ASRock XFast USB technology redefines the standard in high performance computing. Proving once again to be the pioneer in motherboard industry, ASRock XFast USB series motherboards integrate with the XFast USB technology which delivers the world's fastest USB data transfer speed.
This board is designed to build up the most powerful system and delivers the most demanding technology for users nowadays. Just enjoy next generation computing with ASRock 8-core CPU Ready motherboard.
- Premium Gold Caps (2.5 x longer life time), 100% Japan-made high-quality Conductive Polymer Capacitors
- Digi Power, Supports AM3+ Processor, 8-Core CPU
- Supports Dual Channel DDR3 2100(OC)
- Supports AMD Quad CrossFireX™, 3-Way CrossFireX™ and CrossFireX™
- Supports NVIDIA® Quad SLI™ and SLI™
- 2 x Front USB 3.0, 2 x Rear USB 3.0, 8 x SATA3, 2 x IEEE 1394
- Dr. Debug, Power/Reset/Clear CMOS Switch with LED
- Supports XFast USB, XFast LAN, Graphical UEFI
- Supports On/Off Play Technology, Instant Boot, Instant Flash, APP Charger, SmartView, Turbo UCC
- 7.1 CH HD Audio with Content Protection, supports THX TruStudio™
- Free Bundle : CyberLink MediaEspresso 6.5 Trial, 1 x 3.5mm Audio Cable
- ASRock 990FX Extreme4 - motherboard - ATX - Socket AM3+ - AMD 990FX
- Product Type
- Motherboard - ATX
- Chipset Type
- AMD 990FX / AMD SB950
- Processor Socket
- 1 x Socket AM3+
- Compatible Processors
- Sempron, Phenom II X3, Athlon II X2, Phenom II X2, Athlon II X4, Athlon II X3, Phenom II X4, Phenom II X6 (Except Phenom II 920 / 940)
- Data Bus Transfer Rate
- 5.2 GT/s
- Max RAM Size
- 32 GB
- RAM Supported
- 4 DIMM slots - DDR3, non-ECC, unbuffered
- Storage Ports
- 6 x SATA-600 (RAID), 2 x SATA-600, 1 x ATA-133
- USB / FireWire Ports
- USB 3.0, FireWire
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- Max Bus Speed
- 2600 MHz
- 5.2 GT/s
- Processor Socket
- Socket AM3+
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz, 1066 MHz, 800 MHz, 1866 MHz
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture
Audio
- Audio Codec
- Realtek ALC892
- High Definition Audio, THX TruStudio Pro
LAN
- Network Controller
- Broadcom BCM57781
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 240-pin , 2 x PCIe 2.0 x16 , 2 x PCIe 2.0 x1 , 2 x PCI , 1 x PCIe 2.0 x16
- Storage Interfaces
- AMD SB950: SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 0+1 / RAID 5 / JBOD , Marvell 88SE9120: SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices , AMD SB850: ATA-133 -connectors: 1 x 40pin IDC - 2 devices
- 2 x USB 3.0 , 1 x FireWire , 1 x PS/2 keyboard , 1 x TOSLINK , 1 x LAN (Gigabit Ethernet) , Audio , 6 x USB 2.0 , 1 x PS/2 mouse , 1 x SPDIF out , 1 x storage - Serial ATA-600 - 7 pin external Serial ATA
- Internal Interfaces
- 1 x floppy
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- JumperFree, SMBIOS 2.3.1. support, ACPI 1.1 support, UEFI BIOS
- Manual Settings
- CPU frequency
- Hardware Monitoring
- CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, power supply fan tachometer
- Sleep / Wake Up
- Wake on LAN (WOL)
- Hardware Features
- AMD Cool 'n' Quiet Technology, ASRock Instant Boot, NVIDIA SLI Technology Support, ASRock Instant Flash, NVIDIA Quad SLI Technology Support, ASRock Turbo UCC, ASRock APP Charger, ASRock SmartView, Loss-less content protection technology, ASRock XFast USB, Asrock C.C.R. (Combo Cooler Retention Module), AsRock On/Off Play Technology, Conductive Polymer Capacitors, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, AMD 3-way CrossFireX technology support
- Included Accessories
- Front USB 3.0 panel
- Cables Included
- 1 x audio cable , 1 x floppy cable , 1 x IDE cable
- Software Included
- Drivers & Utilities, ASRock Software Suite, ASRock Extreme Tuning Utility, Cyberlink MediaEspresso 6.5 (30-day trial)
- Plug and Play, WHQL, FCC, ACPI 1.1, EuP Ready, ErP Ready
- 30.5 cm
- 24.4 cm
ASRock 990FX EXTREME4 AM3+ AMD 990FX DDR3 ATX
