ASRock 970 Pro3 R2.0 AMD 970 AM3+ ATX 4 DDR3 CrossFire RAID 140W
Quicklinx: B5XLWS00 Mfr#: 970-PRO3 R2.0
This board is designed to build up the most powerful system and delivers the most demanding technology for users nowadays. Just enjoy next generation computing with ASRock 8-core CPU ready motherboard.
  • X-Boost
    ASRock's X-Boost technology is a smart auto-overclocking function and is brilliantly designed to unlock the hidden cores of your CPUs. Simply press "X" when turning on the PC, X-Boost will automatically overclock the relative components to get up to 116% performance boost! With the smart X-Boost, overclocking CPU or unlock CPU cores can become a near one-button process.
  • 4 USB 3.0 (2 front, 2 back)
    Rich storage options! This motherboard offers 4 USB 3.0 (2 from onboard header, 2 from rear I/O) to facilitate computing environment.
  • Fast Boot
  • Restart to UEFI
    ASRock "Restart to UEFI" technology is designed for those requiring frequent UEFI access. It allows users to easily enter the UEFI setup automatically when turning on the PC next time.
  • AM3+ 8-core processor support
  • C.C.R. (Combo Cooler Retention module)
    The unique combo cooler retention module greatly improves heat dissipation and is backward compatible with AMD previous AM3/AM2+ coolers.
  • Dehumidifier
    Users may prevent motherboard damages due to dampness by enabling "dehumidifier function". When enabling dehumidifier function, the computer will power on automatically to dehumidify the system after entering S4/S5 state.
  • ASRock OMG (Online Management Guard)
    Fast, easy and free – ASRock OMG technology allows you to establish an internet curfew or restrict Internet access at specified times. Administrators are able to schedule the starting and ending hours of internet access granted to other users.
  • Graphical UEFI – the BIOS interface
    Unified Extensible Firmware Interface (UEFI) is a BIOS utility which offers tweak-friendly options in an advanced viewing interface. Compared with traditional BIOS design, the UEFI utility provides lots improved functions.
  • THX TruStudio
    THX TruStudio is specially designed to bring the same great audio experience found in live performances, films, and recording studios to the PC.
ASRock 970 Pro3 R2.0 - motherboard - ATX no CPU - Socket AM3+ - AMD 970
Motherboard - ATX
No CPU
Chipset Type
AMD 970 / AMD SB950
Processor Socket
1 x Socket AM3+
Compatible Processors
Sempron, Phenom II X3, Athlon II X2, Phenom II X2, Athlon II X4, Athlon II X3, Phenom II X4, Phenom II X6 (supports CPUs with up to 8 cores, Maximum TDP 140 Watt)
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID)
USB / FireWire Ports
2 x USB 3.0 + 6 x USB 2.0 + (2 x USB 3.0 + 6 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
No CPU
Chipset Type
AMD 970 / AMD SB950
Max Bus Speed
2.4 GHz
Processor Socket
Socket AM3+
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1800 MHz, 1600 MHz, 1333 MHz, 1066 MHz, 800 MHz, 1866 MHz, 2100 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Audio
Audio Codec
Realtek ALC892
THX TruStudio PC, High Definition Audio
LAN
Network Controller
Realtek RTL8111E
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x PCIe 2.0 x16 , 1 x PCIe 2.0 x16 (x4 mode) , 1 x PCIe 2.0 x1 , 2 x PCI , 4 x DIMM 240-pin , 1 x CPU
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
1 x PS/2 keyboard , 1 x PS/2 mouse , 6 x USB 2.0 , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (side surround) - mini-jack
Internal Interfaces
6 x USB 2.0 - header , 1 x serial - header , 1 x SPDIF - header , 2 x USB 3.0 - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
JumperFree, SMBIOS 2.3.1. support, ACPI 1.1 support, Untied Overclocking Technology, UEFI BIOS
Manual Settings
Processor core voltage, memory voltage, chipset voltage
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, power supply fan tachometer
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
ASRock Hybrid Booster, ASRock U-COP, AMD Cool 'n' Quiet Technology, ASRock Instant Boot, 4+1 Phase Power Design, ASRock Instant Flash, ASRock CPU Frequency Stepless Control, All-Solid Capacitor motherboard Design, ASRock Boot Failure Guard (B.F.G.), ASRock UCC, ASRock APP Charger, ASRock Good Night LED, ASRock XFast USB, AsRock On/Off Play Technology, ASRock XFast LAN, ASRock XFast RAM, ASRock Crashless BIOS, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, ASRock OMG (Online Management Guard), ASRock Internet Flash, ASRock Dehumidifier Function, Hyper Transport 3.0, ASRock Fast Boot, ASRock X-Boost, ASRock Restart to UEFI, ASRock UEFI System Browser
I/O back plate
2 x Serial ATA cable
Software Included
Drivers & Utilities, AMD OverDrive, ASRock Extreme Tuning Utility, Cyberlink MediaEspresso 6.5 (30-day trial), ASRock MAGIX Multimedia Suite
Plug and Play, WHQL, FCC Part 15, ACPI 1.1, EuP Ready, ErP Ready
