Aruba AP-303H (RW) Unified Access Point
Quicklinx: FBKKWS00 Mfr#: JY678A
  • IEEE 802.11n
£397.03 ex VAT
£476.43 inc VAT
With a maximum concurrent data rate of 867Mbps in the 5GHz band and 400Mbps in the 2.4GHz band, Aruba 303H Unified Hospitality Access Points deliver high-performance Gigabit Wi-Fi for hospitality and branch environments at an attractive price point. It supports multi-user MIMO (MU-MIMO) and 2 spatial streams (2SS) to provide simultaneous data transmission for up to two devices, maximizing data throughput and improving network efficiency. The Aruba 303H AP combines wireless and wired access in a single compact device. Three local Gigabit Ethernet ports are available to securely attach wired devices to your network. One of these ports is also capable of supplying PoE power to the attached device. This multi-functional Wave 2 access point delivers best-in class Wi-Fi connectivity for hospitality and branch offices, enabling an always-on user experience with low total cost of ownership (TCO).
  • Cost-effective Wave 2 Access Point
    HPE Aruba Networking 303H Unified Hospitality Access Points, the successor of the existing HPE Aruba Networking 205H access points, provide richer feature sets to benefit customers.Lower unit price when compared to the existing 205H AP, making this AP ideal for customers who want to replace the existing 205H or expand their networks.
  • Flexible Deployment Options
    HPE Aruba Networking 303H Unified Hospitality Access Points support various mount options including wall, wall box and desk mount, fitting into different environments nicely and conveniently.Three local GbE ports can be used to connect wired devices to the network and provide POE power, giving the flexiblity and stability for users in branch offices and remote stations.Powered by IEEE 802.3af PoE or 48V DC power.
HPE Aruba AP-303H (RW) Unified Hospitality - radio access point - Wi-Fi 5
Radio access point
External - indoor
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Performance
Concurrent data rate (5 GHz): 867 Mbps , Concurrent data rate (2.4 GHz): 400 Mbps
Wireless clients per Wi-Fi radio: 255 , BSSIDs per radio: 16
Single-gang wall-box
15 cm x 8.6 cm x 4 cm
310 g
Radio access point
Ruggedized Design
Indoor
15 cm
8.6 cm
4 cm
310 g
External
Wireless
Data Transfer Rate
867 Mbps
Line Coding Format
CCK, 64 QAM, 256 QAM, BPSK, QPSK, 16 QAM
Spread Spectrum Method
OFDM, DSSS
Frequency Band
2.4 GHz, 5 GHz
Performance
Status Indicators
Power, system, status
Auto-uplink (auto MDI/MDI-X), DFS support, Quality of Service (QoS), Trusted Platform Module (TPM), reset button, 2T2R MIMO technology, Maximum Ratio Combining (MRC), Low Density Parity Check (LDPC), Transmit Beam-forming (TxBF) ready, Cyclic Delay Diversity (CDD), Space Time Blocking Code (STBC), Advanced Cellular Coexistence (ACC), cyclic shift diversity (CSD), MU-MIMO technology, enhanced ClientMatch, Aruba Beacons Bluetooth Low-Energy (BLE) technology, wireless intrusion protection
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az, IEEE 802.11ac
Aerial
Antenna
Internal
Antenna Qty
2
Directivity
Directional
Gain Level
5.6 dBi
1 x 1000Base-T (uplink) - RJ-45 , 2 x 1000Base-T - RJ-45 , 1 x 1000Base-T (PoE) , 1 x USB 2.0 - Type A , 1 x console
MTBF
1,090,000 hours
EN 60950, IEC 60950, UL 60950, CB, UL 2043, FCC, EN 60601-1-2, cTUVus, EN 300 328, EN 301 489, EN 60601-1-1, LVD 72/23/EEC, EN 301 893, R&TTE Directive 1995/5/EC
15.6 Watt
Limited warranty - lifetime
5 - 93% (non-condensing)
Type: Radio access point
Connectivity: Wireless
Speed: 867Mbps
Protocol: IEEE 802.11n
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Brand: Aruba
