Enjoy the peace of mind that comes from knowing your home is safe and secure. Built with advanced 4K resolution and a wider field of view, Arlo Ultra 2 provides powerful, wire-free security to protect your loved ones.
4K Video with HDR:
Zoom in up to 12x to see sharp details with Arlo Ultra’s 4K & HDR advanced image quality technology.
Enhanced night vision:
Color night vision lets you see key details even in the dark
180 degree diagonal field of view:
See more with a wider angle lens that has auto image correction reducing the fish eye effect.
Integrated spotlight:
Scare off unwelcome guests using Arlo Ultra’s motion-activated spotlight.
Weather-resistant
Built to withstand heat, cold, rain or sun.
Versatile magnetic charging.
The magnetic charging cable snaps into place for continuous power all day.
100% wire-free with 6-month battery life
100% wire-free with 6-month battery life on one charge you can easily install your camera to watch over the most vulnerable parts of your property.
Premium 2-way Audio:
Listen and speak to visitors with crystal clear, full 2-way audio that reduces wind and noise
Built-in smart siren:
Trigger the siren from the Arlo app or have it sound automatically when motion is detected to scare away intruders.
4K with HDR
Zoom 12x with 180° view and auto image correction. -
Motion alerts
Get alerts to your phone if motion is detected. -
Auto zoom and tracking
Auto-focus and follow moving objects.
- Arlo Ultra 2 Security System - gateway + camera(s) - wireless (802.11b, 802.11g, 802.11n, 802.11ac, Bluetooth 4.2 LE) - battery powered, AC powered
- System
- Gateway + camera(s) - wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2 LE - battery, power adapter
- Camera
- 4 cameras - outdoor - night vision
- Platform
- Apple HomeKit, SmartThings
- Intelligent Assistant
- Google Assistant, Alexa
- Localisation
- Europe
- 1 year
- System
- Network Interface
- Built-in microphone, built-in speaker, auto focus, motion alerts, upload to cloud, microSD card slot, infrared cut filter, motion detection, weather-resistant, Smart Siren, colour night vision, 4K Ultra HD video, High Dynamic Range (HDR), two-way audio support, spotlight, 12x digital zoom, movement tracking, up to 6 months battery lifetime
- Package Content
- 4 cameras, camera wall mount, power adapter, magnetic charging cable, video monitoring decal, SmartHub, 4 rechargeable batteries, screw kit
- Cables Included
- Network cable - 1 pcs.
- Power Source
- Battery, power adapter
- Localisation
- Europe
- IC, FCC, AES-128, 128-bit SSL, REACH, EU RoHS, WERCS, EuP1275
- Warranty
- 1 year
Cameras
- Quantity
- 4 cameras
- Camera Type
- Outdoor
- Sensor
- 1/2" - 3840x2160
- Field of View
- 151° (H), 80° (V), 180° (D)
- Night Vision
- Infrared LEDs
- -20 °C
- 45 °C
- IP65
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Platform
- Compatible Services
- IFTTT
- Details
- Camera: 5.2 cm x 8.9 cm x 7.84 cm - 331 g , Gateway: 14 cm x 5.24 cm x 15.3 cm - 300 g
