The world’s first and only 100% wire-free, IP65 Certified Weather-resistant, LTE mobile HD security camera
100% Wire-Free
Place it anywhere. No cords or wiring hassles.
Un-tethered Mobile Security
Arlo Go supports LTE wireless connections and can work anywhere nationwide with LTE coverage.
IP65 certified weather-resistant
Rain or shine, hot or cold, the IP65-certified Arlo Go camera will brave it all.
HD Quality
Live stream and watch recordings in more brilliant detail than ever before.
130° Viewing Angle
See more of every moment with a 130° wide-angle lens.
Rechargeable
Long lasting, takes the expense out of uninterrupted security.
2-Way Audio
Listen in and talk back through the built-in speaker and mic, straight from your smartphone.
Advanced Motion Detection
Wide-angle PIR motion sensor makes sure no movement will slip through without your notice.
Night Vision
Integrated night vision automatically switches on at night to shed light on the smallest wonders.
Cloud Storage
Don't pay for cloud storage that you don't need. Keep 7 days of motion- and audio-triggered recordings.
Local Backup Storage
Built-in SD card slot allows for local backup storage in the event of Internet interruption.
Plays Well with Others
Works with Amazon Alexa, the Google Assistant, IFTTT & Stringify.
Arlo Go is powered by LTE and requires a mobile plan before using.
100% wire-free
Place it anywhere. No cords or wiring hassles. -
HD Quality
Live stream and watch recordings in more brilliant detail than ever before. -
2-way audio
Listen in and talk back through the built-in speaker and mic, straight from your smartphone. -
Cloud storage
Don't pay for cloud storage that you don't need. Keep 7 days of motion- and audio-triggered recordings. -
Un-tethered mobile security
Arlo Go is SIM Card connected and works anywhere nationwide. -
130° viewing angle
See more of every moment with a 130° wide-angle lens. -
Advanced motion detection
Wide-angle PIR motion sensor makes sure no movement will slip through without your notice. -
Local backup storage
Built-in SD card slot allows for local backup storage in the event of Internet interruption. -
Weather resistant
Rain or shine, hot or cold, the IP65-certified Arlo Go camera will brave it all. -
Rechargeable
Long lasting rechargeable batteries take the expense out of uninterrupted security. -
Night vision
Integrated night vision automatically switches on at night to shed light on the smallest wonders. -
Plays well with others
- Arlo Go Mobile HD Security Camera - network surveillance camera
- Network surveillance camera - fixed - outdoor - weatherproof
- Audio
- Yes: built-in speaker, built-in microphone, two-way audio capability
- 9 cm x 6.95 cm x 7.79 cm
- 335 g
- Connectivity Technology
- Wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1280 x 720
- Motion Detection
- Video Modes
- 720p
- HSUPA, LTE, WCDMA, 3G, 4G, HSDPA, HSPA+
- E-mail alerts, Advanced Motion Detection, Push Notification, integrated rechargeable battery, Audio Detection
- 1-year warranty
- Environmental Parameters (operating)
- -20 °C - 45 °C
- Audio Support
- Wireless
- 9 cm
- 6.95 cm
- 7.79 cm
- 335 g
- Localisation
- United Kingdom
Camera
- Colour - Day&Night - fixed - outdoor - weatherproof
- Digital Video Format
- H.264
- Max Digital Video Resolution
- 1280 x 720
- Motion Detection
- Video Modes
- 720p
- Digital Zoom
- 8
- Infrared LEDs
- Infrared Distance
- 7.6 m
Lens Construction
- Horizontal Field of View (degree)
- 130
- Network Interface
- Supported Memory Cards
- microSD Card, microSDHC Card, microSDXC Card
- Included Accessories
- SIM card, outdoor security mount, 3 screws, window decal
- UL, IC, FCC, IP65
- Battery
- 3660 mAh
- OS Required
- Android, Apple iOS
- Limited warranty - 1 year
- -20 °C
- 45 °C
