The Aruba 310 series access points deliver high performance and superb user experience for mobile devices, Internet of Things (IoT) devices, and applications in dense office environments. Featuring MU-MIMO capability, advanced Aruba ClientMatch radio management, and Aruba Beacon technologies, the 310 series enables an all-wireless digital work environment in a cost-effective manner.
Cost-Efficient Wave 2 Access Points for Mid-Market
The Aruba 310 Series Access Points provide fast gigabit data speeds and a superb user experience for mobile devices, Internet of Things (IoT) devices, and applications in high density office environments.Integrated BLE Beacon to remotely manage battery-powered Aruba Beacons. -
A Choice of Operating Modes to Meet Your Unique Management and Deployment Requirements
Aruba 310 Series Access Points offer centralized configuration, data encryption, policy enforcement and network services, as well as distributed and centralized traffic forwarding when managed by Aruba Mobility Controllers.In Aruba Instant mode (Aruba IAP) a single AP automatically distributes the network configuration to other Instant APs. A built-in migration path allows 310 Series Instant APs to become part of a WLAN that is managed by a Mobility Controller. -
Provide Simultaneous Data Transmission to Multiple Devices and Improving Network Efficiency
Aruba 310 Series Access Points delivers aggregate 2.1Gbps data rate with 1.7Gbps @ 5GHz and 400Mbps @ 2.4GHz.4x4:4SS SU/MU-MIMO @ 5GHz; and 2x2:2SS SU-MIMO @ 2.4GHz to ensure the highest performance.
- HPE Aruba Instant IAP-315 (RW) - radio access point
- Radio access point
- Form Factor
- In-ceiling - indoor
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Concurrent data rate (5 GHz): 1733 Mbps , Concurrent data rate (2.4 GHz): 400 Mbps , Peak data rate: 2.1 Gbps
- Capacity
- Wireless clients: 255 , BSSIDs per radio: 16
- Included Accessories
- 2 x ceiling mounting clip
- Power Over Ethernet (PoE) Supported
- PoE
- 18.2 cm x 18 cm x 4.8 cm
- 650 g
- Limited lifetime warranty
- Ruggedized Design
- Indoor
- 18.2 cm
- 18 cm
- 4.8 cm
- 650 g
- Form Factor
- In-ceiling
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 1.733 Gbps
- Line Coding Format
- CCK, 64 QAM, 256 QAM, BPSK, QPSK, 16 QAM
- Spread Spectrum Method
- OFDM, DSSS
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Capacity
- Status Indicators
- System, status
- Auto-sensing per device, auto-uplink (auto MDI/MDI-X), DFS support, Quality of Service (QoS), Trusted Platform Module (TPM), reset button, 2T2R MIMO technology, Adaptive Radio Management (ARM), Maximum Ratio Combining (MRC), Low Density Parity Check (LDPC), Transmit Beam-forming (TxBF) ready, Energy Efficient Ethernet, Cyclic Delay Diversity (CDD), Space Time Blocking Code (STBC), 4T4R MIMO technology, Advanced Cellular Coexistence (ACC), cyclic shift diversity (CSD), AppRF technology, MU-MIMO technology, enhanced ClientMatch, Aruba Beacons Bluetooth Low-Energy (BLE) technology, wireless intrusion protection, Air Monitor (AM)
- IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az, IEEE 802.11ac
Aerial
- Antenna
- Internal
- Antenna Qty
- 4
- Directivity
- Omni-directional
- 1 x 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A
- MTBF
- 916,373 hours
- EN 60950, IEC 60950, UL 60950, CB, UL 2043, FCC, EN 60601-1-2, cTUVus, EN 300 328, EN 301 489, EN 60601-1-1, LVD 72/23/EEC, R&TTE Directive 1999/5/EC, EN 301 893
- PoE
- 14.4 Watt
- OS Provided
- InstantOS
- Limited warranty - lifetime
- 0 °C
- 50 °C
- 5 - 95% (non-condensing)
