Aruba Instant On AP11D (RW) Access Point
Quicklinx: FBK7WS00 Mfr#: R2X16A
  • IEEE 802.11n
£125.72 ex VAT
£150.86 inc VAT
Marketing description is not available.
  • Simplicity is the Key to a Great Wi-Fi Experience
    The HPE Aruba Networking Instant On AP11D Desk/Wall Access Points are built with premium hardware and software quality that's as reliable as coming from a trusted vendor.Effortless set-up right out of the box – in the palm of your hand.The HPE Aruba Networking Instant On portfolio comes with flexible management options to choose from: The HPE Aruba Networking Instant On mobile app guides you through step-by-step from initial set-up to ongoing management.Ideal for single or distributed small business sites like boutique hotels, medical clinics, Airbnb, and other Wi-Fi hotspots.Simple to build landing page that allows you to customize your guest access page with your own brand and logo.
  • Eliminates High Cost of Cabling with Full-scale Wireless Mesh Coverage
    HPE Aruba Networking Instant On AP11D Desk/Wall Access Points have built-in wireless mesh capabilities to cost-effectively extend Wi-Fi connectivity, without additional cables.Conveniently expand your network to hard-to-wire areas - nearly getting rid of spotty connections and dead zones, to provide Wi-Fi where you need it.
  • Safeguard Sensitive Data with WPA2/WPA3 and Enhanced Open
    HPE Aruba Networking Instant On AP11D Desk/Wall Access Points comes with integrated Wi-Fi Alliance WPA2/WPA3 security standard and Enhanced Open support for protected wireless access.Create up to eight different SSIDs under one network name to keep your data safe, whether surfing the web or checking HR data.
HPE Networking Instant On AP11D (RW) - radio access point - Bluetooth, Wi-Fi 5
Radio access point
External - indoor
Bluetooth, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Performance
Concurrent data rate (5 GHz): 867 Mbps , Concurrent data rate (2.4 GHz): 300 Mbps
Wall mounting kit, desk mount kit
Power Over Ethernet (PoE) Supported
PoE Class 3 / PoE Class 4
15 cm x 8.6 cm x 4 cm
313 g
Radio access point
Ruggedized Design
Indoor
15 cm
8.6 cm
4 cm
313 g
External
Wireless
Frequency Band
2.4 GHz, 5 GHz
Performance
Status Indicators
Status
Wall mountable, reset button, 2T2R MIMO technology, security lock slot (cable lock sold separately), Bluetooth (BLE) clients support
Encryption Algorithm
WPA2, WPA3, Opportunistic Wireless Encryption (OWE)
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac
Aerial
Antenna
Internal
Directivity
Directional
Gain Level
6.2 dBi
1 x 1000Base-T (PoE) - RJ-45 , 1 x 1000Base-T (PoE output) - RJ-45 , 2 x 1000Base-T - RJ-45
1 x network cable
MTBF
124 years
UL 2043, EN 60601-1-2, EN 60601-1-1
OS Provided
InstantOS
Limited warranty - 2 years , Technical support - phone consulting - 90 days , Technical support - web support - 2 years
5 - 93% (non-condensing)
Type: Radio access point
Connectivity: Wireless
Protocol: IEEE 802.11g
Protocol: IEEE 802.11a
Protocol: IEEE 802.11n
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: Bluetooth
Brand: Aruba
