This motherboard supports Security Wake On Internet technology with the onboard Qualcomm Atheros LAN, so you can connect with your PC from anywhere in the world. You will be able to power your PC on or turn it off, monitor and take control of it remotely with another smartphone, tablet or computer.
All the capacitors on this board are built with 100% all solid capacitors. With these solid caps, ASRock motherboards are allowed to perform more stably and ensure longer lifetime.
Home cloud - remote desktop anytime, anywhere
This motherboard supports Security Wake On Internet technology with the onboard Qualcomm Atheros LAN, so you can connect with your PC from anywhere in the world. You will be able to power your PC on or turn it off, monitor and take control of it remotely with another smartphone, tablet or computer. -
All solid capacitor design
All the capacitors on this board are built with 100% all solid capacitors. With these solid caps, ASRock motherboards are allowed to perform more stably and ensure longer lifetime. -
4 power phase design
Compared to other competitors' 3 power phase design, ASRock uses 4 power phase design and sturdy components for delivering smoother power to the CPU, thus enhancing the motherboard's performance at lower temperatures. -
FAN-tastic tuning
Configure different fan speeds for respective temperatures using the graph. The fans will automatically shift to the next speed level when the assigned temperature is met. -
Easy driver installer
For users that don't have an optical disk drive to install the drivers from the support CD, easy driver installer is a handy tool in the UEFI that installs the LAN driver to your system via an USB storage device, then downloads and installs the other required drivers automatically. -
USB key
In a world where time is money, why waste precious time everyday typing usernames to log in to Windows? Why should even bother memorizing those foot long passwords? Just plug in the USB key and let your computer log in to windows automatically! -
Fast boot
With ASRock's exclusive Fast Boot technology, it takes seconds to logon to Windows 8 from a cold boot. No more waiting! The speedy boot will completely change your user experience and behavior. -
Dehumidifier
Users may prevent motherboard damages due to dampness by enabling "dehumidifier function". When enabling dehumidifier function, the computer will power on automatically to dehumidify the system after entering S4/S5 state. -
Restart to UEFI
ASRock "Restart to UEFI" technology is designed for those requiring frequent UEFI access. It allows users to easily enter the UEFI SETUP automatically when turning on the PC next time. -
HDMI (High-Definition Multimedia Interface)
This motherboard supports HDMI (High-Definition Multimedia Interface) which is an interface standard for transferring uncompressed video data and delivering multi-channel audio through a single cable. Both video and audio data signals transferred through the HDMI interface is digital without being converted into analog, therefore it delivers the richest pictures and the most realistic sounds.
- ASRock H81M-ITX - motherboard - mini ITX - LGA1150 Socket - H81
- Product Type
- Motherboard - mini ITX
- Chipset Type
- Intel H81
- Processor Socket
- 1 x LGA1150 Socket
- Compatible Processors
- Pentium, Celeron, Xeon, Core i5, Core i3, Core i7 (supports 4th Generation Intel Core i3 / i5 / i7)
- Max RAM Size
- 16 GB
- RAM Supported
- 2 DIMM slots - DDR3, non-ECC, unbuffered
- Storage Ports
- 2 x SATA-600, 1 x eSATA-600
- USB / FireWire Ports
- 2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 2.0 via headers)
- Max Allocated RAM Size
- 1792 MB
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Chipset Type
- Intel H81
- Processor Socket
- LGA1150 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 16 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz, 1066 MHz
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
- 1792 MB
Audio
- Audio Codec
- Realtek ALC892
- High Definition Audio, Premium Blu-ray audio support
LAN
- Network Controller
- Atheros AR8171
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 2 x DIMM 240-pin , 1 x PCIe 2.0 x16
- Storage Interfaces
- SATA-600 -connectors: 2 x 7pin SATA, 1 x 7pin eSATA - 3 devices
- 1 x DVI-D , 2 x USB 3.0 , 1 x VGA , 1 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x SPDIF out , 1 x HDMI , 1 x PS/2 keyboard / mouse
- Internal Interfaces
- 1 x USB 2.0 - header , 1 x audio - header
- Power Connectors
- 4-pin ATX12V connector, 24-pin main power connector
- BIOS Type
- AMI
- BIOS Features
- Multilingual BIOS, SMBIOS 2.3.1. support, ACPI 1.1 support, UEFI BIOS
- Hardware Monitoring
- CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage, power supply fan tachometer, opened case detection
- Sleep / Wake Up
- Wake on LAN (WOL)
- Hardware Features
- ASRock Hybrid Booster, ASRock U-COP, 4 Phase Power Design, ASRock Instant Flash, All-Solid Capacitor motherboard Design, ASRock Boot Failure Guard (B.F.G.), Intel Extreme Memory Profile (XMP) support, ASRock APP Charger, Intel Turbo Boost Technology 2.0, ASRock Good Night LED, Intel Clear Video HD Technology, ASRock XFast USB, AsRock On/Off Play Technology, ASRock XFast LAN, ASRock XFast RAM, ASRock Crashless BIOS, ASRock OMG (Online Management Guard), ASRock Internet Flash, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, ASRock Dehumidifier Function, ASRock Interactive UEFI, ASRock Fast Boot, ASRock Restart to UEFI, ASRock UEFI System Browser, ASRock Home Cloud, ASRock FAN-Tastic Tuning, Platform Controller Hub (PCH) 1.05V Voltage Multi-adjustment, Platform Controller Hub (PCH) 1.5V Voltage Multi-adjustment, Energy Efficient Ethernet 802.3az, ASRock UEFI Tech Service, ASRock Easy Driver Installer, ASRock USB Key, CPU/Chassis Quiet Fan, CPU/Chassis Fan Multi-Speed Control, ASRock A-Tuning
- Included Accessories
- I/O back plate
- Cables Included
- 2 x Serial ATA cable
- Software Included
- Drivers & Utilities, Cyberlink MediaEspresso 6.5 (30-day trial), Antivirus (Trial version), Start8 (30 days trial)
- WHQL, FCC, ACPI 1.1, EuP Ready, ErP Ready
