Arlo VMS3430 Video Server + Camera(s) - Wireless - 4 Cameras CMOS
Quicklinx: CHLWWS00 Mfr#: VMS3430-100EUS
With an Arlo system, you'll have everything you need to get started. Just connect the base station to your Wi-Fi router, sync your cameras, fire up the free Arlo app, and you’re done in minutes. Make sure to upgrade your service plan and add more cameras to make the most out of your system.
  • Robust design
    Designed to withstand the elements, the Arlo VMS3430 cameras are compliant with IP65 standards, ensuring they are protected against dust and water. This makes them suitable for outdoor use, regardless of the weather conditions.
  • Enhanced connectivity
    With a wireless frequency band of 2.4 GHz, the Arlo VMS3430 offers reliable connectivity, allowing for seamless video transmission without the need for cumbersome cables. This wireless design simplifies installation and provides flexibility in camera placement.
  • Efficient night vision
    Equipped with advanced night vision capabilities, the Arlo VMS3430 cameras ensure clear video quality even in complete darkness. This feature enhances the security of your premises by providing round-the-clock surveillance.
  • Efficient operation
    The video server of the Arlo VMS3430 comes with an LED indicator, 16 MB of flash memory, and 64 MB of RAM, ensuring efficient operation and smooth video streaming. This setup supports the H.264 compression format, optimizing storage without compromising video quality.
Arlo VMS3430 - video server + camera(s) - wireless
System
Video server + camera(s) - wireless - 2.4 GHz
Camera
4 cameras - outdoor - night vision
System
Wireless Frequency Band
2.4 GHz
Package Content
4 cameras, power adapter, 4 magnetic mounts, 4 mounting screws, window decal, 16 lithium batteries (CR123)
Network cable - 1 pcs.
Security DVR
Compression Format
H.264
Video Server
RAM
64 MB
Flash Memory
16 MB
LED indicator
Cameras
Quantity
4 cameras
Camera Type
Outdoor
Sensor
CMOS
Field of View
130°
Night Vision
Infrared Distance
7.5 m
White Balance
Auto
-10 °C
50 °C
IP65
Network Port
10/100Base-T
Details
Video server: 21.6 cm x 16.5 cm x 5.72 cm - 113 g , Camera: 4.1 cm x 7.1 cm x 6.4 cm - 113 g
