Enjoy the peace of mind that comes from knowing your home is safe and secure. Built with advanced 4K resolution and a wider field of view, Arlo Ultra 2 provides powerful, wire-free security to protect your loved ones.
4K Video with HDR:
Zoom in up to 12x to see sharp details with Arlo Ultra’s 4K & HDR advanced image quality technology.
Enhanced night vision:
Color night vision lets you see key details even in the dark
180 degree diagonal field of view:
See more with a wider angle lens that has auto image correction reducing the fish eye effect.
Integrated spotlight:
Scare off unwelcome guests using Arlo Ultra’s motion-activated spotlight.
Weather-resistant
Built to withstand heat, cold, rain or sun.
Versatile magnetic charging.
The magnetic charging cable snaps into place for continuous power all day.
100% wire-free with 6-month battery life
100% wire-free with 6-month battery life on one charge you can easily install your camera to watch over the most vulnerable parts of your property.
Premium 2-way Audio:
Listen and speak to visitors with crystal clear, full 2-way audio that reduces wind and noise
Built-in smart siren:
Trigger the siren from the Arlo app or have it sound automatically when motion is detected to scare away intruders.
Stay better informed with clearer details
Thanks to advanced 4K resolution with HDR, watch and record video with picture-perfect detail and color. -
See who's there in color, even at night
Capture the full picture in low light with enhanced color night vision. -
Never miss a thing with an ultra-wide view
The wider-angle lens gives you an ultra-wide 180° view of your property, while auto-correcting the image to remove fisheye distortion. -
Enjoy peace of mind when it's dark
Ward off would-be intruders by activating the integrated spotlight manually, or automatically when motion is detected. -
Pick up hard-to-see details with a closer look
Zoom in on video up to 12x closer with amazing clarity. -
Weather-resistant for year-round security
Designed to withstand heat, cold, rain, or sun. -
Keep setup fast and easy
Quickly install and adjust your camera in more ways, wire-free, using the magnetic mounts. -
The magnetic charging cable snaps into place for continuous power all day. -
Charge less with a long-lasting battery
Get 6 months of battery life on one charge using the convenient rechargeable battery. -
Respond to visitors, from anywhere
Listen and speak to visitors from your phone with crystal-clear, 2-way audio that reduces wind and noise. -
Quickly deter unwanted guests
Trigger the built-in smart siren automatically or manually from the Arlo app.
- Arlo Ultra 2 Security System - gateway + camera(s) - wireless (802.11b, 802.11g, 802.11n, 802.11ac, Bluetooth 4.2 LE)
- System
- Gateway + camera(s) - wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2 LE
- Camera
- 3 cameras - outdoor - night vision
- Platform
- Google Home, Apple HomeKit, SmartThings
- Intelligent Assistant
- Alexa
- White
- Localisation
- Europe
- 1 year
- System
- Network Interface
- microSD card slot, motion detection, 4K Ultra HD video, High Dynamic Range (HDR), two-way audio support, spotlight, 12x digital zoom, built-in siren, colour night vision, weather-resistant
- Package Content
- 3 cameras, power adapter, 3 rechargeable batteries, magnetic charging cable, SmartHub, video monitoring decal, 3 camera wall mounts, magnetic mounting bracket
- Cables Included
- Network cable - 1 pcs.
- White
- Localisation
- Europe
- Warranty
- 1 year
Cameras
- Quantity
- 3 cameras
- Camera Type
- Outdoor
- Sensor
- 1/2" - 8 Megapixel
- Field of View
- 180°
- Night Vision
- Voltage
- DC 5 V
- Current Consumption
- 2 A
- -20 °C
- 45 °C
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Platform
- Compatible Application
- IFTTT App
- Alexa
- Details
- Camera: 5.2 cm x 8.9 cm x 7.84 cm - 331 g , Gateway: 14 cm x 5.24 cm x 15.3 cm - 300 g
