Aruba 10G SFP+ LC SR 300m MMF XCVR
Quicklinx: DMKVWS00 Mfr#: J9150D
43 In Stock
£400.98 ex VAT
£481.17 inc VAT
10G SFP+ transceiver, LC SR 300m OM3 MMF, for use with selected Aruba switches
  • Enhanced connectivity
    The HPE Aruba SFP+ transceiver module offers a high-speed 10 Gigabit Ethernet connection that ensures rapid data transfer rates of up to 10 Gbps, making it suitable for high-bandwidth applications.
  • Broad compatibility
    Featuring an LC multi-mode connector, this transceiver module is designed to facilitate seamless integration with a wide range of networking equipment, ensuring a flexible solution for your connectivity needs.
  • Extended reach
    With a maximum transfer distance of 300 m, the HPE Aruba SFP+ transceiver module is perfect for extending your network reach, making it suitable for a variety of enterprise environments.
HPE Networking Instant On - SFP+ transceiver module - 10GbE
SFP+ transceiver module - SFP+ / LC multi-mode
Plug-in module
Cabling Type
10GBase-SR
Data Transfer Rate
10 Gbps
10GbE
Max Transfer Distance
300 m
HPE Aruba 2540 24, 2540 48, 2930F 12, 2930F 24, 2930F 48, 2930F 8G, 2930M 24, 2930M 40, 2930M 48, 3810M 24, 3810M 40, 3810M 48, 5406R 16, 5406R 44, 5406R 8-port, 5406R zl2, 5412R 92, 5412R zl2, 54XX, 6200F 12, 6200M 24, 6300, 6405 48, 6405 96, 64XX, 70XX, 72XX, 83XX, 8400, 8400 8-slot; CX 8360
Plug-in module
Wired
Cabling Type
10GBase-SR
10GbE
Data Transfer Rate
10 Gbps
300 m
1 x Ethernet 10GBase-SR - LC multi-mode
OM3
HPE Aruba 2930F 12G PoE+ 2G/2SFP+, 2930F 8G PoE+ 2SFP+ TAA, 2930M 24 Smart Rate POE+ 1-Slot, 2930M 24G 1-Slot, 2930M 24G POE+ 1-Slot, 2930M 40G 8 HPE Smart Rate PoE Class 6 1-slot Switch, 2930M 40G 8 HPE Smart Rate PoE+ 1-slot Switch, 2930M 48G 1-Slot, 2930M 48G POE+ 1-Slot, 3810M 24SFP+ 250W, 3810M 48G PoE+ 4SFP+ 1050W, 3810M 48G PoE+ 4SFP+ 680W, 6200F 12G Class4 PoE 2G/2SFP+ 139W Switch, 6200F 12G Class4 PoE 2G/2SFP+ 139W TAA Switch, 6200M 24G Class4 PoE 4SFP+, 6300F, 6300M, 6405 48SFP+ 8SFP56, 6405 96G CL4 PoE 4SFP56, 6405 Switch Bundle, 6410, 6410 Switch Bundle, 7005 (IL) FIPS/TAA-compliant Controller, 7005 (JP) Controller, 7005 (JP) FIPS/TAA Controller, 7005 (RW) FIPS/TAA-compliant Controller, 7005 (US) FIPS/TAA Controller, 7005 Cloud Service Controller, 7010 (IL) Controller, 7010 (JP) FIPS/TAA Controller, 7010 (RW) FIPS/TAA-compliant Controller, 7024 (JP) FIPS/TAA Controller, 7024 (RW) FIPS/TAA-compliant Controller, 7024 (US) Controller, 7024 (US) FIPS/TAA Controller, 7030 (JP) FIPS/TAA Controller, 7030 (RW) FIPS/TAA-compliant Controller, 7030 (US), 7030 (US) Controller, 7030 (US) FIPS/TAA Controller, 7205 (IL) FIPS/TAA-compliant Controller, 7205 (JP) Controller, 7205 (JP) FIPS/TAA Controller, 7205 (RW) FIPS/TAA-compliant Controller, 7205 (US), 7205 (US) Controller, 7205 (US) FIPS/TAA Controller, 7210 (JP) FIPS/TAA Controller, 7210 (RW) FIPS/TAA-compliant Controller, 7210 (US), 7210 (US) FIPS/TAA Controller, 7210DC (JP) Controller, 7210DC (US) Controller, 7220 (JP) Controller, 7220 (RW) FIPS/TAA-compliant Controller, 7220 (US) FIPS/TAA Controller, 7220DC (IL) Mobility Controller, 7220DC (US) Controller, 7240 (RW) FIPS/TAA-compliant Controller, 7240 (US) FIPS/TAA Controller, 7240XM (IL) FIPS Controller, 7240XM (JP) FIPS/TAA Controller, 7240XM (RW) FIPS Controller, 7240XM (US) FIPS Controller, 8320, 8325-32C, 8325-48Y8C, 8400 8-slot Chassis, 8400 Management Module , HPE Aruba CX 8360-12C V2, 8360-16Y2C V2
Brand: Aruba
