Arlo Essential Spotlight Camera - Pack of 3 White
Quicklinx: FZHFWS00 Mfr#: VMC2330-100EUS
Cover the basics with our straightforward wireless security camera.
Home security you can control from your smartphone. 100% wire-free and weather resistant, install in minutes for no-fuss protection.
6 month battery life
Wire-free, no cords or wiring hassles
Capture clear details in full high definition
Record video in 1080p, and see more of the picture with a 130° viewing angle.
Weather Resistant
Withstands heat, cold, rain or sun
Motion detection alerts
Take quick action and view live video, sound the siren, or call a friend directly from your phone.
See in colour, even at night
Ward off intruders and view unique details in colour with the integrated spotlight.
Simple installation
Set up your camera in a few easy steps thanks to its 100% wireless design. Connect directly to wifi - no base station required.
2-way audio
Hear and speak to visitors in real time with high quality audio via the Arlo app or using your smart assistant.
Deter intruders with built-in siren
Set the siren to sound automatically during an event or trigger it remotely from the app.
Connect and control with your favourite smart assistant
Works with Amazon Alexa, Google Assistant and IFTTT.
  • Weather-resistant security
    Arlo Essential is designed to withstand heat, cold, rain, and sun.
  • See in colour, even at night
  • Quickly install
    Set your wire-free camera in just a few easy steps.
  • Deter intruders with built-in siren
    Trigger your siren automatically, or manually from your phone.
  • Get alerts when motion is detected
Arlo Essential - network surveillance camera
Network surveillance camera - fixed - indoor, outdoor - weatherproof
Packaged Quantity
3 (specifications are for single item)
Audio
Yes: two-way audio capability, built-in microphone, built-in speaker
Camera Mount Type
Wall mount
5.2 cm x 7.84 cm x 8.9 cm
331 g
White
Wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Optical Sensor Type
CMOS
Wi-Fi
Intelligent Assistant
Built-in spotlight, e-mail alerts, 110-degree motion detection angle, echo reduction, built-in siren, noise-cancellation
1-year warranty
Environmental Parameters (operating)
-20 °C - 45 °C
Packaged Quantity
Audio Support
Camera Mount Type
Wall mount
Wireless
5.2 cm
7.84 cm
8.9 cm
331 g
Europe
Camera
Colour - Day&Night - fixed - indoor, outdoor - weatherproof
Digital Video Format
H.264
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Digital Zoom
12
Infrared LEDs
Infrared Distance
7.62 m
Digital Video Capture Resolution
1920 x 1080
Image Sensor
CMOS
Lens Construction
Diagonal Field of View (degree)
130
Network Interface
Wi-Fi
Wall mount kit
FCC, IC
White
Software Included
Arlo Smart (3-months trial)
Internet of Things (IoT)
Limited warranty - 1 year
-20 °C
45 °C
