Aruba Instant On AP17 (RW) Access Point
Quicklinx: FBK6WS00 Mfr#: R2X11A
  • IEEE 802.11n
£219.27 ex VAT
£263.12 inc VAT
Marketing description is not available.
  • Eliminates High Cost of Cabling with Full-Scale Wireless Mesh Coverage
    Aruba Instant On AP17 Outdoor Access Points feature built-in wireless mesh capabilities to cost-effectively extend Wi-Fi connectivity without additional cables.Conveniently expands your network to hard-to-wire areas and nearly eliminating spotty connections and dead zones, providing Wi-Fi where you need it.
  • Safeguard Sensitive Data with WPA2/WPA3 and Enhanced Open
    Aruba Instant On AP17 Outdoor Access Points come with integrated Wi-Fi Alliance security standard WPA2/WPA3 and Enhanced Open support for protected wireless access.Create up to eight different SSIDs under one network name to keep your data safe, whether surfing the web or checking HR data.
  • Simplicity is the Key to a Great Wi-Fi Experience
    The Aruba Instant On AP17 Outdoor Access Points are built with premium hardware and software quality that's reliable and comes from a trusted vendor.Effortless set-up right out of the box – in the palm of your hand.The Aruba Instant On portfolio comes with flexible management options to choose from: The Aruba Instant On mobile app guides you through step-by-step from initial set-up to ongoing management.Aruba Instant On AP17 Outdoor Access Points are designed for single or distributed small businesses sites such as tech start-ups, graphic design firms, cafés, restaurants, and other Wi-Fi hotspots.Simple to build landing page lets you customize your guest access page with your logo, your own brand, and acceptance of use language.
HPE Networking Instant On AP17 (RW) - radio access point - Bluetooth, Wi-Fi 5
Radio access point
External - outdoor
Bluetooth, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Performance
Concurrent data rate (5 GHz): 867 Mbps , Concurrent data rate (2.4 GHz): 300 Mbps
Cable gland M20x1.5, self-tapping screw, grounding lug, M4x8 screw, mounting bracket
Power Over Ethernet (PoE) Supported
PoE
18.7 cm x 15.6 cm x 6.7 cm
650 g
Radio access point
Ruggedized Design
Outdoor
18.7 cm
15.6 cm
6.7 cm
650 g
External
Wireless
Frequency Band
2.4 GHz, 5 GHz
Performance
Status Indicators
Status
Manageable, wall mountable, reset button, 2T2R MIMO technology, pole mountable, Bluetooth (BLE) clients support
Encryption Algorithm
WPA2, WPA3, Opportunistic Wireless Encryption (OWE)
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac
Aerial
Antenna
Internal
Antenna Qty
2
Directivity
Omni-directional
Gain Level
4.7 dBi
1 x 1000Base-T (PoE) - RJ-45
MTBF
34 years
IEC 60950, UL 2043, EN 60601-1-2, EN 60601-1-1, CB 62368
PoE
OS Provided
InstantOS
Limited warranty - 2 years , Technical support - phone consulting - 90 days , Technical support - web support - 2 years
-40 °C
50 °C
5 - 93% (non-condensing)
Type: Radio access point
Connectivity: Wireless
Protocol: IEEE 802.11b
Protocol: IEEE 802.11n
Protocol: IEEE 802.11g
Protocol: IEEE 802.11ac
Protocol: Bluetooth
Brand: Aruba
