Aruba 105 Wireless Access Point
Quicklinx: 940QWS00 Mfr#: AP-105
  • IEEE 802.11n
The AP-105 is a high-speed, affordable, and reliable 802.11n access point for indoor environments. Designed for both ceiling and wall mounting, the compact AP-105 delivers wire-like performance at data rates up to 300Mbps per radio.
The AP-105 delivers high-speed, secure network services that let users finally move to a "wireless where possible, wired where necessary" network access model. The network can then be right sized, with unnecessary ports eliminated to lower operating costs. The key to rightsizing is Aruba's unique Adaptive Radio Management technology, which manages channel, power, and wireless client behavior to deliver wire-like performance and reliability. By rightsizing network infrastructure, organizations significantly enhance user mobility and efficiency while lowering total cost of ownership.
The multifunction AP-105 can be configured through the controller to provide wireless LAN access, air monitoring, remote networking, secure enterprise mesh, and wireless intrusion detection and prevention over the 2.4GHz and 5GHz RF spectrum. The AP-105 features a 100/1000Base-T Ethernet interface and operates from either standard 802.3af Power over Ethernet (PoE) sources or a 12VDC power supply.
HPE Aruba AP 105 - radio access point - Wi-Fi
Radio access point
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Power Over Ethernet (PoE) Supported
PoE
13.2 cm x 13.5 cm x 4.5 cm
299 g
Radio access point
13.2 cm
13.5 cm
4.5 cm
299 g
External
Wireless
Data Transfer Rate
300 Mbps
Spread Spectrum Method
OFDM, DSSS
Auto-uplink (auto MDI/MDI-X), MIMO technology, Trusted Platform Module (TPM)
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n
Aerial
Antenna
Internal
Directivity
Omni-directional
1 x 1000Base-T - RJ-45 , 1 x management - RJ-45
VCCI, EN 60950, NOM, IEC 60950, UL 60950, CB, CCC, MIC, UL 2043, FCC, R&TTE, ANATEL, cTUVus, EN 300 328, EN 301 893
PoE
External power adapter
12.5 Watt
Limited warranty - lifetime
50 °C
5 - 95%
