Aruba HP ProCurve MSM317 WW Access Device
Quicklinx: 6LJ1WS00 Mfr#: J9423A
HP 317 Access Device Series integrates wired and wireless connectivity into a small unit that can be quickly installed in a standard wall outlet box. It provides four Ethernet ports, a 2.4 GHz wireless access point, and a pass-through RJ-45 connection to support a range of service and user connectivity options. One Ethernet port can be configured as an IEEE 802.3af-compliant PSE port for powering devices such as IP telephones. The HP 317 Access Device Series requires only a single Power over Ethernet (PoE) cable drop and provides wireless coverage for one room.
  • Integrated Wired and Wireless Connectivity
    The HP 317 Access Device Series integrates a single radio 802.11b/g wireless access point with four Ethernet ports in a single device making them ideal for hotel rooms and dormitories.Provides four Ethernet ports and a pass through RJ45 port to support IPTV, VoIP phones or refrigerators.
  • Simplified Deployment and Reduced Costs
    The HP 317 Access Device Series requires only a single Power over Ethernet (PoE) cable drop, reducing cabling, switch ports, and power sourcing.Supports a pass-through port as well as PoE out, reducing additional power needs for IP-based VoIP phones.Provides wireless coverage for one room reducing the need for site surveys.Support industry leading Limited Lifetime Warranty 2.0 with 3 year 24x7 phone support.
  • Comprehensive Security
    The HP 317 Access Device Series protects wireless traffic between authenticated clients and the access point with 802.1X port based authentication.Locks out unauthorized wireless access by authenticating users prior to granting network access delivering higher security and data integrity of the wireless traffic with either Advanced Encryption Standard (AES) or Temporal Key Integrity Protocol (TKIP).Prevents communication between wireless devices associated with the same access point through local wireless bridge client traffic filtering.
HPE MSM317 Access Device WW - radio access point - Wi-Fi
Radio access point
External
Ports Qty
5
IEEE 802.11b, IEEE 802.11g
Power Over Ethernet (PoE) Supported
PoE
7.1 cm x 7.6 cm x 2.8 cm
150 g
Radio access point
7.1 cm
7.6 cm
2.8 cm
150 g
External
Ports Qty
5
Wireless
Data Transfer Rate
54 Mbps
Communication Mode
Half-duplex, full-duplex
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11d, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.3at
5 x 100Base-TX - RJ-45 , 1 x 100Base-TX - RJ-45 , 1 x management - RJ-45
IEC 60950, UL 60950, EN55022 Class B, ICES-003 Class B, FCC Part 15 B, FCC Part 15.247, OET 65 C, RSS-210, RSS-102, MIC, UL 2043, EN 60950-1, CSA C22.2 No. 60950-1-03, CSA C22.2 No. 950, FCC Part 15.407, EN 60601-1-2, ARIB STD-T66, ARIB STD-T71, RCR STD-33, EN 300 328, EN 301 489-1, EN 301 893, EN 301 489-17
PoE
5 - 95%
Resources
The following resources are available for the Aruba HP ProCurve MSM317 WW Access Device
