The Aruba 330 Series access points provide the fastest gigabit data speeds and superb user experience for mobile devices and applications in a digital workplace. Designed with an integrated HPE Smart Rate port to scale up to 2.5Gbps Ethernet over existing copper, the 330 Series allows enterprises to leverage their multi-gigabit Ethernet wired network infrastructures to eliminate bottlenecks. These Wave 2 access points deliver multi-user MIMO (MU-MIMO) aware ClientMatch to boost network efficiency and support the growing device density demands on your network.
Multi-gig Ethernet
Leverage wired multi-gig NBASE-T -compatible Ethernet infrastructure to eliminate bottlenecks in high-density environments. -
ClientMatch unleashes MU-MIMO
Aruba ClientMatch software groups Wave 2 clients together, enabling 4x4:4SS MU-MIMO. That means a faster, more efficient network. -
Integrated Bluetooth Beacon
330 series APs have an integrated BLE Beacon to simplify management of a large-scale network of battery-powered Aruba Beacons.
- HPE Aruba AP 334 - radio access point - Wi-Fi 5
- Radio access point
- Form Factor
- External
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- Power Over Ethernet (PoE) Supported
- PoE
- Power
- DC 48 V
- 22.5 cm x 22.4 cm x 5.2 cm
- 1.15 kg
- Limited lifetime warranty
- 22.5 cm
- 22.4 cm
- 5.2 cm
- 1.15 kg
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 1733 Mbps
- Line Coding Format
- CCK, 64 QAM, 256 QAM, BPSK, QPSK, 16 QAM
- Spread Spectrum Method
- OFDM, DSSS
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- System, status
- Auto-uplink (auto MDI/MDI-X), DFS support, reset button, Maximum Ratio Combining (MRC), Low Density Parity Check (LDPC), Transmit Beam-forming (TxBF) ready, Energy Efficient Ethernet, Cyclic Delay Diversity (CDD), Space Time Blocking Code (STBC), Advanced Cellular Coexistence (ACC), cyclic shift diversity (CSD), Aruba Beacons Bluetooth Low-Energy (BLE) technology
- IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az, IEEE 802.11ac
- 1 x 1000Base-T - RJ-45 , 1 x 2500Base-T - RJ-45 , 1 x USB 2.0 - Type A , 1 x console - RJ-45 , 4 x aerial - RP-SMA
- MTBF
- 531,662 hours
- EN 60950, IEC 60950, UL 60950, CB, UL 2043, FCC, EN 60601-1-2, cTUVus, EN 300 328, EN 301 489, EN 60601-1-1, LVD 72/23/EEC, R&TTE Directive 1999/5/EC, EN 301 893
- PoE
- Voltage Required
- DC 48 V
- 25 Watt
- Limited warranty - lifetime
- 0 °C
- 50 °C
- 5 - 95% (non-condensing)
