Aruba HP 425 Wireless 802.11n (WW) Access Point
Quicklinx: 9JXRWS00 Mfr#: JG654A
  • IEEE 802.11n
The HPE 425 802.11n Dual Radio Access Point Series works in unison with HPE network controllers to deliver a high performance WLAN solution. Offering two spatial stream access and up to 300 Mbps of throughput per radio, they are ideal for voice and multi-media communications and offer embedded high gain and optional external antennas for improved wireless coverage and reliability. Built-in spectral analysis and integrated wireless IDS/IPS provides detection, classification and intelligent avoidance of non-IEEE 802.11 interference and comprehensive threat protection.
  • Enhanced Wi-Fi Performance
    The HPE 425 802.11n Dual Radio Access Point Series offers dual radio, two spatial stream access, supporting up to 300 Mbps per radio for enhanced voice and rich media applications.Supports both centralized and distributed traffic forwarding offering enhanced application performance and WLAN scalability.Provides advanced Quality of Service (QoS) for voice and video communication supporting IEEE 802.1p traffic priority handling and Spectralink Voice Priority (SVP).Extends network availability with self-healing, self-optimizing local mesh.
  • Improved Coverage and Reliability
    The HPE 425 802.11n Dual Radio Access Point Series optimizes WLAN coverage and reliability with Wi-Fi Clear Connect automatic power adjustment capability, providing real-time identification of interference, and intelligent channel switching.Enhances the user experience with airtime fairness, providing equal RF transmission time for wireless clients in mixed user environments.Improves client performance by automatically redirecting 5 GHz-capable clients to the less-congested 5 GHz spectrum with band steering.Improves wireless coverage in dense client environments with embedded high gain internal antennas and optional external antennas.
  • Comprehensive Security
    The HPE 425 802.11n Dual Radio Access Point Series provides comprehensive threat protection with an integrated Intrusion Detection System (IDS) offering granular threat detection and location tacking capabilities.Simplifies client authentication with support for both internal and external authentication, authorization and accounting servers (AAA), per user VLAN mapping and authentication.Locks out unauthorized wireless access by authenticating users prior to granting network access. Enhance data integrity of the wireless traffic with Advanced Encryption Standard (AES) or Temporal Key Integrity Protocol (TKIP).
  • Investment Protection
    The HPE 425 802.11n Dual Radio Access Point Series provides a Limited Lifetime Warranty.Provides interoperability with all IEEE 802.11a/b/g/n client devices through Wi-Fi Alliance certifications.
HPE 425 (WW) - radio access point - Wi-Fi
Radio access point
External - indoor
1 x 560 MHz
RAM
128 MB
Flash Memory
128 MB
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
2 x ceiling mounting clip
Power Over Ethernet (PoE) Supported
PoE
18.86 cm x 18.86 cm x 5.08 cm
750 g
Radio access point
Ruggedized Design
Indoor
18.86 cm
18.86 cm
5.08 cm
750 g
Processor / Memory / Storage
Processors Installed
1 x 560 MHz
RAM
128 MB
Flash Memory
128 MB
External
Wireless
Data Transfer Rate
300 Mbps
Network / Transport Protocol
DHCP
Remote Management Protocol
SNMP 3, SNMP 2c
Communication Mode
Half-duplex, full-duplex
Frequency Band
2.4 GHz, 5 GHz
DHCP support, VPN support, VLAN support, auto-uplink (auto MDI/MDI-X), DiffServ support, Intrusion Detection System (IDS), wall mountable, Wi-Fi Multimedia (WMM) support, SpectraLink Voice Priority (SVP) support, Quality of Service (QoS), plenum-rated, ceiling mountable, Wi-Fi Clear Connect, Virtual Service Community (VSC)
Encryption Algorithm
AES, SSL, TKIP, WPA, WPA2, WEP
Authentication Method
RADIUS
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11n
Aerial
Antenna
Internal
Antenna Qty
4
Directivity
Omni-directional
1 x 1000Base-T - RJ-45 , 1 x management - RJ-45
EN55022 Class B, ICES-003 Class B, FCC Part 15 B, FCC Part 15.247, OET 65 C, RSS-210, RSS-102, UL 2043, FCC, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, FCC CFR47, FCC Part 15.407, EN 60601-1-2, ARIB STD-T66, ARIB STD-T71, RCR STD-33, iDA, EN 300 328, EN 301 489-1, EN 301 893, CAN/CSA-C22.2 No. 60950-1, EN 301 489-17
PoE
External power adapter (not included)
Max Supported Qty
1
Software Included
HP Intelligent Management Center, HP Wireless Services Manager
Limited warranty - lifetime - response time: next business day , Technical support - phone consulting - lifetime
45 °C
5 - 95% (non-condensing)
9JXR C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.68
9JXR C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.87
