FM2A75M-DGS has brilliantly designed for smart overclocking, ASRock X-Boost technology is able to unleash the hidden power of your CPUs. Simply press "X" when turning on the PC, X-Boost will automatically overclock the relative components to get up to 15.77% performance boost! With the smart X-Boost, overclocking CPU can become a near one-button process.
ASRock "Restart to UEFI" technology is designed for those requiring frequent UEFI access. It allows users to easily enter the UEFI SETUP automatically when turning on the PC next time. Engineered for supremacy, designed for efficiency and packed with incredible features, the AMD Radeon HD 7000 Series offers the world's most advanced graphics.
X-Boost
Brilliantly designed for smart overclocking, ASRock X-Boost technology is able to unleash the hidden power of your CPUs. Simply press "X" when turning on the PC, X-Boost will automatically overclock the relative components to get up to 15.77% performance boost! With the smart X-Boost, overclocking CPU can become a near one-button process. -
Restart to UEFI
ASRock "Restart to UEFI" technology is designed for those requiring frequent UEFI access. It allows users to easily enter the UEFI SETUP automatically when turning on the PC next time. -
AMD Radeon HD 7000 series graphics
Engineered for supremacy, designed for efficiency and packed with incredible features, the AMD Radeon HD 7000 Series offers the world's most advanced graphics. -
DirectX 11
DirectX 11 is the very latest in high-speed, high-fidelity gaming and computing. It can enable not just more visually stunning games, but significant performance improvements in some of your favorite websites and everyday applications. -
Dual graphics
The AMD Dual Graphics technology combines APU and GPU computing power to optimize user's visual experience. -
AMD Steady Video 2.0
Bringing the best video experience! Compared to v1.0, AMD Steady Video 2.0 provides more tech advances such as Letter/Pillar Boxed Content, Indicator Overlay, Enhanced Algorithm Effectiveness, etc. -
AMP and XMP
Not only supporting AMD Memory Profile (AMP), ASRock FM2 Motherboard Series also come with Intel XMP memory tuning kits, making it's easy to get maximum memory performance from your system. -
Interactive UEFI
ASRock Interactive UEFI is a blend of system configuration tools, cool sound effects and stunning visuals. The unprecedented UEFI provides a more attractive interface and brings a lot more amusing. -
Internet Flash
Internet Flash searches for available UEFI firmware updates from ASRock servers. System can auto-detect the latest UEFI from the servers and flash them within UEFI setup without entering Windows OS. -
Easy RAID installer
Easy RAID installer can help you install the RAID driver easily without floppy drive. It can copy the RAID driver from a support CD to your USB storage device with just one simple click in UEFI setup.
- ASRock FM2A75M-DGS - motherboard - micro ATX - Socket FM2 - AMD A75
- Product Type
- Motherboard - micro ATX
- Chipset Type
- AMD A75
- Compatibility
- AMD LIVE! Ready
- Processor Socket
- 1 x Socket FM2
- Max RAM Size
- 32 GB
- RAM Supported
- 2 DIMM slots - DDR3
- Storage Ports
- 6 x SATA-600 (RAID)
- USB / FireWire Ports
- 2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 6 x USB 2.0 via headers)
- Audio
- HD Audio (6-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Chipset Type
- AMD A75
- Compatibility
- AMD LIVE! Ready
- Processor Socket
- Socket FM2
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR3
- Bus Clock
- 2400 MHz, 1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz, 2133 MHz
- Speed
- PC3-19200, PC3-12800, PC3-10600, PC3-8500, PC3-17000, PC3-14900
Audio
- Audio Codec
- Realtek ALC662
- High Definition Audio
LAN
- Network Controller
- Realtek RTL8111E
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 2 x DIMM 240-pin , 1 x PCIe 2.0 x16 (x16 mode) , 1 x PCIe 2.0 x1 , 1 x PCI
- Storage Interfaces
- SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10
- 1 x PS/2 mouse , 1 x PS/2 keyboard , 1 x VGA , 1 x DVI-D , 4 x USB 2.0 , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x audio line-out , 1 x microphone
- Internal Interfaces
- 1 x parallel - header , 1 x serial - header , 3 x USB 2.0 - header , 1 x USB 3.0 - header , 1 x line-out/microphone - header
- Power Connectors
- 4-pin ATX12V connector, 24-pin main power connector
- BIOS Type
- AMI
- BIOS Features
- JumperFree, SMBIOS 2.3.1. support, ACPI 1.1 support, UEFI BIOS
- Manual Settings
- Memory voltage, chipset voltage
- Hardware Monitoring
- CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage, power supply fan tachometer
- Sleep / Wake Up
- Wake on LAN (WOL)
- Hardware Features
- ASRock Hybrid Booster, ASRock U-COP, AMD Cool 'n' Quiet Technology, ASRock Instant Boot, ASRock Instant Flash, HDCP compliant, Intel Extreme Memory Profile (XMP) support, ASRock APP Charger, ASRock XFast USB, AMD Radeon Dual Graphics, ASRock XFast LAN, ASRock XFast RAM, ASRock Crashless BIOS, ASRock OMG (Online Management Guard), ASRock Internet Flash, ASRock Dehumidifier Function, AMD Steady Video 2.0, ASRock Interactive UEFI, AMD Memory Profile (AMP) support, UMI-Link GEN2
- Cables Included
- 2 x Serial ATA cable
- Software Included
- Drivers & Utilities, ASRock Extreme Tuning Utility, AMD Live! Explorer, Cyberlink MediaEspresso 6.5 (30-day trial), ASRock MAGIX Multimedia Suite
- Plug and Play, WHQL, FCC, EuP Ready, ErP Ready
- 22.6 cm
- 19.3 cm
