Aruba Instant On AP15 (RW) Access Point
Quicklinx: FBK4WS00 Mfr#: R2X06A
  • IEEE 802.11n
£176.82 ex VAT
£212.18 inc VAT
Marketing description is not available.
  • Eliminates High Cost of Cabling with Full-Scale Wireless Mesh Coverage
    Aruba Instant On AP15 Indoor Access Points feature built-in wireless mesh capabilities to cost-effectively extend Wi-Fi connectivity without additional cables.Conveniently expands your network to hard-to-wire areas while nearly eliminating rid of spotty connections and dead zones, to provide Wi-Fi where you need it.
  • Safeguard Sensitive Data with WPA2/WPA3 and Enhanced Open
    Aruba Instant On AP15 Indoor Access Points come with integrated Wi-Fi Alliance security standard WPA2/WPA3 and Enhanced Open support for protected wireless access.Create up to eight different SSIDs under one network name to keep your data safe, whether surfing the web or checking HR data.
  • Simplicity is the Key to a Great Wi-Fi Experience
    The Aruba Instant On AP15 Indoor Access Points are built with premium hardware and software quality that's as reliable and coming from a trusted vendor.Effortless set-up right out of the box – in the palm of your hand.The Aruba Instant On portfolio comes with flexible management options to choose from: The Aruba Instant On mobile app guides you through step-by-step from initial set-up to ongoing management.Simple to build landing page lets you customize your guest access page with your logo, your own brand, and acceptance of use language.Traffic for any device connecting with guest role is automatically segmented from core business traffic.
HPE Networking Instant On AP15 (RW) - radio access point - Bluetooth, Wi-Fi 5
Radio access point
Wall / ceiling mountable - indoor
Bluetooth, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Performance
Concurrent data rate (5 GHz): 1733 Mbps , Concurrent data rate (2.4 GHz): 300 Mbps
Ceiling rail mount clip, solid surface mount clip
Power Over Ethernet (PoE) Supported
PoE
18.3 cm x 18.3 cm x 4.1 cm
674 g
1-year warranty
Radio access point
Ruggedized Design
Indoor
18.3 cm
18.3 cm
4.1 cm
674 g
Wireless
Frequency Band
2.4 GHz, 5 GHz
Performance
Status Indicators
Status
Manageable, wall mountable, reset button, 4T4R MIMO technology, security lock slot (cable lock sold separately), Bluetooth (BLE) clients support
Encryption Algorithm
WPA2, WPA3, Opportunistic Wireless Encryption (OWE)
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac
Aerial
Antenna
Internal
Directivity
Omni-directional
Gain Level
6 dBi
1 x 1000Base-T (PoE) - RJ-45
1 x network cable
MTBF
105 years
UL 2043, EN 60601-1-2, EN 60601-1-1
PoE
OS Provided
InstantOS
Limited warranty - 1 year , Technical support - phone consulting - 90 days , Technical support - web support - 1 year
50 °C
5 - 93% (non-condensing)
Type: Radio access point
Connectivity: Wireless
Protocol: IEEE 802.11g
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: IEEE 802.11n
Protocol: Bluetooth
Brand: Aruba
