Arlo Go Mobile HD Security Camera
Quicklinx: DF3NWS00 Mfr#: VML4030-100UKS
Type: Outdoor Camera
Compatible With: Alexa, Google Assistant
  • microSDHC Card
  • microSD Card
More than 50 in stock
£307.50 ex VAT
£369.00 inc VAT
The Arlo Go Mobile Security Camera is ideal for security monitoring when traveling or in areas with limited or no Wi-Fi access. Arlo Go works anywhere in AT&T's nationwide coverage and supports 3G and 4G-LTE wireless connections. This allows you to keep an eye on trails, RVs, or your cabin from anywhere, even far away from the nearest power outlet or Wi-Fi connection.
Arlo Go Mobile HD Security Camera - network surveillance camera
Network surveillance camera - fixed - outdoor - weatherproof
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
9 cm x 6.95 cm x 7.79 cm
335 g
Wireless
Camera
Colour - Day&Night
Max Resolution
1280 x 720
Motion Detection
Video Modes
720p
HSUPA, LTE, WCDMA, 3G, 4G, HSDPA, HSPA+
E-mail alerts, Advanced Motion Detection, Push Notification, integrated rechargeable battery, Audio Detection
1-year warranty
Environmental Parameters (operating)
-20 °C - 45 °C
Audio Support
Wireless
9 cm
6.95 cm
7.79 cm
335 g
United Kingdom
Camera
Colour - Day&Night - fixed - outdoor - weatherproof
Digital Video Format
H.264
Max Digital Video Resolution
1280 x 720
Motion Detection
Video Modes
720p
Digital Zoom
8
Infrared LEDs
Infrared Distance
7.6 m
Lens Construction
Horizontal Field of View (degree)
130
Network Interface
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
SIM card, outdoor security mount, 3 screws, window decal
UL, IC, FCC, IP65
3660 mAh
Android, Apple iOS
Limited warranty - 1 year
-20 °C
45 °C
Brand: Arlo
Price Range Ex VAT: 300 - 500
