ASRock H61M-DGS features Intel Smart Connect technology, which keeps content always up-to-date! It means that your email, favorite apps, and social networks are continually and automatically updated even when the system is asleep. Smart Connect will periodically wake up the PC while in a sleep state and check updates for things like email, Twitter, Facebook, etc. No more waiting for the latest world news or friends' updates to be delivered - just enable this function and you're up-to-date and ready to go.
Intel Smart Connect technology keeps content always up-to-date! It means that your email, favorite apps, and social networks are continually and automatically updated even when the system is asleep. Smart Connect will periodically wake up the PC while in a sleep state and check updates for things like email, Twitter, Facebook, etc. No more waiting for the latest world news or friends' updates to be delivered - just enable this function and you're up-to-date and ready to go. -
Intel Rapid Start technology
Intel Rapid Start technology gets your device up and running faster from even the deepest sleep, saving time and battery life. It quickly returns where you left off with a PC that goes from deep-sleep to full awake in a flash. The ultra-responsive capability gives your device the power to quickly resume within few seconds and ensures ultra-low power consumption when on standby. With Intel Rapid Start technology, users can jump right back into everything they were doing! -
Intel HD graphics built-in visuals
Intel HD graphics, simplifies your designs by eliminating additional discrete graphics hardware, while integrating stunning visuals and performance for immersive gaming.
- ASRock H61M-DGS - 2.0 - motherboard - micro ATX - LGA1155 Socket - H61
- Product Type
- Motherboard - micro ATX
- Chipset Type
- Intel H61 Express
- Processor Socket
- 1 x LGA1155 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7, Xeon E3-1200 series
- Max RAM Size
- 16 GB
- RAM Supported
- 2 DIMM slots - DDR3, non-ECC, unbuffered
- Storage Ports
- 4 x SATA-300
- USB / FireWire Ports
- 4 x USB 2.0 + (4 x USB 2.0 via headers)
- Max Allocated RAM Size
- 1760 MB
- Audio
- HD Audio (6-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Chipset Type
- Intel H61 Express
- Processor Socket
- LGA1155 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 16 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz, 1066 MHz
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
- Memory Allocation Technology
- Dynamic Video Memory Technology 5.0
- 1760 MB
Audio
- Audio Codec
- Realtek ALC662
- High Definition Audio
LAN
- Network Controller
- Realtek RTL8111C
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 2 x DIMM 240-pin , 1 x PCIe 3.0 x16 (x16 mode) , 1 x PCIe 2.0 x1
- Storage Interfaces
- SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices
- 1 x PS/2 mouse , 1 x PS/2 keyboard , 1 x DVI-D , 1 x VGA , 4 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack
- Internal Interfaces
- 2 x USB 2.0 - header , 1 x serial - header , 1 x parallel - header
- Power Connectors
- 4-pin ATX12V connector, 24-pin main power connector
- BIOS Type
- AMI
- BIOS Features
- JumperFree, SMBIOS 2.3.1. support, Hyper-Threading Technology, ACPI 1.1 support, UEFI BIOS
- Hardware Monitoring
- CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage, power supply fan tachometer
- Sleep / Wake Up
- Wake on LAN (WOL)
- Hardware Features
- ASRock Hybrid Booster, ASRock U-COP, ASRock Instant Boot, ASRock Instant Flash, ASRock Boot Failure Guard (B.F.G.), HDCP compliant, Intel Extreme Memory Profile (XMP) support, Solid Capacitor for CPU power, ASRock APP Charger, Intel Turbo Boost Technology 2.0, ASRock Combo Cooler Option (C.C.O), ASRock Good Night LED, Intel Clear Video HD Technology, ASRock XFast USB, ASRock XFast LAN, ASRock XFast RAM, ASRock Crashless BIOS, Intel Rapid Start Technology, Intel Smart Connect Technology, ASRock OMG (Online Management Guard), ASRock Internet Flash, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video 2.0, ASRock Dehumidifier Function, ASRock Fast Boot, ASRock Restart to UEFI
- Plug and Play, WHQL, FCC, ACPI 1.1
