file browser is your solution to zero adaption, managing your folders and files in the cloud. Accessing and exchanging files instantly among all of your PC and storages. All your folders and files are sitting just where you know they are. -
Media library and streaming
Orbweb Personal's media library takes care of your media content. Organize all your photos, videos and music across your PCs and online storages. Diverse, intuitive and smart sorting help finding desired movies in few clicks. Progressive streaming lets you enjoy your music collection almost no download time. Web browser based and mobile app portal keep you connected in any device any time.
- ASRock X99M Extreme4 - motherboard - micro ATX - LGA2011-v3 Socket - X99
- Product Type
- Motherboard - micro ATX
- Chipset Type
- Intel X99 Express
- Processor Socket
- 1 x LGA2011-v3 Socket
- Compatible Processors
- Xeon, Core i7
- Max RAM Size
- 64 GB
- RAM Supported
- 4 DIMM slots - DDR4, non-ECC, ECC, registered, unbuffered
- Storage Ports
- 6 x SATA-600 (RAID), 4 x SATA-600, 1 x eSATA-600, 1 x Ultra M.2
- USB / FireWire Ports
- 4 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Chipset Type
- Intel X99 Express
- Processor Socket
- LGA2011-v3 Socket
- Max Processors Qty
- 1
- Xeon, Core i7
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR4
- Bus Clock
- 1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz, 2133 MHz, 2800 MHz (O.C.), 2933 MHz (O.C.), 2400 MHz (O.C.), 3000 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC, ECC
- Registered or Buffered
- Registered, unbuffered
- Intel Extreme Memory Profiles (XMP), quad channel memory architecture
Audio
- Audio Codec
- Realtek ALC1150
- DTS Connect, High Definition Audio, Premium Blu-ray audio support
LAN
- Network Controller
- Intel I218V / Atheros AR8171
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 288-pin , 2 x PCIe 3.0 x16 , 1 x PCIe 2.0 x16 (x4 mode) , 1 x Ultra M.2
- Storage Interfaces
- SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices , SATA-600 -connectors: 1 x 7pin external SATA - 1 devices
- RAID Features
- Intel Rapid Storage Technology
- 1 x PS/2 keyboard / mouse , 4 x USB 2.0 , 2 x LAN (Gigabit Ethernet) , 1 x SPDIF out , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 4 x USB 3.0
- Internal Interfaces
- 2 x USB 3.0 - header , 4 x USB 2.0 - header , 1 x audio , 1 x serial , 1 x Thunderbolt
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- Multilingual BIOS, SMBIOS 2.3.1. support, ACPI 1.1 support, Untied Overclocking Technology, Dual BIOS, Secure Backup UEFI Technology
- Manual Settings
- CPU frequency, memory voltage
- Hardware Monitoring
- CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage, power supply fan tachometer
- Sleep / Wake Up
- Wake on LAN (WOL)
- Hardware Features
- 12 Phase Power Design, ASRock Instant Flash, 15µ Gold Contact, Intel Turbo Boost Technology 2.0, ASRock XFast LAN, ASRock Dr. Debug, NVIDIA 4-way SLI Technology Support, ASRock XFast RAM, ASRock Crashless BIOS, ASRock OMG (Online Management Guard), ASRock Internet Flash, Digi Power Design, AMD 4-way CrossFireX technology support, ASRock Dehumidifier Function, ESD Protection, ASRock Restart to UEFI, ASRock UEFI System Browser, Platform Controller Hub (PCH) 1.05V Voltage Multi-adjustment, Platform Controller Hub (PCH) 1.5V Voltage Multi-adjustment, Energy Efficient Ethernet 802.3az, Preboot eXecution Environment (PXE), ASRock UEFI Tech Service, ASRock Easy Driver Installer, ASRock USB Key, Premium Headset Amplifier, Direct Drive Technology, EMI shielding cover, NexFET, ASRock A-Tuning, ASRock Full Spike Protection, ASRock Cloud, ASRock APP Shop, ASRock Super Alloy, ASRock Purity Sound 2, ASRock HDD Saver Technology, ASRock Easy RAID Installer, Sapphire Black PCB, Ultra Dual-N MOSFET (UDM)
- Included Accessories
- HDD saver cable
- Cables Included
- 2 x Serial ATA cable , 1 x SLI bridge
- Software Included
- Drivers & Utilities, Antivirus (Trial version), Start8 (30 days trial), Google Chrome Browser, Google ChromeToolbar, Orbweb.ME Professional, ASRock Disk Health Report
- WHQL, FCC, EuP Ready, ErP Ready
ASRock X99M Extreme4 Intel LGA2011-3 X99 mATX DDR4 RAID Gigabit LAN
