Aruba IAP-305 (RW) Instant 2x/3x 11ac Access Point
HIGH PERFORMANCE AND SUPERB USER EXPERIENCE!
Quicklinx: CRVSWS00 Mfr#: JX945A
Type: Radio access point
Connectivity: Wireless
Protocol: IEEE 802.11ac, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g + 1 more
Compatibility: PC
  • IEEE 802.11n
£427.31 ex VAT
£512.77 inc VAT
The entry-level Aruba 300 Series Wave 2 access points deliver high performance and superb user experience for medium density environments. These Wave 2 access points deliver multi-user MIMO (MU-MIMO) aware ClientMatch to boost network efficiency and support the growing device density demands on your network.
The 300 Series also has an integrated Bluetooth Aruba Beacon that simplifies the remote management of a network of large-scale battery-powered Aruba beacons while also providing advanced location and indoor way finding, and proximity-based push notification capabilities.
  • Intelligent Power Monitoring
    For the Aruba 300 Series Access Points, the IPM power-save feature applies when the unit is powered by an 802.3af PoE source.By default, the USB interface will be the first feature to turn off if AP power consumption exceeds the available power budget.
  • Threat Protection and Security
    The Aruba 300 Series Access Points feature integrated wireless intrusion protection offers threat protection and mitigation, and eliminates the need for separate RF sensors and security appliances.IP reputation and security services identify, classify, and block malicious files, URLs and IPs, providing comprehensive protection against advanced online threats.Integrated Trusted Platform Module (TPM) for secure storage of credentials and keys.
HPE Aruba Instant IAP-305 (RW) - radio access point - Wi-Fi 5
Radio access point
In-ceiling - indoor
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Performance
Concurrent data rate (5 GHz): 1300 Mbps , Concurrent data rate (2.4 GHz): 400 Mbps , Peak data rate: 1.7 Gbps
Wireless clients per Wi-Fi radio: 255 , BSSIDs per radio: 16
2 x ceiling mounting clip
16.5 cm x 16.5 cm x 3.8 cm
460 g
Radio access point
Ruggedized Design
Indoor
16.5 cm
16.5 cm
3.8 cm
460 g
In-ceiling
Wireless
Line Coding Format
CCK, 64 QAM, 256 QAM, BPSK, QPSK, 16 QAM
Spread Spectrum Method
OFDM, DSSS
Frequency Band
2.4 GHz, 5 GHz
Performance
Status Indicators
System, wireless
Auto-uplink (auto MDI/MDI-X), DFS support, Quality of Service (QoS), Trusted Platform Module (TPM), reset button, 2T2R MIMO technology, Maximum Ratio Combining (MRC), 3T3R MIMO technology, Low Density Parity Check (LDPC), Transmit Beam-forming (TxBF) ready, Cyclic Delay Diversity (CDD), Space Time Blocking Code (STBC), Advanced Cellular Coexistence (ACC), cyclic shift diversity (CSD), MU-MIMO technology, enhanced ClientMatch, Aruba Beacons Bluetooth Low-Energy (BLE) technology, wireless intrusion protection
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az, IEEE 802.11ac
Aerial
Antenna
Internal
Antenna Qty
3
Directivity
Omni-directional
Gain Level
5.4 dBi
1 x 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A
MTBF
1,116,000 hours
EN 60950, IEC 60950, UL 60950, CB, UL 2043, FCC, EN 60601-1-2, cTUVus, EN 300 328, EN 301 489, EN 60601-1-1, LVD 72/23/EEC, EN 301 893, R&TTE Directive 1995/5/EC
13 Watt
OS Provided
InstantOS
Limited warranty - lifetime
50 °C
5 - 93% (non-condensing)
CRVS Aruba Network Device Wall / Ceiling Mount Kit - White In Stock £12.44
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: PC
Brand: Aruba
