Arlo ESSENTIAL2 2K VIDEO DOORBELL
Quicklinx: HV7LWS00 Mfr#: AVD4001-100EUS
Type: Smart doorbell
Compatible With: Alexa, Google Assistant
£124.17 ex VAT
£149.00 inc VAT
The Arlo Video Doorbell 2K (2nd Generation) enhances home security and convenience with its comprehensive features. Designed for outdoor use, it operates reliably in extreme temperatures ranging from -20°C to 45°C. This smart doorbell integrates smoothly into your home automation system, offering compatibility with IFTTT App, Alexa, and Google Assistant for extensive voice control.
With 2-way audio, an RGB LED indicator, and motion detection, you're always connected to your front door, able to communicate with visitors and receive notifications in real-time. The integrated camera, with a 2K resolution and a 180° diagonal field of view, provides clear images both day and night, supported by echo and noise reduction for clear audio quality. Whether you prefer a battery or hardwired power source, the Arlo Video Doorbell 2K (2nd Generation) provides flexibility in installation, making it a smart addition to your home's security and convenience.
  • Effortless installation
    The Arlo Video Doorbell 2K (2nd Generation) offers both battery and hardwired power sources, ensuring a seamless setup process tailored to your home's needs.
  • Enhanced security features
    Equipped with a camera, motion detection, and a built-in siren, this smart doorbell enhances your home security by providing real-time alerts and the ability to respond to visitors from anywhere.
  • High-quality video
    With a 2K video resolution and a 180° field of view, the doorbell camera captures clear, wide-angle videos day and night, ensuring you never miss a detail.
  • Smart compatibility
    Fully integrated with Alexa and Google Assistant, this IoT-compatible device allows for effortless voice control and automation, making it a smart addition to any modern home.
  • Convenient communication
    Features like 2-way audio and RGB LED indicator facilitate easy communication with visitors, enhancing both your home security and convenience.
Arlo Video Doorbell 2K (2nd Generation) - smart doorbell - Wi-Fi - white
Smart doorbell - with camera
Environment
Outdoor
Functions
Siren, motion detection, camera, doorbell
Integrated Sensors
Motion sensor
Integrated Components
Microphone, speaker
Power Source
Hardwired, battery
Intelligent Assistant
Google Assistant, Alexa
Wireless - Wi-Fi
Frequency Band
2.4 Ghz
Camera
Max Resolution 1944 x 1944 - audio - Day&Night
Camera Zoom
12x digital zoom
White
Environment
Outdoor
Functions
Microphone, speaker
Integrated Sensors
Motion sensor
Power Source
Hardwired, battery
Wireless - Wi-Fi
Frequency Band
2.4 Ghz
2-way audio, RGB LED indicator, status notification
Internet of Things (IoT)
Hub
Not needed
Compatible Application
IFTTT App
Camera
Day & Night Functionality
Digital Zoom
12
Audio Support
Max Digital Video Resolution
1944 x 1944
Video Modes
2K
Echo reduction, built-in siren, noise reduction, cloud recording, motion detection, 180° field of view (diagonal)
Motion Sensor
Detection Range
3.05 m
Software
Arlo Secure (30 days trial)
Battery Lifetime
4 months
Screws, charging cable, flat mounting plate, angled mounting plate, release pin, wire extension kit
White
-20 °C
45 °C
Brand: Arlo
