Simplicity is the Key to a Great Wi-Fi Experience
The Aruba Instant On AP11 Indoor Access Point is built with premium hardware and software quality that's as reliable as coming from a trusted vendor.Effortless set-up right out of the box – in the palm of your hand.The Aruba Instant On portfolio comes with flexible management options to choose from: The Instant On mobile app guides you through step-by-step from initial set-up to ongoing management.Ideal for small and growing businesses like cafés, retail stores or professional offices, and other Wi-Fi hotspots.Simple to build landing page lets you customize your guest access page with your logo, your own brand, and acceptance of use language. -
Eliminates High Cost of Cabling with Full-Scale Wireless Mesh Coverage
Aruba Instant On AP11 Indoor Access Points feature built-in wireless mesh capabilities to cost-effectively extend Wi-Fi connectivity without additional cables.Conveniently expands your network to hard-to-wire areas and can remove spotty connections and dead zones, to provide Wi-Fi where you need it. -
Protect Sensitive Data with WPA2/WPA3 and Enhanced Open
Aruba Instant On AP11 Indoor Access Points feature the only premium-grade access point with Wi-Fi Alliance WPA2/WPA3 and Enhanced Open support for protected wireless access.Create up to eight different SSIDs under one network name to keep your data safe, whether surfing the web or checking HR data.
- HPE Networking Instant On AP11 (RW) - radio access point - Bluetooth, Wi-Fi 5
- Radio access point
- Form Factor
- Wall / ceiling mountable - indoor
- Data Link Protocol
- Bluetooth, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Concurrent data rate (5 GHz): 867 Mbps , Concurrent data rate (2.4 GHz): 300 Mbps
- Included Accessories
- Ceiling rail mount clip, solid surface mount clip
- Power Over Ethernet (PoE) Supported
- PoE
- 15.2 cm x 15.2 cm x 3.4 cm
- 193 g
- 2-year warranty
- Ruggedized Design
- Indoor
- 15.2 cm
- 15.2 cm
- 3.4 cm
- 193 g
- Form Factor
- Connectivity Technology
- Wireless
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Status Indicators
- Status
- Manageable, wall mountable, reset button, 2T2R MIMO technology, security lock slot (cable lock sold separately), Bluetooth (BLE) clients support
- Encryption Algorithm
- WPA2, WPA3, Opportunistic Wireless Encryption (OWE)
- IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac
Aerial
- Antenna
- Internal
- Directivity
- Omni-directional
- Gain Level
- 5.8 dBi
- 1 x 1000Base-T (PoE) - RJ-45
- Cables Included
- 1 x network cable
- MTBF
- 91 years
- UL 2043, EN 60601-1-2, EN 60601-1-1
- PoE
- OS Provided
- InstantOS
- Limited warranty - 2 years , Technical support - phone consulting - 90 days , Technical support - web support - 2 years
- 0 °C
- 40 °C
- 5 - 93% (non-condensing)
