Arlo ESSENTIAL2 XL FHD OUTDOOR CAMERA 2-PACK
Quicklinx: HV7NWS00 Mfr#: VMC2252-100EUS
Compatible With: Alexa, Google Assistant
£190.84 ex VAT
£229.00 inc VAT
See the essential details, longer. Arlo Essential XL captures video in 1080p resolution, with an integrated spotlight, and color night vision. It's perfect for high-traffic locations or areas that are difficult to reach.
  • 2 years of protection
    All the trusted features of the Essential camera with up to 2 years of protection from just one charge thanks to the XL battery.
  • Easy to install
    Unbox and go with Bluetooth installation - set up in minutes with just a few screws and no wires.
  • Realistic video
    1080p resolution gives you realistic video so you can see what's happening around your home.
  • Color night vision
    Accurately see what's happening at your home in vivid color even in the dark with Full HD color night vision.
  • Powerful spotlight
    Light up 7 m of your property with bright spotlight. Have it come on automatically when motion is detected or turn it on manually from the app to make it harder for intruders to hide.
  • Weatherproof
    Rain-, sun-, wind- and snowproof. Its super-strong polycarbonate casing - the same material used in bullet-proof glass - means your camera can work in temperatures from -20°C to 45°C.
Arlo Essential XL - 2nd Generation - network surveillance camera
Network surveillance camera - fixed - indoor, outdoor - weather resistant
Packaged Quantity
2 (specifications are for single item)
Audio
Yes: two-way audio capability, built-in microphone, built-in speaker
Camera Mount Type
Wall mount
5.73 cm x 8.26 cm x 9.66 cm
454 g
Wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Motion Detection
Video Modes
1080p, 720p
Optical Sensor Type
1/3" - 2 MP
Wi-Fi
Platform
Google Home
Intelligent Assistant
Charging cable
Colour Night Vision, built-in siren, built-in spotlight, RGB status LED, PIR detection
1-year warranty
Environmental Parameters (operating)
-20 °C - 45 °C
Packaged Quantity
Audio Support
Camera Mount Type
Wall mount
Wireless
5.73 cm
8.26 cm
9.66 cm
454 g
Camera
Colour - Day&Night - fixed - indoor, outdoor - weather resistant
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p, 720p
Digital Zoom
12
Infrared LEDs
2
Digital Video Capture Resolution
1920 x 1080
Image Sensor
2 MP 1/3"
Lens Construction
Diagonal Field of View (degree)
130
Network Interface
Wi-Fi
Charging cable, wall mount kit
Charging cable
Lithium Ion 18600 mAh (up to 16 months)
Internet of Things (IoT)
Platform
Google Home
Compatible Application
IFTTT App
Limited warranty - 1 year
-20 °C
45 °C
Brand: Arlo
