Arlo Pro 5 Spotlight Security Camera - 4 Camera Kit - White
Quicklinx: HF1ZWS00 Mfr#: VMC4460P-100EUS
£583.33 ex VAT
£699.99 inc VAT
Capture more than 60 billion colours with our advanced 2K colour night vision that’s over 100X better than a human eye. With up to 30% more battery life and dual band Wi-Fi connectivity, instantly connect direct to any Wi-Fi router for 24/7 protection. Protect your home day and night and customise your security via the NEW Arlo Secure app.
Colour night vision that's better than a human eye
With up to 30% more battery life and dual band connectivity, instantly connect direct to any Wi-Fi router for 24/7 protection.
Advanced 2K Colour Night Vision?
Capture over 60 billion colours with our advanced 2K colour night vision that’s over 100X better than a human eye.
Advanced Colour Night Vision
24/7 full colour video accuracy means better identification of clothes and distinctive features, which could make all the difference when it comes to evidence.
Field of View
Big garden? Large driveway? With an extra-wide 160° field of view you can keep an eye on the places other security cameras don’t see.
Real-time Talk
Built in speaker & microphone lets you speak to family and visitors or warn off intruders as if you were there yourself.
Dual-Band Wi-Fi
The Arlo Pro 5 connects to both major networks (2.4GHz and 5GHz ) making set-up easier and optimising your camera for range and speed.
Loud Siren
Scare off intruders with the built-in 80 db smart siren that can be heard up to 30 metres away. Have it automatically go-off if motion is detected or trigger from the app to quickly raise the alarm.
  • See sharper details with 2K HDR video
    Everything in picture-perfect detail with the power to zoom 12x on every image to make out faces or license plates.
  • Extended battery life with low power mode
    Stay connected longer on one charge with a mode that maximizes battery life.
  • Seamless setup with dual-band Wi-Fi
    Setting up your camera is easy with dual-band Wi-Fi that supports 2.4 and 5Ghz Wi-Fi and automatically connects to the stronger network.
  • Wire-free installation is easier than ever
    Enjoy a simpler DIY setup that avoids all the complicated wires and will ensure your home security is up and running in minutes.
  • All-weather protection all of the time
    Designed to withstand every outdoor element and built for all kinds of weather like heat, cold, rain, sun and more.
  • See the bigger picture with 160° views
    When you have a wider view of security, you are able to protect more. Every shot is auto corrected to reduce any fisheye effect and deliver true-to-life imagery.
  • More detail after dark
    With color night vision, you'll see critical details that are almost as distinctive as the daytime.
Arlo Pro 5 - network surveillance camera
Network surveillance camera - fixed - indoor, outdoor - weatherproof
Packaged Quantity
4 (specifications are for single item)
Audio
Yes: two-way audio capability, built-in microphone
Camera Mount Type
Wall mount
5.2 cm x 8.9 cm x 7.84 cm
316 g
White
Wireless
Camera
Colour - Day&Night
Motion Detection
Video Modes
2K, 1080p, 720p
IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Platform
Apple HomeKit
Intelligent Assistant
Alexa, Google Assistant, Apple HomeKit - indirect
1 - magnetic charging cable
High Dynamic Range (HDR), 160° field of view, Colour Night Vision, built-in spotlight, infrared-cut filter, auto tracking, Auto Zoom, 130-degree motion detection angle, de-warping
1-year warranty
Environmental Parameters (operating)
-20 °C - 45 °C
Packaged Quantity
Audio Support
Camera Mount Type
Wall mount
Wireless
5.2 cm
8.9 cm
7.84 cm
316 g
Europe
Camera
Colour - Day&Night - fixed - indoor, outdoor - weatherproof
Motion Detection
Video Modes
2K, 1080p, 720p
Digital Zoom
12
Infrared LEDs
2
Lens Construction
Horizontal Field of View (degree)
130
Network Interface
Magnetic charging cable, rechargeable battery, wall mount kit, window decal
1 x magnetic charging cable
IP65
White
1 lithium polymer 4800 mAh (up to 8 months)
Software Included
Arlo Secure (30 days trial)
Internet of Things (IoT)
Platform
Apple HomeKit
Compatible Application
IFTTT App, Samsung SmartThings
Supported Host Device Platform
Android, iOS
Voice Controlled
Indirect
Limited warranty - 1 year
Shipping Width
16.7 cm
Shipping Depth
29.7 cm
Shipping Height
15.7 cm
Shipping Weight
2.2 kg
-20 °C
45 °C
Type: Indoor / Outdoor Camera
Compatible With: Alexa
Compatible With: Apple HomeKit
Brand: Arlo
Price Range Ex VAT: £500 - £750
