The Aruba 2530 Switch Series provides security, reliability, and ease of use for enterprise edge, branch office, and SMB deployments. Fully managed switches deliver Layer 2 capabilities with optional PoE+, optional 10GbE uplinks, enhanced access security, traffic prioritization, sFlow, IPv6 host support, and power savings with Energy Efficient Ethernet. The Aruba 2530 Switch Series is easy to use and deploy, and delivers consistent wired/wireless user experience with unified management tools such as ClearPass Policy Manager and Airwave Network Management.
                Cost-Effective, Reliable and Secure Access Layer SwitchesThe HPE Aruba Networking 2530 Switch Series provides security, reliability, and ease of use for enterprise edge, branch office, and SMB deployments.Fully managed switches deliver full Layer 2 capabilities with optional PoE+, enhanced access security, traffic prioritization, sFlow, and IPv6 host support.Right size deployment with choice of 8-, 24-, and 48-port models available with Gigabit or Fast Ethernet ports, and optional PoE+.Power savings with fanless models, Energy Efficient Ethernet (IEEE 802.3az), and ability to disable LEDs and enable port low power mode.Delivers consistent wired/wireless user experience with unified security and management tools like ClearPass Policy Manager, AirWave and cloud-based Central. Provides optimal configuration automatically when connected to HPE Aruba APs for PoE priority, VLAN configuration, and rogue AP containment.
                Security and Quality of Service (QoS)The HPE Aruba Networking 2530 Switch Series supports flexible authentication methods including Local MAC, 802.1X, and MAC and Web for greater policy-driven application security.Advanced denial of service (DOS) protection, such as DHCP Protection, Dynamic ARP protection, and Dynamic IP lockdown, enhance security. Flexible traffic controls include ACLs and QoS.Traffic prioritization with IEEE 802.1p allows real-time traffic classification with support for eight priority levels mapped to either two or four queues using weighted deficit round robin (WDRR) or strict priority (SP).Defend your IPv6 network with DHCPv6 Protection.
                Simple Deployment and ManagementThe HPE Aruba Networking 2530 Switch Series supports a choice of management interfaces with Web GUI, command-line interface (CLI), and SNMP with either console or micro USB ports.Quiet operation with fanless and variable speed fan models.Flexible deployment with wall, table, and rack mounting options.Zero touch provisioning (ZTP) provides quick and painless deployment at locations with few or no technical resources.
                Single View of the NetworkThe HPE Aruba Networking 2530 Switch Series supports HPE Aruba Networking ClearPass Policy Manager for unified and consistent policy between wired/wireless users and simplifies implementation and management of guest login, user onboarding, network access, security, QoS, and other network policies.Supports HPE Aruba Networking AirWave network management software to provide common platform for zero touch provisioning management, and monitoring for wired and wireless network devices.RMON and sFlow provide advanced monitoring and reporting capabilities for statistics, history, alarms, and events.HPE Aruba Networking Central cloud-based management platform offers simple, secure, and cost effective way to manage switches.Supports both cloud-based HPE Aruba Networking Central and on-premise HPE Aruba Networking AirWave with the same hardware ensuring change of management platform without ripping and replacing switching infrastructure.
- HPE Aruba 2530-48G-PoE+ - switch - 48 ports - Managed - rack-mountable
- Switch - 48 ports - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000 (PoE+) + 4 x Gigabit SFP
- Power Over Ethernet (PoE)
- PoE+
- Performance
- Throughput: 77.3 Mpps , Switching capacity: 104 Gbps
- MAC Address Table Size
- 16000 entries
- Jumbo Frame Support
- 9220 bytes
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, TFTP, SSH-2, CLI
- Flow control, DHCP support, BOOTP support, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), port mirroring, IPv6 support, half duplex mode, full duplex mode, SNTP support, sFlow, MSTP support, ACL support, Multicast Suppression, STP Root Guard, LLDP support, dual firmware images, CoS, GARP
- IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- 44.3 cm x 32.26 cm x 4.45 cm
- 4.72 kg
- Enclosure Type
- Desktop, rack-mountable, wall-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- Performance
- 16000 entries
- 9220 bytes
- Encryption Algorithm
- SSL
- Authentication Method
- RADIUS, TACACS+, Secure Shell v.2 (SSH2)
- Processor
- 1 x ARM: 800 MHz
- RAM
- 256 MB DDR3 SDRAM
- Flash Memory
- 128 MB
- 48 x 1000Base-T RJ-45 PoE+ , 4 x SFP , 1 x management RJ-45
- Power Device
- Internal power supply
- Voltage Required
- FCC Class A certified, CISPR 22 Class A, CISPR 24, EN 61000-3-2, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, VCCI Class A ITE, EN 61000-3-3, EN55024, EN55022 Class A, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1
- 44.3 cm
- 32.26 cm
- 4.45 cm
- 4.72 kg
- 0 °C
- 45 °C
- 15 - 95% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 15 - 90% (non-condensing)
|  | C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.73 |
|  | C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £12.76 |
|  | Aruba SFP Transceiver Module 1000Base | In Stock | £123.50 |
