From kids and pets to an empty home or after-hours business, you've got a lot to keep safe. Day or night, indoors or out, Arlo takes the wondering and worrying out of life with the world's only 100% wire-free indoor/outdoor home monitoring system. Security so simple - just place Arlo's weatherproof cameras wherever you need them without needing to find a power outlet. They are battery powered that last up to 6 months. Then use the free Arlo app anytime, anywhere to see crystal-clear live and recorded HD video. Arlo's motion sensors automatically send alerts to your phone when movement is detected, and records to your free private cloud storage to review anytime. Arlo is always ready to go when you are - add extra cameras to your system with the touch of a button.
Arlo at your fingertips
Enjoy complete command of your connected home security cameras thanks to the free, highly rated Arlo App. Customize settings, communicate instantly and more. -
Built for the real world
Versatile magnetic mounts, weatherproof enclosures and superior battery life are just a few of Arlo’s enduring advantages.
- Arlo Add-on HD Security Camera VMC3030 - network surveillance camera
- Network surveillance camera - fixed - outdoor - weatherproof
- 4.1 cm x 7.1 cm x 6.4 cm
- 113 g
- Connectivity Technology
- Wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1280 x 720
- Motion Detection
- Optical Sensor Type
- CMOS
- Focal Length Control
- Fixed focal
- Focus Adjustment
- (min distance 60 cm)
- IEEE 802.11n
- Auto exposure control, e-mail alerts, Motion Detection Technology, infrared cut filter, Push Notification, quad video stream, LED indicator, auto white balance
- Environmental Parameters (operating)
- -10 °C - 50 °C
- Wireless
- 4.1 cm
- 7.1 cm
- 6.4 cm
- 113 g
- Localisation
- Europe
Camera
- Colour - Day&Night - fixed - outdoor - weatherproof
- Digital Video Format
- H.264
- Max Digital Video Resolution
- 1280 x 720
- Motion Detection
- Infrared Distance
- 7.5 m
Image Sensor
- CMOS
Lens Construction
- Fixed focal
- Min Focus Distance
- 60 cm
- Network Interface
- IEEE 802.11n
- Included Accessories
- Magnet mount
- UL, IC, FCC, IP65
- Battery
- CR123 x 4 Lithium Ion (up to 6 months)
- -10 °C
- 50 °C
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
